I2C Communications? — Parallax Forums
I2C Communications?
edited 2004-03-23 18:25 in General Discussion
Any way to make it faster? Can manually bit-banging the ports outrun
an i2cin/i2cout command?
Followup: Is there a non-microprocessor I2C device that can handle an
I2C transfer (read from one device, writing of the read data to
another device) for me?
    edited 2004-03-23 14:36
    The i2cin and i2cout are the fastest way, approx. 82kbit/s I think.
    There is this chip
    http://www.i2cchip.com/bl233_a.pdf
    that you can 'program' with a script using the stamp
    that then runs by itself. It requires a crystal though.
    Since it has isolated i2c buses it may do what you require.
    regards peter
    Sent: Tuesday, March 23, 2004 3:16 PM
    Subject: [noparse][[/noparse]basicstamps] I2C Communications?
    > Yahoo! Groups Links
    edited 2004-03-23 14:54
    If you want faster you should write your own code running on an SX micro
    or something similar. The BS2p does I2C transfers about 81 kBits/second
    -- you're not going to bit-bang any faster than that on a BASIC Stamp
    (SHIFTIN and SHIFTOUT can be used to synthesize I2C routines for
    non-BS2p BASIC Stamps, but only runs about half as fast as I2CIN/I2COUT
    on the BS2p).
    -- Jon Williams
    -- Parallax
    From: jmccorm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7M9botpx7kJVKz1cDJDvj3s7f7QRKqo8Erv8Vc1BN_dQaT8zrcIgi7PbrYMiYKClJuTnyhYv0nbBlH4f]jmccorm@y...[/url
    Sent: Tuesday, March 23, 2004 8:16 AM
    Any way to make it faster? Can manually bit-banging the ports outrun an
    I2C transfer (read from one device, writing of the read data to another
    device) for me?
    edited 2004-03-23 15:48
    > micro or something similar. The BS2p does I2C transfers about 81
    > kBits/second -- you're not going to bit-bang any faster than that
    > on a BASIC Stamp (SHIFTIN and SHIFTOUT can be used to synthesize
    > I2C routines for non-BS2p BASIC Stamps, but only runs about half
    > as fast as I2CIN/I2COUT on the BS2p).
    About bit banging... I may have just had an epiphany. I have to
    transfer data out to 8 I2C devices (MAX 6956s) at the same time. I'm
    running a BS2P40, so I've got IO lines to spare.
    If I try bit banging *eight at a time* (the low 8 lines for data, and
    the high eight lines for clock... although the individual clocks may
    be redundant), then I could get 8x the throughput with just toggling
    OUTL and OUTH with the values. Think I could outrun a SHIFT IN/OUT and
    I2C IN/OUT by toggling OUTL and OUTH to do eight transfers at a time?
    edited 2004-03-23 16:12
    Nope ... not gonna work. Why? Because pure bit-banging as you suggest
    you're going to do is going to use require you to do eight separate
    reads/writes for your data pins, then a write to your common clock pin.
    Where you're going to get killed is in the instruction fetch from the
    EEPROM. Using I2CIN or I2C out can send several bytes with only a
    single instruction fetch -- you can't do that with your manual method.
    Your best bet, as I suggested earlier, is to create your own I2C
    coprocessor that will let you send I2C data at the limits of that spec.
    -- Jon Williams
    -- Dallas Office
    From: jmccorm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Uc9zo8rAToLdXEvnGwD0smJpceg45zxKiBjexlYjJX0DdFfctMRbUgBwGORyJGGISuOtJ10DLRrsnO8]jmccorm@y...[/url
    Sent: Tuesday, March 23, 2004 9:49 AM
    Subject: [noparse][[/noparse]basicstamps] Re: I2C Communications?
    > kBits/second -- you're not going to bit-bang any faster than that on a
    > BASIC Stamp (SHIFTIN and SHIFTOUT can be used to synthesize I2C
    > routines for non-BS2p BASIC Stamps, but only runs about half as fast
    About bit banging... I may have just had an epiphany. I have to transfer
    data out to 8 I2C devices (MAX 6956s) at the same time. I'm running a
    the high eight lines for clock... although the individual clocks may be
    redundant), then I could get 8x the throughput with just toggling OUTL
    and OUTH with the values. Think I could outrun a SHIFT IN/OUT and I2C
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2004-03-23 16:16
    Sorry, there may be some confusion between the BS2sx and the SX micro to
    which I was referring. The SX micro (what we use in most BASIC Stamps)
    is very fast. It has its own set of tools and programming boards.
    http://www.parallax.com/sx/index.asp
    -- Jon Williams
    -- Dallas Office
    From: jmccorm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cYrmP82SwqCnVI5xVuGmewxhIHVM8mj9rxVItaXehVcYO4oYGIfvanSp_R16k2U742zHNoptsETmwA]jmccorm@y...[/url
    Sent: Tuesday, March 23, 2004 10:13 AM
    BTW... a side question. The SX stuff. The website is very unclear about
    all of it (if you know nothing about it). Does it work with the BS2P40
    programming board? Or does it have its own programming boards? Or are
    you on your own there? I realize, of course, it would take some
    different programming software. (Which Parallax appears to provide for
    free.
    edited 2004-03-23 16:18
    > suggest you're going to do is going to use require you to do eight
    > separate reads/writes for your data pins, then a write to your
    > common clock pin. Where you're going to get killed is in the
    > instruction fetch from the EEPROM.
