Phone generator/ringer overcomplicated?
I need to build a phone ringer (I have the frequency generator).
What is needed is when the operator pushes the buttor the phone
selected, it rings like a real phone untill the receiver is picked
up. I was looking at timer relays but they are about as expensive as
using a stamp and icecube relays. Does this seem right or am I
overdoing it again with a stamp? Any help appreciated.
Ian
Ian
between rings and control of the relay(s). How are you going to sense
that the reciever was picked up? You can do it from the remote end, but
it will require current sensing if memory serves me.
-- Jon Williams
-- Dallas Office
From: iphillipsca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Wg6ZTlPrM6Sx7mWOnLzParplZSCuyR7NAkKUtlZqrLQZpKZwMGbCGQf-ptlEhSEJMJkGZdmdE7MFp_TB7vg1SLk]iphillips@s...[/url
Sent: Friday, March 26, 2004 10:47 AM
Subject: [noparse][[/noparse]basicstamps] Phone generator/ringer overcomplicated?
Ian
phone to ring. Can't remember if this is a square wav or sine wave, but I'm
guessing a square wave would work. A phone does indeed present a specific
impedance load to the line, around 600 ohms or so. If that's the case (and
I'm pretty sure it's close) you could hook the output of the stamp to drive
a little IC audio amplifier with a 12-volt power supply, or even a FET,
remembering the flyback diode. You can probably get the voltage up to the
needed level with a 10:1 transformer, but you'll have to match the frequency
of the AC wav, which escapes me at the moment. Should be pretty simple once
you verify voltage and such.
And yes, you can get a pretty good shock from the phone line when it rings.
Been there... Done that...
Mike Sokol
mike@f...
www.fitsandstarts.com
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Friday, March 26, 2004 11:46 AM
> Ian
> Yahoo! Groups Links
>If memory serves, a telephone line puts out around a 100 volt AC swing for a
A >>long<< time ago you use to be able to see 48V battery packs on
tele-poles...
The "ring" was generated by switching polarity effectively creating 96V AC.
A Square wave does work ok, but if I remember correctly this feature (sine vs.
square) is what distinguished the top-of-the-line vs. the knock off TELCO
testers... Radio Shack used to sell one.
I think that the frequency is 20Hz .... (could always scope your phone line
and call it from another phone)
Nothing like stripping wires (with teeth - dumb kid I was) and having the
phone just happen to ring! Ouch
>Mike Sokol
>mike@f...
>-William of Occam-
> > Ian
Beau Schwabe Mask Designer National Semiconductor Corporation
500 Pinnacle Court, Suite 525
Home: polygon_man@h... Mail Stop GA1
Work: bschwabe@a... Norcross, GA 30071
have the generator I would only be switching the output of it to
multiple phones. And yes, I have Bin there Dun that too!
Ian
From: Mike Sokol [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=G7tVEWpZbZR2bdgitTS7_D2BQkKUzZ-tWQNek_imhLXpEUgbeQlomjVVYfbPN7b_kJ6oLeozkmXAw6hYYPBJ]mike@f...[/url
Sent: March 26, 2004 12:29 PM
Subject: Re: [noparse][[/noparse]basicstamps] Phone generator/ringer overcomplicated?
for a
I'm
specific
(and
drive
the
frequency
once
rings.
Mike Sokol
mike@f...
-William of Occam-
> Ian
and
> Yahoo! Groups Links
Yahoo! Groups Links
4 seconds pause. Use a dpdt relay, controlled by the 555's, to switch
the ring generator in and out of the loop. Since you apparently have a
pair of wires going to the phone on the remote end. An optocoupler in
series with your loop current, or parrallel if you prefer, will give you
the answer detect. The only hard thing is catching the phone being
picked up DURING a ring. Have the operator switch set a latched relay,
and the loop current detector release the switch. Course, you can by a
phone line simulator for under a hundred bucks that will do all this for
you, including providing loop current to the far end.
> Ian
> Yahoo! Groups Links
