Power Issue (I think) — Parallax Forums
edited 2004-03-22 14:41 in General Discussion
Hi, I'm pretty new to the BS and electronics stuff.
I've hooked my stamp (HW board) with 2 motor controllers (Quadruple
Half H-Bridge), controlling 3 motors, and i also hooked up a distance
sensors (GP2D12) with a resistor and a capacitor so that I can use
rctime on it.
Then, when I try to power another distance sensor, everything seems
to stop working. The 1st distance sensor gets random result, and the
motors start going slowly.
My guess is that there's not enough voltage for all the components in
the setup. Can anyone propose a solution?
    edited 2004-03-21 19:36
    Be shure you have a seperate powersupply with proper voltage and current for
    your motors.
    John Baker
    http://www.geocities.com/johnsrobotics/
    rctime on it.
    from the same email address that you subscribed. Text in the Subject and Body of
    the message will be ignored.
    Yahoo! Groups Links
    Do you Yahoo!?
    Yahoo! Finance Tax Center - File online. File on time.
    edited 2004-03-21 19:37
    Tell us more. How big are the motors (power consumption)? What kind of
    batteries.
    It isn't a voltage issue as much as a power issue. There are two
    possibilities.
    1) The motors are causing the voltage to droop because they are drawing so
    much current. This causes the Stamp to reset and havoc ensues. Solutions: a)
    Bigger capacity power supply; b) Large capacitor from + to - to smooth out
    transient brown outs (won't work if you are just sucking the batteries dry
    though); c) Separate batteries for motors and electronics (put the ground in
    common).
    2) The motors are shooting noise back into the electronics and causing a
    reset. Solutions: a) Small capacitor across motors; b) Separate batteries;
    c) Other noise filtering (for example, chokes in series with motors).
    Look at the voltage with a voltmeter. A scope is good for noise. Put an LED
    on the Stamp and have it turn on for a second at reset and then back off. If
    that LED starts turning on, you are definitely getting a reset.
    Hope some of that helps.
    Al Williams
    AWC
    * NEW: Our easiest to use math/analog coprocessor ever!
    http://www.awce.com/pak12.htm
    From: rich2kchan [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6xDRDQ67bHwcri4p5JuuO55iy96lrIofoXP0Jq2-riyfUgZxdgkD73bbqOWY6hNU21htWgGuAyCWeg]rich2kchan@y...[/url
    Sent: Sunday, March 21, 2004 1:17 PM
    Subject: [noparse][[/noparse]basicstamps] Power Issue (I think)
    rctime on it.
    Yahoo! Groups Links
    edited 2004-03-21 19:40
    Its not the voltage, its the current that is falling behind.
    Take a look at the datasheets for the things you are using and see how much
    current each one requires. Add it all up and compare that to what your stamp
    is spec'd to supply. If the former is as much or greater than the latter,
    you have power problems.
    It would help if you described your circuit more as well. What are you
    powering the motors from? How about the sensors? Are the motors 12 volt and
    supplied from a wall wart? That sort of thing.
    > From: rich2kchan [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FpbuJE8f0atqHN2wR7jDBrCJMNwOfm3qqeKVFZ8g6nRfNkC39QmHfn0fOjXigtNJ6EZu7DM7HrpDR85W4Fo]rich2kchan@y...[/url
    > Sent: March 21, 2004 11:17 AM
    > rctime on it.
    > Yahoo! Groups Links
    edited 2004-03-21 19:54
    Sorry for not giving enough details.
    The motors have separate power supply (4 AA batteries for 2 of the
    motors -- used for wheels -- and a 9V battery for the 3rd motor --
    for a 12v dc motor)
    The dist. sensor is hooked to the 5v on the board. A 220 ohms
    resistor connect an input on the board and the output of the
    sensor. A .1 capacitor is hooked from that to the gnd of the
    sensor, which is also hooked to the gnd of the board. This is
    actually pretty similar to a setup described in the BS manual for a
    photoresistor. (in the book whats a microcontroller.)
    The setup tried out fine with 1 sensor, and the setup starts getting
    messed up as soon as the other sensor is powered.
    how much
    your stamp
    latter,
    you
    volt and
    > > From: rich2kchan [noparse][[/noparse]mailto:rich2kchan@y...]
    (Quadruple
    distance
    use
    > > rctime on it.
    seems
    and the
    components in
    > > Yahoo! Groups Links
    edited 2004-03-22 03:09
    It looks like the distance sensor typically takes in 33 mA and the
    board outputs 50 mA. So then is there any way I can use 2 distance
    sensors? How can I increase the current or lower the current used?
    --- In basicstamps@yahoogroups.com, "rich2kchan" <rich2kchan@y...>
    > for a 12v dc motor)
    a
    getting
    see
    > how much
    what
    > your stamp
    the
    > latter,
    are
    > you
    12
    > volt and
    > (Quadruple
    > distance
    > use
    > > > rctime on it.
    > seems
    > and the
    > components in
    > > > Yahoo! Groups Links
    edited 2004-03-22 03:49
    It will be very easy to "drive" your sensors without exceeding the stamp 50
    mA max value.
    There are a variety of ways to do this. Some very simple, some still simple
    but require a little more thought.
    Can you provide the part number and manufacturer of the sensors you are using?
    ken
    edited 2004-03-22 04:11
    I used the sharp GP2D12 distance sensors.
    The specs can be found here:
    http://www.junun.org/MarkIII/datasheets/GP2D12_15.pdf
    stamp 50
    > mA max value.
    still simple
    you are using?
    > ken
    distance
    edited 2004-03-22 06:06
    Rich,
    How are you currently powering the sensors? For the sensors, what is the Vcc
    5V pin connected to? Is is connected to one of the I/O pins (P0 ~ P15)?
    The stamp manual specifies the current limit with regard to the I/O pins, but
    does not specifically address the current limits when using pin 21, the
    output of the Stamp on-board 5 volt regulator. It is possible you can run the
    sensors from pin 21, but to be safe.......
    What I would do is the following:
    Get a 7805 voltage regulator with the TO-220 package
    http://cache.national.com/ds/LM/LM341.pdf
    On the input to ground, and the output to ground, connect a 10 to 50 uF
    capacitor and a 0.1 microfarad capacitor.
    Connect the output of the regulator directly to pin 21 (VDD) of the stamp.
    The output of this regulator will now become the power supply for your stamp,
    and for your sensors.
    Write back if this does not make sense.
    Note to Jon Williams.......what is the maximum current output of the Stamp
    on-board regulator? I assume the total 40mA source or 50mA sink from the I/O
    pins is primarily a function of the on-board pic? And if so, how much current is
    left over for the pin 21 output?
    For the moment lets ignore the power dissapation of the on-board regulator.
    You can only lower the current if you change
    the sensors you use -- probably not practical.
    You can easily increase the current available.
    Add a 7805 linear regulator to your project,
    or even better a LM2940 low-dropout regulator.
    These should be good to 1 amp.
    the
    > > for a 12v dc motor)
    > a
    > getting
    > see
    > > how much
    > what
    > > your stamp
    > the
    > > latter,
    > are
    > > you
    > 12
    > > volt and
    > > (Quadruple
    > > distance
    can
    > > use
    > > > > rctime on it.
    > > seems
    > > and the
    > > components in
    > > > > Yahoo! Groups Links
