using matlab API to send RS232 signals using a bafo usb-to-serial adapor
I do not have a serial port on my laptop so I am using a Bafo
BF-810 serial adaptor (www.bafo.com) to send signals to a
microcontroller (2p40 from parallax). I am using matlab to send the
signals from my PC. Can anyone tell me how to write a Matlab API or
anything else in matlab to enable it communicate with the bafo
serial adaptor. My e-mail address is greenish_green@y...
instruction book for writing to a RS232. If it doesn't work, the
problem is in the adaptor, not the Matlab code.
Dennis
From: Green One [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=E8f9zGPw8MfdsSabusncwfqDhN_QDby1gSWzBkTmNFnixqoKoVAEB2EwCH8PPhhjihlScwf6ZTZLSbaVogMIVkeY]greenish_green@y...[/url
Sent: Monday, March 22, 2004 2:22 PM
Subject: [noparse][[/noparse]basicstamps] using matlab API to send RS232 signals using a
Yahoo! Groups Links
Dennis O'Leary <doleary@e...> wrote:Just follow the directions
*exactly* in the Appendix of the Matlab
Dennis
From: Green One [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ThjRRwSP2qHQGrXnxehKbn30E63clrGgdhM0HFRonBK1E2Febx12YFcebbj65s_2438quTWoz8ptjYl7EOsb]greenish_green@y...[/url
Yahoo! Groups Links
from the same email address that you subscribed. Text in the Subject and Body of
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Finance Tax Center - File online. File on time.
RS232, is the name of the standard behind the term "serial port".
Further, it explains in detail what travels on the 9 to 25 different
pins, some non assigned, others assigned. Most PCs that still wear
serial ports these days have only the basic DB9 connector, that's the
AT configuration. Now where did you get your MATLAB kit from? They
should be able to provide some documentation.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
> From: Hex Shadow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BIDyhBAXpfQBLhhE9qyguIhkKJ2VT1ea8Dj-akkivNV1eZvcgFG-R3sNcugRCdfUA6lY2SgheoOm89U4ey3LyX4]hexshadow666@y...[/url
> Sent: Tuesday, March 23, 2004 1:04 AM
> Subject: RE: [noparse][[/noparse]basicstamps] using matlab API to send RS232 signals
using a bafo
> i dont have a matlab instruction book. and whats a RS232?
directions
> Dennis
> From: Green One [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dtBjbHUef9ZvBZbsEzLGMeE2EF6HNq13wcRvjIGtfSK9yLYEky0-xgahf8QC92CCWXFI_SEL48PIa2yGs54QMD39]greenish_green@y...[/url
a
> Hi,
Your BAFO unit takes a USB signal, and makes
it into Serial. The Serial standard it then uses
is called RS232. In fact, your BAFO adapter
'looks' like a serial (RS232) port to your computer.
Thus, to interface with MATLAB, use the RS2332
interface -- which your BAFO is now pretending to
be.
--- In basicstamps@yahoogroups.com, Hex Shadow <hexshadow666@y...>
> Dennis
> From: Green One [noparse][[/noparse]mailto:greenish_green@y...]
a
> Hi,
> Yahoo! Groups Links
Subject and Body of the message will be ignored.
> Yahoo! Groups Links
> Do you Yahoo!?
work fine. However, in order for me to use matlab to SEND OUT DATA
and RECEIVE DATA through the adaptor and driver I must use API to
make matlab and the driver communicate. I have no clue where to
start in this regards.
greenish_green@y...
--- In basicstamps@yahoogroups.com, "Gregg C Levine"
<hansolofalcon@w...> wrote:
> Hello (again) from Gregg C Levine
different
the
> > From: Hex Shadow [noparse][[/noparse]mailto:hexshadow666@y...]
> using a bafo
> directions
> > Dennis
using
> a
> > Hi,
the
Matlab tech support structure, you should contact contact
www.mathworks.com about this instead of this list.
Dennis
From: Green One [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_YvMW9Mb703xFT0hO0cbpDdNk7sXGpNf3cgBAttLvLygLK-Exidz3GJTLByjxa3uv1mEsvBLqtadzok8KnOQ]greenish_green@y...[/url
Sent: Tuesday, March 23, 2004 10:37 AM
Subject: [noparse][[/noparse]basicstamps] Re: using matlab API to send RS232 signals using
Matlab and the usb to rs232 adaptor (Bafo bf-810) with it drivers
greenish_green@y...
