internet controlled basic stamp?
Hi everyone,
I am looking for a way to create an interface for users to
control the functions of my stamp(2) over the internet. Basically,
I want to set up a web page with a few buttons. When pressed, the
signal from the internet will tell a stamp pin to go high. I've
seen things called Phidgets, they are a little pricey, and you have
to code them in Visual Basic. Maybe something easier to control? I
appriciate any help you may offer.
the stamp and hook it up to a device that can run a webserver, like a
linux system. There was somebody who wrote a pic-based tcp/ip stack, but
he kind of cheated by using SL/IP.
On Tue, 23 Mar 2004, mwweisert wrote:
> Hi everyone,
> Thanks
> Yahoo! Groups Links
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
demo version does enough to help you.
LabView can then talk to your Stamp via the serial port and has what you are
looking to do.
Michael Williams
Tyco Electronics, Hardware Engineering Group
221 Jefferson Ridge Parkway
Lynchburg, Virginia 24501
williammi@t... <mailto:williammi@t...>
I have taken a vow of poverty... to annoy me, please PayPal money to
"michael@f..."
From: mwweisert [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Bb8D7xgoqPuJNHt7uCAi3kxY75ZHAZE4lQBI9B2VwY5Ui9Qv28CRc18tCbLjn2cN7CnYt3OTi80kDI0w]mwweisert@y...[/url
Subject: [noparse][[/noparse]basicstamps] internet controlled basic stamp?
Hi everyone,
http://www.awce.com/netporter.htm
Al Williams
AWC
* New: Simplified floating point math
http://www.awce.com/pak12.htm
From: Williams, Michael [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h3VUGtgneGuI8OTgVYgEGqj4HACHdLHP_R17YAL2Ljg2bZnf5JMIa0J98en8weJWANZ2dK-3us17CVGDTYQh4BXtIw]williammi@t...[/url
Sent: Wednesday, March 24, 2004 7:28 AM
To: 'basicstamps@yahoogroups.com'
Subject: RE: [noparse][[/noparse]basicstamps] internet controlled basic stamp?
LabView has this capability, but is on the pricy side. I'm not sure if the
looking to do.
Michael Williams
"michael@f..."
From: mwweisert [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GvAaBbjZRSZBsmVLd8HHL813nLFRoNESTmPPj5R__Qv9w9OG2KNDz8O62AkF5yJcsQIhX8yDuG_6nGmA]mwweisert@y...[/url
Hi everyone,
Yahoo! Groups Links
I experimented with an Ethernet interface for a microcontroller (a BX-
24) recently using the RealTek RTL8019. I put together a web page
showing what I did, including schematics, at
http://www.kinzers.com/don/BX24/Ethernet
You could do something similar but the limited RAM space of the Basic
Stamp is going to problematic. A UDP packet with a single byte of
payload requires 43 bytes. (You could add external RAM like I did on
my Basic Stamp diesel generator controller, I suppose. See
http://www.kinzers.com/don/GenSet for schematics and code.)
save your money. you can use PERL/CGI
this is an example program to show how easy it is to talk to the
basic stamp through the serial port using perl. for simplicity, i
haven't put validity checks in the program that follows.
to be able to use the com ports in perl, you need:
activeperl for windows (free download here):
http://www.activestate.com/Products/Language_Distributions/
then after you have installed it in windows, go to the command line
and type (you will need to be connected to the internet)
ppm
install win32-API
then download this:
http://members.aol.com/Bbirthisel/SerialPort-0_19.zip
unzip the file, then type:
perl Makefile.PL
perl test.pl
perl install.pl
now you should be able to run the following file by typing:
perl control.pl
# file name: control.pl
# rcobo@e...
# 3/25/2004
# you are free to copy/modify/distribute this program.
# this program talks to the Basic Stamp controller through COM1.
# it sends a character to the BasicStamp and receives a message.
# then the program writes the message to a file named data.txt.
# data.txt will be at the same directory where this program is.
# this program has been tested in windows XP and requires:
# Perl interpreter for windows (free): ActivePerl 5.8.2.808
# Perl Module (free): win32-API
# Perl Module (free): SerialPort-0_19
use Win32::SerialPort;
#**************** COM1 ******************************************
my $port = 'COM1';
my $PortObj = new Win32::SerialPort ($port) || die "Can't open $port:
$^E\n";
#**************** COM1 SETTINGS *********************************
$PortObj->baudrate(9600);
$PortObj->databits(8);
$PortObj->parity("none");
$PortObj->stopbits(1);
$PortObj->write_settings || die "couldn't write settings\n";
#******** SEND CHARACTER THROUGH COM1 ****************************
$PortObj->write("A");
#******** WAIT **************************************************
sleep 1; #if you want to wait n seconds
#******* RECEIVE A MESSAGE *************************************
my $buffersize = 10;
my ($bitesreceived, $message) = $PortObj->read($buffersize);
print( "read $bitesreceived bites\n") unless ($bitesreceived ==
$buffersize);
#******* WRITE FILE *****************************************
open( OUTFILE, ">data.txt") or die( "can't find file data.txt\n" );
print( OUTFILE "$message\n" );
#******* CLOSE COM1 ********************************************
undef $PortObj;
#****** END OF PROGRAM ****************************************
I browsed the .PM code, and I had no idea the
Win32::CommPort API was so clunky. This puts
a nice wrapper around it. Thanks!!
--- In basicstamps@yahoogroups.com, "zauborg" <zauborg@y...> wrote:
> hello,
> ppm
> install win32-API
> then download this:
> perl Makefile.PL
> perl test.pl
> perl install.pl
> perl control.pl
> # rcobo@e...
> # 3/25/2004
> my $port = 'COM1';
$port:
> $^E\n";
settings\n";
> $buffersize);
> undef $PortObj;
