Electromagnets and the basic stamp — Parallax Forums
edited 2004-03-26 14:52 in General Discussion
Hi - I was wondering if someone could point me in the right direction
regarding very simple (homemade) electromagnets and the bs2. Thanks,
Jordan
    edited 2004-03-26 12:42
    --- In basicstamps@yahoogroups.com, "jordankanarek"
    direction
    > Jordan
    Hi, Jordan.
    Nothing comes to mind specifically regarding both. But any stepper
    motor is nothing more than a series of electromagnets, and there's
    ample reference to steppers and stamps. So if you use that as an
    interface guide, and focus elswhere for the electromagnet specifics,
    you'll have everything (I think) you're looking for.
    Have fun!
    Stephen Weller
    American. Veteran. Patriot.
    edited 2004-03-26 13:05
    A good source of electromagnets for experimenting is to use the coils from
    burnt out relays. The contacts are usually the weak point of relays but the
    coil usually survives. Just hack them up and get the coil and core. They
    are already rated for a specific voltage so you don't need to be concerned
    with that. By the way, they can also function as a detector by passing a
    magnet past them, a voltage will output from the windings that you can use
    to trigger a circuit to use as an input to the stamp. On the output,
    interface them to the stamp via a transistor switch (or another relay) and
    there you go. Interfacing circuits are detailed on the following web site.
    jim
    http://www.geocities.com/jimforkin2003/
    From: wun_fungi [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MALZvOq8uPZHiSXUb5O2CY_aiwLP4mgpsb1hm0Tks0kBCdXsDyqmUZZOlMxgZyhD34ba0JIVwk3zP3279FY3Mj-eYn0]sweller@a...[/url
    Sent: Friday, March 26, 2004 7:43 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Electromagnets and the basic stamp
    direction
    > Jordan
    Hi, Jordan.
    Have fun!
    Stephen Weller
    Yahoo! Groups Links
    Jordan,
    I'm not sure what you are looking for. I have a project that *sort of* uses
    electromagnets and a Stamp. It's a coil gun, and Stamp measures the velocity
    of the projectile. www.madlabs.info Probably not what you want, but there is
    also misc. information on the site about electromagnets. If you can be more
    specific, maybe we can help out.
    Jonathan
    www.madlabs.info
    Sent: Wednesday, March 24, 2004 8:46 PM
    Subject: [noparse][[/noparse]basicstamps] Electromagnets and the basic stamp
    > Jordan
    > Yahoo! Groups Links
