Interfacting with RAM? (Say, 32kbyte or more) — Parallax Forums
edited 2004-03-26 18:17 in General Discussion
Anyone know of some good way to interface with real amounts of RAM?
They've got 512kbit EEPROMs out there. They've got little tiny serial
RAM chips. Am I overlooking something or some way of interfacing a
basic stamp to some real amout of RAM?
    edited 2004-03-25 20:54
    In a message dated 3/25/2004 3:32:13 PM Eastern Standard Time,
    jmccorm@y... writes:
    We have a device that will store 500 entries, upto 128 bytes per entry in
    real time. Please concact me off-line.
    Sid
    edited 2004-03-25 23:29
    Yes, you may be overlooking something.
    1. These EEPROMS can 'only' be written something
    like 1,000,000 times. This is fine if you don't want
    to scan video or something.
    2. These EEPROMS are serially interfaced.
    Some use I2C -- which means only certain BS2 platforms
    support them. Some lesser ones (64 KBytes) use
    SPI, and should work fine.
    3. It does take some time to access (write) these
    EEPROMS -- on the order of milliseconds. Thus, again
    you can't use them for video. Since the BS2 has like
    52 Bytes of RAM, having 64 K of 'slow' RAM hanging off
    them is helpful, but can be limiting, also.
    Other than that, they should be fine. Non-volitile,
    write often, very good for logging purposes. But
    you can't treat them like 'local' RAM.
    serial
    edited 2004-03-25 23:41
    http://www.solutions-cubed.com/solutions%20cubed/RPB2003.htm
    edited 2004-03-26 00:51
    I have used a 128x8 static RAM chip on a project that needed some
    extra RAM. A few latches, shift registers and some logic is all that
    it took. I had other parallel devices that I needed to interface as
    well so much of the circuitry was common. You can find links to
    schematics for the interface and code at
    http://www.kinzers.com/don/GenSet.
    For another project I was considering using a 32Kx8 Hitachi static
    RAM - HM62256 using the same type of interface. You can get data on
    that device here:
    http://www.web-ee.com/Electronic-Projects/data/hm62256.pdf
    For even more memory, check out the HM628128 - 128Kx8.
    Here is a cross-reference of RAM devices that may be useful:
    http://www.flippers.com/StaticRam.html
    edited 2004-03-26 02:25
    serial
    I'm interested in what you mean by real ammount of RAM.
    We are in a pre-release stage of a couple products, one has a small
    amount of ram that is non-volitle, but it is only in the 20-30k
    neighborhood.
    Another we have is an EPROM device that goes into lots more memory,
    but it is not RAM.
    Can you offer an idea what the typical use might be ?
    Dave
    edited 2004-03-26 07:23
    Most of the RAM chips I've seen out there for the basic stamp are
    pretty wimpy. We're talking a neighborhood of 2kbit or less being
    common in serial RAM. I'm pretty much satisfied with 512kbit EEPROMs
    on an I2C bus.
    > neighborhood.
    That's certainly a step above what is common out there.
    That's a fair and good question. What's the killer app for RAM?
    Guessing I'd say imaging/video/display/digitization. Of course, if you
    put more RAM out there, it'd be great to provide the killer app with
    it. [noparse]:)[/noparse]
    edited 2004-03-26 12:01
    If you need more RAM, maybe you should investigate some of the other
    8-bit processors on the marked. Zilog's eZ80Acclaim supports up to 256
    KB of Flash RAM, 16 KB of SRAM and 16 MB of external RAM. More
    informatioin here
    edited 2004-03-26 16:38
    You might also find Barry Michels' project interesting.
    http://barrymichels.com/ide/
    It is an interface to a CF card or IDE hard drive, but it also
    includes 128kbytes RAM and an LCD. He started the prototyping using
    a Stamp, with discussion here on this list, and then moved the
    control over to a PIC16C877. It has a serial interface (to the Stamp
    or a terminal).
    -- Tracy
    > on an I2C bus.
    The problem with EEproms is the limited read/write cycles. Our RAM
    board will offer in the trillions or read/write.
    you
    There in lies the problem. We can offer the 64k or 256k ram, but
    whatch-ya gonna do with it ?
    Our need was as a temporary storage before sending a page to the data
    logger. The 512k data logger can only accept page write so there is
    a little limit on the value, unless you can fill up a whole page.
    Enter the need for RAM, at least for us.
    But, look for neat things in the near future !
    Since we are using the BS2 there are some some features that might be
    gained by going to one of the faster Stamps. Gotta love the Stamp !
    Dave
