Using Visual Basic to control a BS2 SumoBot
Hello everyone. I was just wondering if I can use Visual Basic to
control or program a BS2 SumoBot. I want to build an interface using
VB and connect it to the robot via serial port. I hope that someone
can help me here as I'm very new in this topic.
Thanx in advance.
Thanx in advance.
frustrating haul. On our web site you'll find tools to compiler and
download PBASIC source code. What your program will have to do is
generate PBASIC source code from your interface, then send it to the
compiler (DLL for Windows).
It can be done ... but it won't be easy. We did this for our GUI-Bot
interface (we didn't use VB, but the process is the same) and it was a
lot of work.
-- Jon Williams
-- Dallas Office
From: eliza_yasmin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LMYqBi57EKHUhJCG4hu5P0WtFPbOm2hFnD_oOciYMsUfqdvGY-cWV5kjER7lapt9bDU_wbHv-_xOr1g8OCP1]eliza_yasmin@y...[/url
Sent: Thursday, March 25, 2004 3:46 AM
Subject: [noparse][[/noparse]basicstamps] Using Visual Basic to control a BS2 SumoBot
Thanx in advance.
This is a simple example, for both sides, of
how to talk to the BS2 with VB over the serial
port.
Having said that, you can CONTROL a BS2 Sumobot
with this approach, but you'll still have to
PROGRAM the SumoBot BS2 with the Parallax IDE.
You'll need to decide what you want to tell the
BS2 (Go straight, turn left, did IR hit?, etc)
and design a simple set of messages to send
back and forth. Once you've done that you can
program the BS2 to respond to the messages
using the IDE. You then program the PC with
VB to make a user interface which will send
and report the messages sent. Hook them both
together and off you go.
--- In basicstamps@yahoogroups.com, "eliza_yasmin"
using
> Thanx in advance.
already have the Basic Stamp Editor in my pc. I would
appreciate if u could explain to me what I need to do
step by step. What I have in mind is:
1) Connect the robot to the pc via serial port.
2) Build the interface (Attached are the Grid Plan)
using VB.
3) User will click at any Lot (lets say Lot A), then
the robot will go to Lot A along the route from a
fixed location.
4) I need to program the robot (to move to the front,
left or right) based on the gridpoints in VB. This
will be done using the Editor am I right?
But the question is, can Basic Stamp communicate with
VB?
--- Jon Williams <jwilliams@p...> wrote:
> If you're not already an expert programmer you're in
> for a long
> to compiler and
> have to do is
> then send it to the
> same) and it was a
> lot of work.
> -- Jon Williams
> -- Dallas Office
> From: eliza_yasmin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UoZdEa8aVgPKSqk2jW8r6PnLpwCLcrMuCaRzm5c13C4-FXLnfpG4UyM0obmDtzvhQ9XrJ7ICu5B55UOA9RVlDA]eliza_yasmin@y...[/url
> a BS2 SumoBot
> Visual Basic to
> interface using
> hope that someone
> Thanx in advance.
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! Finance Tax Center - File online. File on time.
http://taxes.yahoo.com/filing.html
http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv89.pdf
There is a difference between communication and reprogramming, however.
If you just want to communicate, using a command processor program on
your SumoBot(r), then it won't be a big task beyond the creation of your
VB program (which we won't discuss here -- this forum is about BASIC
Stamp programming).
Between the article sited above and your personal VB skills, you should
be able to do what you suggest in #3 below.
-- Jon Williams
-- Dallas Office
From: Eliza Yasmin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VLdNXne71G9nNCSQtvoM2g5KGRMPA3egY4oIPIRk9uAdqZbR-WmoH5az4wOB3g4uqkF5uvjni8VaNTGsa948YS0]eliza_yasmin@y...[/url
Sent: Friday, March 26, 2004 7:26 AM
Subject: RE: [noparse][[/noparse]basicstamps] Using Visual Basic to control a BS2 SumoBot
Wow. I must be prepared for the frustrating haul. I
already have the Basic Stamp Editor in my pc. I would appreciate if u
could explain to me what I need to do step by step. What I have in mind
is:
using VB.
fixed location.
VB?
