bs2 stepper motor control - motor quivers
i'm using a bs2 and uln2803 to control a stepper motor. i wired the
circuit as the schematic for the motor said
( http://www.parallax.com/dl/docs/prod/motors/27964.pdf ) and ran the
sample code. the motor quivers and will not turn. the write-up said
this is caused by incorrect sequencing, which i did exactly as the
sample code. i have tried other sequences but nothing has working.
if anyone has any advice on what i could be doing wrong or if there
is possibly another problem, i would greatly appreciate it.
adam
adam
the
the
working.
> adam
The 2803 can sink about 500mA. What current is the motor ?
How are you driving the darlington ?
Assuming you have a .5A motor and are running it at the nameplate
voltage, verify the motor leads are correct. ( double that if you
are using two channles to get 1 amp.)
Assuming (again) that you have a 6 wire motor, you have already found
the 3 wires for Phase A by checking the resistance, and then you
conneced your positive to the center tap (lowest resistance) wire ?)
You have connected the power thru a properly sized resistor. 5volts
time 500mA is 2.5 watts, so you used a 2.5 watt resistor or whatever
your calculations would show ?
So, you should have power supply to resistor, to motor coil center
tap on Phase A.
power supply to resistor to coil on phase B
Phase A line 1 and phase A line 2 to the 2803 then to ground.
Ditto phase B.
If you motor prattles but does not spin, double check the resistor
sizing and double check the lead is actually the lowest ohm lead.
The other two will be higher to each other, and the center tap will
be lower to either of those two.
If that all checks out, swap only the 2 wires on Phase A to the
darlington.
That should make things work out.
If the motor spins backwards, then swap all 4 wires to the darlington.
Dave
two manufacturers)? We will be posting an update today that gives the
color sequences for the motors we've provided. Since it's not there
now, I'll give it here:
Motor Mitsumi Howard
Phase 1 Black Brown
Phase 2 Orange Green
Phase 3 Brown Red
Phase 4 Yellow White
Common Red Black
I wrote the documentation that appears on our site now (the version with
the phase sequence graphics) and I have tested with both motors. The
Mitsumi motor is a shaped like a flat gray cylinder, and the Howard
motor is shaped more like a black cube.
-- Jon Williams
-- Dallas Office
From: oabatmsu [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MTAroFFOpJStdCcSzfkcWkLeqnLyRS9oyzucJnP8Ou79XwDg9fU1Li_Q1GI0hFotQCKCtJep1SD6FQ]nankeead@m...[/url
Sent: Monday, March 22, 2004 9:51 PM
Subject: [noparse][[/noparse]basicstamps] bs2 stepper motor control - motor quivers
adam
Adam
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Did you buy the Stepper from Parallax? If yes, which one (we have
had
the
> Phase 1 Black Brown
> Phase 3 Brown Red
> Common Red Black
with
The
> -- Jon Williams
> -- Dallas Office
> From: oabatmsu [noparse][[/noparse]mailto:nankeead@m...]
the
the
working.
> adam
reconnected both motors based on the code chart below and they work
fine. Are you using the latest code sample? The demo code did change a
bit with the document update and that may be causing your problem. You
can get the latest code from our product page for the BS1, the BS2
family, and even for the Javelin Stamp.
http://www.parallax.com/detail.asp?product_id=27964
-- Jon Williams
-- Dallas Office
From: oabatmsu [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AjEfkXjYCbmzNAQWlA-xLW7r3t28hSUGTpcE8vmgVKCw2-EkdjNYZfrHV4zXPCrzADrXwmf6_1TWxqI]nankeead@m...[/url
Sent: Tuesday, March 23, 2004 8:23 AM
Subject: [noparse][[/noparse]basicstamps] Re: bs2 stepper motor control - motor quivers
I'm using the Mitsumi motor and that is the information i went by.
Adam
had
the
> Phase 1 Black Brown
> Phase 3 Brown Red
> Common Red Black
with
The
> -- Jon Williams
> -- Dallas Office
the
the
working.
> adam
and the Stepper ground connected?
wrote:
> With respect, Adam, you're doing something wrong because I just
change a
You
> -- Jon Williams
> -- Dallas Office
> Adam
> had
> the
there
> > Phase 1 Black Brown
> > Phase 3 Brown Red
> > Common Red Black
version
> with
> The
Howard
> > -- Jon Williams
> > -- Dallas Office
> the
> the
> working.
there
> > adam
ULN2x03 need to be connected. The ULN2x03 actually switches each phase
connection to ground to complete the path (common is connected to +12v).
