BS1 Problem :''(
The problem could be that you're attempting to run a DOS program on a
Windows machine. Windows is really difficult with programs like our DOS
BS1 editor because we need direct control of the port to bit-bang 4800
baud serial to the BS1. If your version of Windows allows, reboot in
DOS mode before running the editor.
A silly question perhaps, but you do have the programming cable plugged
in correctly, right? Look for the >> marks on the cable and board to
align.
If you are in fact on a Windows machine you can save yourself a lot of
trouble by purchasing our $5 serial interface (allows you to program
from a serial port, and converts DB-9 to the BS1 3-pin connection) along
with our latest version of the Stamp compiler.
http://www.parallax.com/detail.asp?product_id=27111
The best part of the new compiler is that it gives you the memory map
function that used to be available only to the BS2 family.
-- Jon Williams
-- Parallax
From: Hex Shadow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SLtpopo7qXLxYH-WUUdZS9LuQtxl3lxL7JJWhk3j2WgUMC6otdfVktkva9bjKH3UBYGah35DFpjdUliG]hexshadow666@y...[/url
Sent: Tuesday, March 23, 2004 6:01 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: BS1 Problem
the parrallel port, thats my printer port, right?
Adrian Schneider <adrian.schneider@t...> wrote:Isn't the BS1
usually hooked up to the parallel port? There are boards today which
have some additional circuitry to
allow to connect a BS1 to a serial interface, but the standard super
carrier is still using the parallel port (using J3, see schematic at
http://www.parallax.com/dl/docs/prod/schem/supercarrierbd.pdf)
for BS1 as far as I know.
regards
Adrian
align.
-- Jon Williams
-- Parallax
regards
Adrian