    Any difference if I combine my eight writes and eight reads by simply
    utilizing the INL and OUTL variables to do them all at once, or am I
    still killed in the overhead of doing it manually?
    edited 2004-03-23 16:32
    You are still killed because you have to set each of the bits
    individually and these require instructions that must be fetched from
    the EEPROM.
    You keep insisting that you need more than 81 kbits/second -- how much
    faster do you need to go (and stay within the I2C spec)?
    -- Jon Williams
    -- Dallas Office
    From: jmccorm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3BMSDUOjSKprWvQDgAjwLSDCt0_R75jnSmw1X7VNMr8g7AAweVwm_r1xJkMxFedkXCxfPeOB3oY9nO-N]jmccorm@y...[/url
    Sent: Tuesday, March 23, 2004 10:18 AM
    > separate reads/writes for your data pins, then a write to your common
    > clock pin. Where you're going to get killed is in the instruction
    edited 2004-03-23 17:03
    > how much faster do you need to go (and stay within the I2C spec)?
    Here's what I'm doing...
    I'm reading in 9 bytes of data from a 24FC515 EEPROM.
    I'm writing those same 9 bytes of data to a MAX6956.
    (These two operations will set the intensity/color for 6 RGB LEDs.)
    NOTE: 9 bytes = 6 RGB LEDs * 3 elements per LED * 1 nibble of
    intensity per element
    NOTE: With overhead, that should be 13 bytes for the read, and 12
    bytes for the write, or 25 bytes (200 bits) for the operation.
    I have to do a row across, which will be 8 sets of these operations,
    which will control 48 LEDs. (This is a minimum objective. Really, I'd
    like to do 96 LEDs across, which would be 19 sets of the above
    operation, but I'd consider that highly unrealistic using my current
    methods.)
    NOTE: I realize that the 24FC515 exceeds the throughput capacity of
    the I2C spec, but I wasn't counting on it... that isn't my bottleneck.
    In any case, a row should be 1,600 bits for the operation.
    Now these 48 LEDs... they're flying through the air. Really! And
    they're moving so fast that they leave a trail of color behind them.
    So, what we do is we change the color/intensity of the LEDs as they
    are moving. Instead of a streak of a single color left behind them,
    they can actually paint a picture in the air. (Similar idea: a
    fantazein clock, except, on steroids.)
    NOTE: The "trail of color" behind the LEDs is, of course, a function
    of the human eye, and not so much a trick of physics here. Just for
    anyone who read that and thought I was doing something REALLY crazy.
    So, this row of 48 LEDs needs to change very quickly. I was shooting
    for at least 100 times per second. It needs to change so fast because
    of how long the human eye will hold an image, and the more times a
    second it changes, the faster that I can move it and the more
    resolution I can create along the axis of movement.
    Should be well within a 400kbit/s transfer rate of an I2C bus. (Of
    course, multiple buses could be used, but the bus really isn't the
    bottleneck, from what I see.)
    If you do see a better way of doing this, I'm all ears.
    For your application, the BASIC Stamp may not be the *best* choice.
    You're trying to move a lot of data in a very big hurry -- you might
    want to program this app into an SX micro or PIC micro.
    -- Jon Williams
    -- Parallax
    From: jmccorm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9lRsTQ-oZs-1aAvF246ts-VPn4JPR9ZTdLwybs6JD3XKGk8z4BWOY9qQeRjAf_LeWwiJqKLGfs8]jmccorm@y...[/url
    Sent: Tuesday, March 23, 2004 11:03 AM
    NOTE: 9 bytes = 6 RGB LEDs * 3 elements per LED * 1 nibble of intensity
    per element
    NOTE: With overhead, that should be 13 bytes for the read, and 12 bytes
    methods.)
    NOTE: I realize that the 24FC515 exceeds the throughput capacity of the
    I2C spec, but I wasn't counting on it... that isn't my bottleneck. In
    Now these 48 LEDs... they're flying through the air. Really! And they're
    moving so fast that they leave a trail of color behind them. So, what we
    do is we change the color/intensity of the LEDs as they are moving.
    Instead of a streak of a single color left behind them, they can
    actually paint a picture in the air. (Similar idea: a fantazein clock,
    NOTE: The "trail of color" behind the LEDs is, of course, a function of
    the human eye, and not so much a trick of physics here. Just for anyone
    So, this row of 48 LEDs needs to change very quickly. I was shooting for
    at least 100 times per second. It needs to change so fast because of how
    long the human eye will hold an image, and the more times a second it
    changes, the faster that I can move it and the more resolution I can
    Yahoo! Groups Links
    abuse@p....
