BYTE VAR initialization
When a BYTE VAR is declared does it need to have a value of 0
assigned to it or are VAR's automatically initialized to 0.
Jack
Jack
jlindsay24@y... writes:
> Thanks
All variables are 0 when you boot up. They retain their value as long as
power is maintained on the chip.
Sid Weaver
W4EKQ
Port Richey, FL
then released), ALL variables are cleared to zero and all IO pins are
made inputs. Initializing a variable to zero just consumes code space.
The only acception to this suggestion is that you may need your program
to return to a code-based initialization section that does indeed reset
some variables to zero.
-- Jon Williams
-- Dallas Office
From: Jack Lindsay [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=n-iqFWGbpgFmKguFSZWcyZJgYW5FmjKO6xBdNmjUQppqS6XyPOccwbrhrWk0SyZzdhDyzytKoFuT2HOO6iw]jlindsay24@y...[/url
Sent: Tuesday, March 23, 2004 8:37 AM
Subject: [noparse][[/noparse]basicstamps] BYTE VAR initialization
assigned to it or are VAR's automatically initialized to 0. Thanks Jack
