Atmel I2C EEPROM chips and
I had been having some difficulties working with the Microchip
24LC515 I2C 512 kbit EEPROM chips, so I ordered a set of Atmel
AT24C512 chips (also 512 kbit) to try out instead. After
receiving them, I ran a test program which failed and started
reading over the data sheet to find the problem.
It appears that the Atmel chips require a "dummy write" operation
to reset the current memory location. This consists of sending
the device address with the R/W bit set to write and the memory
address, then sending a device address with the R/W bit set to
read and clocking in the data.
To my knowledge, the Basic Stamp can't do this. It seems
peculiar on the part of Atmel to read the data this way.
Anyway, this is something to keep in mind if you use some of the
Atmel I2C EEPROMs. I don't know how many chip models do this.
(The Microchip problem I was having was posted here about a year
ago - basically, I could only access half of each chip because it
appeared to ignore the "block select" bit)
- Mark
Mark D. Conner
E-mail: n9xtn@a...
Homepage: http://members.cox.net/mconner1
"Arrogance and stupidity, all in the same package.....how
efficient of you!" - Ambassador Londo Mollari, Babylon 5
- Mark
Mark D. Conner
E-mail: n9xtn@a...
procedure. It might be the root cause of your MicroChip eeprom problems as
well.
The process to read is (in Pseudocode)
Tell the EEProm which address you want to read from.
I2CStart
I2CWrite WriteCommand 'EEprom address 7 bits + 0/1 for read/write
I2CWrite HighAddress 'High Address Byte of the value you want to read
I2CWrite LowAddress 'Low Address Byte of the value you want to read
I2CStart ' Start I2C again - note NO stop!
Now you can actually read starting from the location specified
I2CWrite ReadCommand
I2CRead ReadAbyte, Ack
I2CRead ReadAnotherByte, ACK
I2CRead ReadLastByte, NACK 'Dont ACK the last byte read
I2CStop
> From: Mark Conner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HQItKckGJyTgmSDxZcA2o01O4F9JrRdgjLohFS81OLq6DBlDaKHaAWPKHh5IfKgxIp6Jfac]n9xtn@c...[/url
> Sent: March 28, 2004 1:29 PM
> Subject: [noparse][[/noparse]basicstamps] Atmel I2C EEPROM chips and "dummy write"
> - Mark
> Mark D. Conner
> E-mail: n9xtn@a...
> from the same email address that you subscribed. Text in the
> Yahoo! Groups Links
writes:
I am using an Atmel AT25HP512 - -512Kbit - chip with great success. Page
write only. 128 bytes per page, 512 pages. SPI 3-wire.
Sid Weaver
W4EKQ
Port Richey, FL
It seems to me it should work fine with the "current read" or the
"sequential read" modes. The BASIC Stamp should have a problem only
with the "random read" mode. These EEPROM chips hold onto the last
address that is written or read, and that address is maintained so
long as the power is on. The address increments automatically with
each read operation (modulo the memory size) or write operation
(modulo the page size).
I'd guess that if the Stamp sends the slaveID, followed by the 16 bit
address, and then ack and stop, the address will be successfully
loaded into the EEPROM's address register. And the Stamp can follow
that with a current read or a sequential read. Are you saying that
that is not the case? The protocol 'AT512 is not much different from
other EEPROM memories like the popular '24LC128. Those also have the
random read option, where a stop + start condition can be replaced
with a shortcut start only between the random address write and the
data read.
Do you have the pullup resistors installed? Are you using a BS2p or
pe, or an earlier stamp with bit-banged I2C?
-- Tracy
>- Mark
>Mark D. Conner
>E-mail: n9xtn@a...
The sequence to set the address without reading or writing anything
_might_ be...:
I2COUT 0,$A0,$12,[noparse][[/noparse]$34] ' set address $1234, but no
extra data
or, (only if you have a '2p version 1.3 with the optional high address)
I2COUT 0,$A0,[noparse][[/noparse]$12,$34] ' set address $1234, but no
extra data
No guarantees that the above will work! It depends on the chip's
internal logic--when does it latch the address? The I2C protocol
does not make any real distinction between "address" and "data". It
is the EEPROM chip that interprets the 2 bytes it receives after the
slaveID as an address. The Stamp does tokenize the above cases
differently, I am not sure why.
I'm still surprised that the standard syntax does not work for you.
I2CIN 0,$A1,$12\$34,[noparse][[/noparse]mybyte1, mybyte2,.....] ' read bytes
Internally, AFAIK, the Stamp deals with that as a random read exactly
according to the description in the data sheet, with the "dummy"
write of the address followed by a start condition and immediately
the read, as PatM outlined.
That is why I asked about the pullups. Also, are you using p0, p8,
x0 or x8 for the sda, double checked the wiring? Address pins on the
EEPROM matched to the slaveID? Write protect pin grounded?
-- Tracy
16 bit
OK. How do you do that with BS2p commands?
that
from
the
replaced
the
>data read.
Near as I can tell, the only way to send an I2COUT command is to
send an actual byte of data. I tried leaving the data argument
off the command and the compiler said "no".
BS2p or
Yes, I use the pull-ups suggested in the BS2p docs. My BS2p is a
version 1.2. Could that be a problem? I heard mention on the
list of other I2C difficulties with <1.3 chips.
- Mark
Either of the following two instructions will successfully set the
address pointer in an 24LC128 to a value of $0134, without actually
writing any data to the chip: This is not documented in the eeprom
data sheet.
I2COUT 0,$A0,$01,[noparse][[/noparse]$34] ' BS2p v1.2 or v1.3, BS2pe v1.0 or v1.1
I2COUT 0,$A0,[noparse][[/noparse]$01,$34] ' BS2p v1.3, BS2pe v1.0 or v1.1
The following command will read the data starting at that location,
without resetting the address. Note that this does not work on the
BS2p v1.2, because it can't do an I2CIN without specifying an address.
I2CIN 0,$A1,[noparse][[/noparse]x] ' BS2p v1.3, BS2pe v1.0 or v1.1
' reads byte at address $0134 set above
I2CIN 0,$A1,[noparse][[/noparse]y,z] ' reads two more bytes with autoincrement
This form would doubtless be faster than the form with the address,
if you need to read a bunch of stuff in a loop.
The usual method of using I2CIN with a random address setting also
works, of course, with the 24LC128.
I2CIN 0,$A1,$01\$34,[noparse][[/noparse]x] ' BS2p v1.2 or v1.3, BS2pe v1.0 or v1.1
' reads one byte from location $0134
' note--address autoincrements to $0135
I don't know why that would not work on an 'LC512 or the Atmel part
specifically, but I don't have one here to try. It does work on an
'LC256 and the Catalyst 'WC256.
-- Tracy