-- Jon Williams
-- Dallas Office
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OpYKyMGFcLfr3vUkz42k7BHIEweSDlNukoGQAFwZEYgmjZ-tdzpBJaR12UHB2ytF_TD7L97Y2p8jpvXeDYs939JwhoY]allan.lane@h...[/url
Sent: Tuesday, March 23, 2004 11:57 AM
It may not be obvious, but is the Stamp ground
change a
You
> -- Jon Williams
> -- Dallas Office
> Adam
> had
> the
there
> > Phase 1 Black Brown
> > Phase 3 Brown Red
> > Common Red Black
version
> with
> The
Howard
> > -- Jon Williams
> > -- Dallas Office
> the
> the
> working.
there
> > adam
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
You'll get a similar response from trying to run the motor too fast. Try
adjusting the delay to something really slow like 1 step every second.
Stick a piece of paper on the shaft with a pencil mark so that you can
easilly see what the motor is doing.
Steve.
Steve Baldwin Electronic Product Design
TLA Microsystems Ltd Microcontroller Specialists
PO Box 15-680, New Lynn http://www.tla.co.nz
Auckland, New Zealand ph +64 9 820-2221
email: steve@t... fax +64 9 820-1929
Your circuit may be OK.
The fault most everyone makes is they try to run a stepper motor too
fast or at speed right away. Either way the motor will quiver like you
state.
What you have to do is build up the speed slowly. Start at a few RPM,
and then ramp up the speed up to 200 RPM. Steppers only run up to about
200 rpm or so for top speed. Modify the program to step the motor real
slow, and then work on speeding it up more gradually, up to 200 rpm.
Depending on the stepper you may get 100 rpm or over 200 rpm for top
speed.
Advanced systems can get speeds upwards of 2,000 RPM or so, but they do
so at the cost of torque. Plus they use creative methods of pulsing or
pulse skipping to getup to that speed.
Anyway, I hope that helps you.
Earl
From: oabatmsu [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T0EEkRm-KeQDAVqp3SbYwQNSYEVh7wyL3dk7YjB1vJdk4KETJP2Sw5NNLuhtWAB7iSMTjQ0fXwFB]nankeead@m...[/url
Adam
had
the
> Phase 1 Black Brown
> Phase 3 Brown Red
> Common Red Black
with
The
> -- Jon Williams
> -- Dallas Office
the
the
working.
> adam
Yahoo! Groups Links
-- Jon Williams
-- Parallax
From: Earl Bollinger [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bMT2G6OZMO193d6LJ0KbjY9uiSTEaChNQHwLq7Tp7_wdIxFyydh2SR-M2zS4bmJwFx5XFKqeUVMu9J8iu4bgr6wzG0g]earlwbollinger@c...[/url
Sent: Tuesday, March 23, 2004 7:03 PM
Subject: RE: [noparse][[/noparse]basicstamps] Re: bs2 stepper motor control - motor quivers
Well in thinking about it.
state. What you have to do is build up the speed slowly. Start at a few
RPM, and then ramp up the speed up to 200 RPM. Steppers only run up to
about 200 rpm or so for top speed. Modify the program to step the motor
real slow, and then work on speeding it up more gradually, up to 200
rpm. Depending on the stepper you may get 100 rpm or over 200 rpm for
top speed. Advanced systems can get speeds upwards of 2,000 RPM or so,
but they do so at the cost of torque. Plus they use creative methods of
pulsing or pulse skipping to getup to that speed. Anyway, I hope that
helps you. Regards, Earl
From: oabatmsu [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AXTKrxSflKEDq4UBqS962iWuf1pVov9rUWyj-ZnM0gl4WJsaBPTTAWYRUFEEkNjpraPeBpxtjQ]nankeead@m...[/url
Adam
had
the
> Phase 1 Black Brown
> Phase 3 Brown Red
> Common Red Black
with
The
> -- Jon Williams
> -- Dallas Office
the
the
working.
> adam
Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
you
> state.
RPM,
about
real
> speed.
they do
> Regards,
> Earl
Good possibility.
Start the motor out at something like 100 hz and ramp up. I think
you may be better talking hertz on the motor as there are 400 steps
per rotation on some motors and 48 on others.
Also, you are dead on that motor torque drops as the inverse of speed
for constant power. At some point, there will not be enough power
to spin itself.
Dave
your help everyone.
wrote:
> Good catch, Earl!
> -- Jon Williams
> -- Parallax
> From: Earl Bollinger [noparse][[/noparse]mailto:earlwbollinger@c...]
quivers
you
few
to
motor
for
so,
methods of
that
> Adam
> had
> the
there
> > Phase 1 Black Brown
> > Phase 3 Brown Red
> > Common Red Black
version
> with
> The
Howard
> > -- Jon Williams
> > -- Dallas Office
> the
> the
> working.
there
> > adam
Subject
> Yahoo! Groups Links
Subject
> Yahoo! Groups Links
> abuse@p...
