Op Amp to BS2 Blues
I constructed the amplifier circuit shown in N&V column #57 to
connect to an ADC as described, except for changing the gain resistor
to 202 ohms (to provide a gain of 100). After trouble shooting the
circuit a number of times, I still can't get any amplification of the
sensor output. The OP amp output measures about 0.3 volts and does
not change with changing input mV. I measured the sensor and can
read changing mV with increasing presssure so I feel like the sensor
works correctly. Is the circuit correct as shown? Does anyone have
any ideas on checking the op amp ICs or how I can split the circuit
and troubleshoot each IC? Any help would greatly appreciated.
Walt Beckwith
Walt Beckwith
resistor
the
sensor
have
circuit
> Walt Beckwith
Hi Walt,
Can you post a layout of your unit ?
Are you breadboarding it ? maybe a pic ?
Dave
the input drive voltage source ground at the same potential as the device
(op amp) ground. This is easy to overlook.
jim
http://www.geocities.com/jimforkin2003/
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=27mInqKEgxNp48bS6GyT6iQ4uhSosDbSBHf52OBFK8jDDRFi6GW_g_xG8PXedkDF-avwJDQu97N3TA]davemucha@j...[/url
Sent: Thursday, March 25, 2004 10:01 PM
Subject: [noparse][[/noparse]basicstamps] Re: Op Amp to BS2 Blues
--- In basicstamps@yahoogroups.com, "waltb27707" <wbeckwith@m...>
resistor
the
sensor
have
circuit
> Walt Beckwith
Hi Walt,
Dave
Yahoo! Groups Links
202 ohms seems a little low to provide a gain of 100X. Try a pot of 100k and
see what happens. What is the value of the input resistor? I *think* that
the gain resistor / input resistor = gain.
Jonathan
www.madlabs.info
Sent: Thursday, March 25, 2004 6:58 PM
Subject: [noparse][[/noparse]basicstamps] Op Amp to BS2 Blues
> Walt Beckwith
> Yahoo! Groups Links
Thank you for your replies. I hard wired the circuit on ONE PAS
board and put the two OPA 2340 ICs in sockets. I don't have a
photo. The circuit is at:
http://www.parallax.com/dl/docs/cols/nv/vol2/col/nv57.pdf Figure
57.2
The gain is calculated by: Vout=(Vhigh-Vlow) (1+2R1/Rgain) R1 is 10K
ohms. The circuit was wired up with 0.22uF bypass caps wired between
pins 4 (-) and 8 (+) on each OPA 2340. I am powering the circuit with
12 volts (8 AA batteries) 12 volts energizes the sensor input
leads. I have a 7805 regulator that drops the voltage to 4.89 volts
which powers the op amps. There is a common ground between 12 volt
and 4.89 volt side. The V low sensor output is not grounded. I'm
not sure how to check ground potentials. I get 4.89 volts from any
regulated positive to any grounded pin or wire with a Radio Shack
DMM.
According to the Spec sheet the OPA2340 can be run from a single
supply of 2.5 to 5.5 volts. Which is what I did. There is nothing
about running from a split supply. I'm beginning to think another amp
might be a better choice.
Thanks for the ideas Guys. I will keep checking.
resistor
the
sensor
have
circuit
> Walt Beckwith
--- Walter Beckwith
--- wbeckwith@m...
--- EarthLink: The #1 provider of the Real Internet.
providing from the sensors to the op amps, add the gain for the difference
between the two, and I suspect you're out of range especially since the op
amp is running from 5 volts. You are dealing with a gain of about 50 so .1
volts on the input would put you at the rail on the output.
jim
From: waltb27707 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=W2480LznMIeZ9fUZ1K8aIuarJC6NLQB3neYYNs7dBOgckviQT6E7mredKeHRzeHpThORL73XxSDeLa2fM39xP-Pf]wbeckwith@m...[/url
Sent: Sunday, March 28, 2004 10:12 PM
Dave, Jim, and Jonathan,
57.2
DMM.
resistor
the
sensor
have
circuit
> Walt Beckwith
--- Walter Beckwith
--- wbeckwith@m...
Yahoo! Groups Links
