Are you connected directly to the relays? Very bad news if yes. Use a
transistor buffer between the BASIC Stamp and any high-current devices like
relays. The other thing that you may need to do is connect a diode across the
relay coils. When you relax the relay, the magnetic field collapse induces a
current and that could be upsetting the BASIC Stamp.
-- Jon Williams
-- Dallas Office
Yes, I have a transistor buffer, and yes, I have
a diod across the relay coils. Does not help.
I can control the relays without disturbing the servo,
but as soon as I connect the DC motor, the servo goes wild.
I have unplugged the control line to the servo, but still
powering it, and no problem occurs. So it looks like it´s
the signal line from BS1 that makes the servo crazy ...
More ideas ? (please ...)
/ Mike
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
Use a transistor buffer between the BASIC Stamp and any high-current
devices like relays. The other thing that you may need to do is
connect a diode across the relay coils. When you relax the relay,
the magnetic field collapse induces a current and that could be
> -- Jon Williams
> -- Dallas Office
> From: mikael_axen2002 [noparse][[/noparse]mailto:mikael_axen@h...]
> Sent: Monday, March 29, 2004 12:47 AM
> Subject: [noparse][[/noparse]basicstamps] DC-motor makes BS1 act weird. Why?
> Howdy!
> I have two relay-schemes connected to two I/O on my BS1.
> The ídea is that one relay controls a DC motor on/off, and the
other reverses the polarity (to the DC motor) to control
forward/backward. The motors are powered by a 2x1.5v battery pack
(1.5v per direction). The BS1 is powered by a 9v battery. I also have
a servo to steer the craft with, this is powered by a 4x1.5v
batterypack.
> The DC motor is taken from a cheap wired control toycar.
> Now to the *problem* : When I run the DC motor, the servo goes
wild, uncontrallable. Just controlling the relays works fine! Just
controlling the servo works fine! The problem occurs only when
actually running the DC motor. I think maybe the DC motor creates
some AC that somehow goes into BS1? Maybe a capacitor to ground could
help? But how big in that case...? Any ideas are appreciated!
> Thanks!
> Mike / Sweden
Just a thought, but has anyone on the forum mentioned using ferrite beads on
external I/O leads to shunt out RF trash? Also, does everyone know about
stacking little picofarad-range disc caps on top of electrolyte caps. Since
electrolytic caps are rolled up inside, they have a lot of inductance which
will present a high impedance to RFI. I suspect that many users are simply
putting big honking 1,000 microfarad caps across the power supply feeds,
which will help with sagging supplies from current draw, but will let
high-frequency garbage zing right on through. Every external line used in a
shared RFI/Computer environment (and yes, as Basic Stamp is certainly a
computer, and yes relay coils and such can generate RFI) needs to be
properly terminated, shielded, and RFI protected. Noise is a bad thing....
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Monday, March 29, 2004 10:57 AM
Subject: [noparse][[/noparse]basicstamps] Re: DC-motor makes BS1 act weird. Why?
Thanks for your reply!
/ Mike
> -- Jon Williams
> -- Dallas Office
> Howdy!
batterypack.
> Thanks!
> Mike / Sweden
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
If possible treat the motor as a relay coil BEFORE the
relay that controls direction and place a diode in reverse
bias there. From the sounds of it, you are driving your
motor in a half-bridge configuration with the relays. This
is fine but may not be conducive to adding diodes.
Another approach (AND/OR with the above) is to use a delta
capacitor pattern between the motor and ground.
GND <---||---o---||---o---||---> GND
A B
Note:
- A and B terminals go across your motor.
- ALL capacitors are .1uF ceramic disc type.
The statement you make "The DC motor is taken from a cheap
wired control toycar" says it all. The brushes on these
type of motors generate LOTS of noise. The capacitor
scheme above should clean a majority of this up.
>/ Mike
> > -- Jon Williams
> > -- Dallas Office
> > Howdy!
>batterypack.
> > Thanks!
> > Mike / Sweden
Beau Schwabe Mask Designer National Semiconductor Corporation
500 Pinnacle Court, Suite 525
Home: polygon_man@h... Mail Stop GA1
Work: bschwabe@a... Norcross, GA 30071
>/ Mike
Mike -
Are all your grounds tied to one common point ? If not, they need to be.
Bruce Bates
>> -- Jon Williams
>> -- Dallas Office
>> Howdy!
>batterypack.
>> Thanks!
>> Mike / Sweden
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
> >/ Mike
>Mike -
>Bruce Bates
Bruce,
He's not going to be able to do this easily with a "split" power
supply driving the motor. (Half-Bridge)
In his case it might be better to connect all of the grounds
EXCEPT the motor circuit, thus completely isolating both power
and ground of the motor.
> >> -- Jon Williams
> >> -- Dallas Office
> >> Howdy!
> >batterypack.
> >> Thanks!
> >> Mike / Sweden
Try connecting the motor casing to ground. I experienced a similar problem
controlling a DC motor with a relay and a BS2-IC, but it solved the problem.
Good luck.
/ Mike
> -- Jon Williams
> -- Dallas Office
> Howdy!
batterypack.
> Thanks!
> Mike / Sweden
-- Jon Williams
-- Dallas Office
From: mikael_axen2002 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hzB8zddrJne0lVlLCkFcxQdDHBnQeihbt7PlUpu3hf2eCN6l2x9gN_R_LZv4_mWHGJcIZOvFJjPzO6lSEvU7oQ4]mikael_axen@h...[/url
Howdy!
The
/ Mike
> -- Jon Williams
> -- Dallas Office
> Howdy!
batterypack.
> Thanks!
> Mike / Sweden
Mike Sokol
mike@f...
www.fitsandstarts.com
-William of Occam-
/ Mike
> -- Jon Williams
> -- Dallas Office
> Howdy!
batterypack.
> Thanks!
> Mike / Sweden
Yahoo! Groups Links
A B
Note:
>/ Mike
> > -- Jon Williams
> > -- Dallas Office
> > Howdy!
>batterypack.
> > Thanks!
> > Mike / Sweden
>/ Mike
Mike -
Bruce Bates
>> -- Jon Williams
>> -- Dallas Office
>> Howdy!
>batterypack.
>> Thanks!
>> Mike / Sweden
>Yahoo! Groups Links
> >/ Mike
>Mike -
>Bruce Bates
Bruce,
> >> -- Jon Williams
> >> -- Dallas Office
> >> Howdy!
> >batterypack.
> >> Thanks!
> >> Mike / Sweden
Good luck.
Best regards,
Russell Warburton
email: russell@w...
website: http://www.warburtech.com
telephone: +44 (0)7814 044 754
Sent: Monday, March 29, 2004 4:57 PM
/ Mike
> -- Jon Williams
> -- Dallas Office
> Howdy!
batterypack.
> Thanks!
> Mike / Sweden
Yahoo! Groups Links
