Degree calcuration for rotational cooridate?
I got values of X and Y for each x axis and y axis, but I don't know
how to write basic stamp code to calculate degree of rotation. If
anybody know, please let me share the code.
Bless you all!
Bless you all!
If I understand your question, the short answer is theta = atan(y /
x). Now the trick, of course, is to compute the arctangent and do it
without floating point, too. If you're committed to using the Basic
Stamp, you might investigate the CORDIC algorithm. You should be
able to achieve the desired result that way using fixed point
arithmetic.
At the risk of being heretical, you might also consider using the BX-
24 which is pin compatible with the Basic Stamp, costs the same or
less, runs faster, has more RAM, more ROM, floating point and an atan
library function.
>Bless you all!
You will probably need a lookup table for this, but the general formula is...
Angle = TAN-1(Y/X)
Angle = ATN(Y/X)
You will still need to monitor the sign of X and Y to determine which
quadrant the angle returned is relevant to.
....Didn't I see something in a fairly recent (smaller size magazine)
'Nuts & Volts' article about an undocumented TAN function for the BSII
that briefly touched this subject?
...I'll try to find it at the house.
-Beau Schwabe
been there all along, but undocumented until recently (See online
help file with STAMPW).
X VAR Word
Y VAR Word
angle VAR Word
magnitude VAR Word
X=100
Y=-100
angle = (X ATN Y) */ 360 ' order of X and Y matters. arctan (Y/X)
' */360 converts from brads to degrees
magnitude = X HYP Y ' the order of X and Y does not matter for HYP
debug ?angle,?magnitude
It helps to understand how the Stamp measures angles, in brads,
units of 1/256 of a circle. Here is more discussion at this URL:
http://www.emesystems.com/BS2math3.htm#ATN_HYP
-- Tracy
>Bless you all!
I appreciate your help^^
Have a nice one!
_____________________________________________________________________
¿¹»Û ÆíÁöÁö¿¡ ¸ÞÀÏÀ» º¸³»¼¼¿ä - ¾ßÈÄ! ¸ÞÀÏ
http://mail.yahoo.co.kr
½ÅÂ÷,Áß°íÂ÷,Á÷°Å·¡ ¸Å¹°ÀÌ ÇÑÀÚ¸®¿¡ - ¾ßÈÄ! ÀÚµ¿Â÷
http://autos.yahoo.co.kr/autos/
Theta = ArcTan ( (X1 - X2) / (Y1 - Y2))
Since this is difficult to do in a Basic Stamp, perhaps you could look
into using a floating point coprecessor. Go the
<http://al_williams.com/> and check out the PAK modules. PAC XII is
very easy to use and includes the ATAN function.
Oh, yes, you also have to know the robot's current bearing. Then you
need to determin how many degrees to rotate in what direction in order
to point the robot to the new position.
Good luck, and keep us informed!
Russ
> Bless you all!
