Pass data through BASIC stamps?
I got the idea the other day to try and design a robotic camera
system to track moving targets, and even pick up new targets while
panning. I decided early that the only feasible way to process the
image was to do it on a computer, and send the image data along a
serial port back to the computer. I originally planned to use the
2nd version of the CMU cam, which I could use todump frames along a
serial line at 115.2k baud. The problem is that I wanted the camera
to connect to the computer using only a single serial cable, with a
BASIC stamp as the sole serial connection to the computer. (I want
to expand on this in the future, so the BASIC stamp needs to be able
to receive and send data on the serial port as well, thinking that
the computer would just send the stamp a command, which would tell it
to request a frame from the camera, then send it to the computer.)
The main problem is to send the camera's frame data back to the
computer through the BASIC stamp. I don't have much experience
programming them, so I don't know if there is a command I'm missing
or something. I originally figured that I would just have to somehow
constantly send the data from the input lines from the camera to the
output lines on the serial port. I thought that at first, I could
just store the frame data in the RAM available, but soon discovered
that there is only a handful of bytes of RAM available. Instead, I
thought maybe to store it in ROM, but noticing that the ROM can only
survive 100,000 -1,000,000 writes, worth only a rough 9-90 hours of
lifetime without having to be replaced, at only 5fps, assuming that
the ROM can even be written to that fast.
Has anyone ever used this camera with a BASIC stamp and found a
way to pass the data to the computer efficiently? Sorry if this
seems trivial / pointless, but I am still new to this whole deal.
PC directly. Thus, if you use 2 serial ports,
one can feed the PC from the camera at high speed,
while the other issues commands to the BS2.
(Note you can add USB-to-Serial adapters that
'look' like local PC-ports to the PC).
The BS2 is strictly a single-tasking beast.
While it recieves it can't transmit, and vice-versa.
There ARE several solutions to providing a
separate buffered reciever chip, which then
dumps to the BS2 when it's ready. However,
with the CMU-cam you're talking a LOT of
data, sent often, which means it's a lot
of load on the BS2 (or ANY small processor)
just to relay data. A direct connect to
the PC would be MUCH better.
--- In basicstamps@yahoogroups.com, "gravychicken" <JBMBLB@d...>
camera
able
it
somehow
the
only
need 5 wires -- BS2_TX, BS2_RX, CMU_TX, CMU_RX,
and GND. You could use a single cable to send
both the CMU data AND the BS2 data. You'd have
to wire custom DB-9's at both ends, but you'd
wind up with one cable in the middle.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> I thought the CMU-Cam would interface with the
camera
while
the
the
a
> camera
a
want
> able
that
tell
> it
the
missing
> somehow
> the
could
discovered
I
> only
of
that
a
just not likely to work. Assuming the data from the cam is a nearly
continuous stream while being transmitted, your Stamp will almost
immediately fall behind, lose sync, lose data, etc.
I'd look at a PC-->Stamp command scheme where your Stamp then
controls what the cam does via serial commands to the cam. The Stamp
would also control external switching logic to determine who talks to
the PC serial input--the Stamp or the cam.
Steve
