Tele-Alert program
hey there,
I am still doing the Tele -Alert system and i was going through the
program and i am not very familiar with Basic language. Inside the
project operating instruction, it mentions to go into the program and
just add in your number that you want to call but i cannot figure it
out where i am suppose to add the number? Is it under the undefined
%00000000 but i thought that was for the initiation of high and low's.
what alram cofiguration is this programmed to? just siren, lamp and
ledpin and tele?
ledpin and tele?
I did a search for this Tele-Alert system on the group here and came up with not
results. What is this Tele-Alert??? Sounds interesting and something that I may
want to use. Can some one direct me to where the code is and some description of
what it can do.
Gene
zuwenamalik <Zuwenamalik@y...> wrote:
hey there,
ledpin and tele?
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Finance Tax Center - File online. File on time.
Thank you for responding to me....eventhough you are having a
difficult time finding what i am talking about. Tele_Alert is an
Alarm Reporting system that will notify you through your cell phone
when an alarm is activated in your home. You can find this project in
the Stamp 2 Communication and control Projects by Tom Petruzzellis.
Maybe you can help me with the Program, I am not sure if it is in
Basic or Assembly language and where in the program can i put in the
cell number? Also i am on the process of purchasing an Epic
Programer for my project to make the circiut easier but i dont know
if i will have to use a different program for that. Below is the
copy of the program:
`Cell2.BS2
flash Var byte
new_io_state Var byte
old_io_state Var byte
call_state Var byte
io Var byte
timer Var byte
i Var byte
j Var word
TXpin Con 10
LedPin Con 15
Lamp Con 13
Siren Con 12
Tele Con 9
MIC Con 8
recall_delay Con 120
C Con 3000 'C - 523
D Con 2000 'D - 587
E Con 1000 'E - 659
F Con 500 'F - 698
G Con 250 'G - 783
A Con 150 'A - 880
B Con 100 'B - 987
R Con 0
init:
DIRL = %00000000
DIRH = %11111111
new_io_state = %00000000
old_io_state = %00000000
for flash = 1 to 3
high LedPin
pause 1500
low LedPin
pause 1500
next
main:
high LedPin
new_io_state=INL
pause 100
low LedPin
pause 100
if new_io_state <> %00000000 then dial_cell
after_io1:
old_io_state = new_io_state
goto main
delay_and_scan
for timer = 1 to recall_delay
high LEDPin
new_io_state=INL
pause 500
low LedPin
pause 500
if new_io_state <> old_io_state then dial_cell
next
goto after_io1
dial_cell:
if new_io_state = %00000000 then main
high LedPin
high Tele
high Lamp
high Siren
pause 500
dtmfout TXPin, 600, 600, [noparse][[/noparse]8]
dtmfout TXPin, 500, 100, [noparse][[/noparse]7,2,9,4,8,9,0]
sleep 10
gosub send_msg
goto delay_and_scan
send_msg:
io = new_io_state
if io.bit0=1 then gosub_chan_1
if io.bit1=1 then gosub_chan_2
if io.bit2=1 then gosub_chan_3
if io.bit3=1 then gosub_chan_4
pause 100
gosub_chan_1:
for i = 1 to 14
lookup i,[noparse][[/noparse]E,D,E,D,E,D,E,D,E,D,E,D,E,D],j
freqout 11,750,j,(j-1) max 32768
next
pause 200
goto fin_1
gosub_chan_2:
for i = 1 to 18
lookup i,[noparse][[/noparse]E,D,C,E,D,C,E,D,C,E,D,C,E,D,C,E,D,C],j
freqout 11,500,j,(j-1) max 32768
next
goto fin_2
gosub_chan_3:
for i= 0 to 24
lookup i,
[noparse][[/noparse]E,F,G,C,E,F,G,C,E,F,G,C,E,F,G,C,E,F,G,C,E,F,G,C],j
freqout 11,250,j,(j-1) max 32768
next
goto fin_3
gosub_chan_4:
for i= 0 to 28
lookup i, [noparse][[/noparse]C,D,E,G,C,D,E,G,C,D,E,G,C,D,E,G,C,D,E,G,C,D,E,G,C,D,E,G],j
freqout 11,150,j,(j-1) max 32768
next
goto fin_4
fin_1:fin_2:fin_3:fin_4:
pause 200
high MIC
pause 30000
low TELE
low LEDPin
low Siren
low LAMP
low MIC
pause 100
return
end
--- In basicstamps@yahoogroups.com, Gene Shults <ebs1955@y...> wrote:
> Hello
came up with not results. What is this Tele-Alert??? Sounds
interesting and something that I may want to use. Can some one direct
me to where the code is and some description of what it can do.
> Thanks
> Gene
> hey there,
and
it
low's.
> ledpin and tele?
Subject and Body of the message will be ignored.
> Yahoo! Groups Links
> Do you Yahoo!?
an alarm system and you are not sure if the dialect below is in
Assembly language or Basic.
The program below is Basic... You should do a search on telephone
touch tone or DTMF frequencies and look at some of the Basic Stamp I
dialect to understand what this program is doing. This is a MUST
for your sake, because this program is actually capable of dialing
several numbers based on the portion of code you provided.
>HEllo Gene,
>`Cell2.BS2
>flash Var byte
>call_state Var byte
>io Var byte
>timer Var byte
>i Var byte
>j Var word
>TXpin Con 10
>LedPin Con 15
>Lamp Con 13
>Siren Con 12
>Tele Con 9
>MIC Con 8
>C Con 3000 'C - 523
>D Con 2000 'D - 587
>E Con 1000 'E - 659
>F Con 500 'F - 698
>G Con 250 'G - 783
>A Con 150 'A - 880
>B Con 100 'B - 987
>R Con 0
>init:
>DIRL = %00000000
>DIRH = %11111111
>for flash = 1 to 3
> high LedPin
> pause 1500
> low LedPin
> pause 1500
>next
>main:
>high LedPin
>new_io_state=INL
>pause 100
>low LedPin
>pause 100
>after_io1:
>goto main
>delay_and_scan
> high LEDPin
> new_io_state=INL
> pause 500
> low LedPin
> pause 500
> next
>goto after_io1
>dial_cell:
>high LedPin
>high Tele
>high Lamp
>high Siren
>pause 500
>sleep 10
>gosub send_msg
>goto delay_and_scan
>send_msg:
>io = new_io_state
>pause 100
>gosub_chan_1:
>for i = 1 to 14
>next
>pause 200
>goto fin_1
>gosub_chan_2:
>for i = 1 to 18
>next
>goto fin_2
>gosub_chan_3:
>for i= 0 to 24
>lookup i,
>next
>goto fin_3
>gosub_chan_4:
>for i= 0 to 28
>next
>goto fin_4
>pause 200
>high MIC
>pause 30000
>low TELE
>low LEDPin
>low Siren
>low LAMP
>low MIC
>pause 100
>return
>end
> > Hello
> > Thanks
> > Gene
> > hey there,
>and
>it
>low's.
> > ledpin and tele?
Beau Schwabe Mask Designer National Semiconductor Corporation
500 Pinnacle Court, Suite 525
Home: polygon_man@h... Mail Stop GA1
Work: bschwabe@a... Norcross, GA 30071
