Tracy type math question
Hi All,
Me and math again. Ugh. I am using a 7.5 degree stepper motor, which has 48
steps per revolution. I am working on a turret style ultrasonic range
detector. What I want to do is figure out which direction (clockwise or
counter-clockwise) is the fastest direction to travel between point A and
point B. As an example, assume 12 o'clock is positon 0. If am at position
27, and I want to go to position 47, I obviously want to go clockwise to get
to the desired position in the least number of steps. I know there is a
tricky math solution to this, I'm just not smart enough to see it [noparse]:([/noparse]
Thanks!
Jonathan
www.madlabs.info
Thanks!
Jonathan
www.madlabs.info
Maybe the following code will work for you:
if actual_position < total_of_steps/2 then turn_anticlockwise else
turn_clockwise
Let me know the results.
Regard,
Klaus
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@p...> wrote:
> Hi All,
which has 48
range
(clockwise or
A and
position
clockwise to get
is a
> Thanks!
> Jonathan
> www.madlabs.info
if( 48 - A ) / 2 < 24 go CW
else go CCW
Dennis
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AiclX4mB4c0gLmunNh_N62JmfWxueif1mf2ADhnVUxW3fkDYkh3Ss_iHDJwzvC8paUd7m46rV7XpoC1L]jpeakall@p...[/url
Sent: Saturday, March 20, 2004 2:53 PM
Subject: [noparse][[/noparse]basicstamps] Tracy type math question
Hi All,
48 steps per revolution. I am working on a turret style ultrasonic range
and point B. As an example, assume 12 o'clock is positon 0. If am at
position 27, and I want to go to position 47, I obviously want to go
clockwise to get to the desired position in the least number of steps. I
know there is a tricky math solution to this, I'm just not smart enough
Thanks!
Jonathan
www.madlabs.info
Assume A is current position.
if( 48 - A ) < 24 go CW
else go CCW
Dennis
From: Dennis O'Leary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OSNFAaVnJrqGRrihPx8E00yH1EQ0uI6a9K6vSgDmNXHCPCsv-AMc9a6unGfjmC3TxknW0V7Xh9o]doleary@u...[/url
Sent: Saturday, March 20, 2004 4:19 PM
Subject: RE: [noparse][[/noparse]basicstamps] Tracy type math question
else go CCW
Dennis
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=alSwHatm7JVCDTa1Di_5qYtjnsrlJOUHxqQAxkjO2uI0NL6D_lxaWykgf0CDx2sUzC6R_K1RNLMFwVLP7A]jpeakall@p...[/url
Hi All,
Thanks!
Jonathan
www.madlabs.info
Yahoo! Groups Links
Assume A is current position. To go to B:
if( B - A ) < 24 go CW
else go CCW
Dennis
From: Dennis O'Leary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pGx4CPNGIKBVAxWG-rSHYzPrfbXbnps-ogVDfMAaDagXvkNf-Qkm2UA8T1_FYF_yGGKTbnVk]doleary@u...[/url
else go CCW
Dennis
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_N-qWMBpB25w56Ku0SWGk1rGCJNXGxwQrLQt8biHSinzOrWDVx-eO5oDt0Gb0gJakxNl8_MpPdJYvuA]jpeakall@p...[/url
Hi All,
Thanks!
Jonathan
www.madlabs.info
Yahoo! Groups Links
Depressing that everyone else gets the answer so easy! Why am I left in the
dark ;-)
Thanks for the help, should work great! I'll try it out to-morrow.
Jonathan
www.madlabs.info
Sent: Saturday, March 20, 2004 4:41 PM
> Yikes! This is my last attempt:
> else go CCW
> Dennis
> From: Dennis O'Leary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PkegZIpnJeULNAOtZ4kkQpexMuieqjD6vuf7EOeal51EKdWq4KkGkpxo8cp6luePFsiciave_NY]doleary@u...[/url
> else go CCW
> Dennis
> From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6uhqhHasH69FZxq_oW7svxRcoduP4cMIwTPUfHIkUMLqIm5pIsECnEQfT23yRBEEE-P3leTnoJBBtrZapA]jpeakall@p...[/url
> Hi All,
> Thanks!
> Jonathan
> www.madlabs.info
> Yahoo! Groups Links
> Yahoo! Groups Links
> Denis, Klaus,
left in the
> dark ;-)
> Jonathan
Seems that this would not work when one is at pos 7 and wants to go
to pos 47.
( 47 - 7 ) = 40
40 < 24 = false = go CC
compare a different 8 step seperation
17 - 25 = -8
Am I correct on this ? or am I missing somethng ?
Dave
Drat! You are correct. Any ideas how to do this?
Jonathan
www.madlabs.info
Sent: Sunday, March 21, 2004 8:15 AM
Subject: [noparse][[/noparse]basicstamps] Re: Tracy type math question
> > Denis, Klaus,
> left in the
> > dark ;-)
> > Jonathan
> to pos 47.
> ( 47 - 7 ) = 40
> 17 - 25 = -8
> Dave
> Yahoo! Groups Links
correct solution for all cases is to use 2 conditional tests instead of
one to keep results positive.
Let A = current position.
Let B = next position.
if A > B
if (A-B) < 24 go CCW
else go CW
else
if (B-A) < 24 go CW
else go CCW
Dennis
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XjUiByUVhmT82ZGKnZ6AqLEQJRdS4cjzcaHIY9ohDU9l8AzGb4T7rlflpb_-z7LdFr6oQ4XkZ5ivtXs]davemucha@j...[/url
Sent: Sunday, March 21, 2004 8:16 AM
> Denis, Klaus,
left in the
> dark ;-)
> Jonathan
to pos 47.
( 47 - 7 ) = 40
17 - 25 = -8
Dave
Yahoo! Groups Links
Your magic number is 24
NP = New Position
CP = Current Position
THEN
If NP = CP then DO_NOTHING
If NP > CP then State1
goto State3 'Because NP < CP
State1: If NP < CP+24 Then State2 ' less than 24 step away CCW
Clockwise 'Else CW
GOTO DO_NOTHING
State2: Counter Clockwise
: GOTO DO_NOTHING
State3: If 100 + CP < 124 + NP Then State4 ' CP < NP +24 means NP is
' closest CCW NOTE: 100
' arbitrary number to avoid
' negative numbers
Clockwise ' Else closest CW
goto DO_NOTHING
State4: COunter Clockwise
goto DO_NOTHING
DO_NOTHING: ' Continue
How's this look?
CAT
--- In basicstamps@yahoogroups.com, "Jonathan Peakall" <jpeakall@p...>
wrote:
> Hi All,
has 48
range
(clockwise or
A and
position
clockwise to get
is a
> Thanks!
> Jonathan
> www.madlabs.info
correct, but the State3 test is over complicated. I originally did a
subtraction and switch things to do an addition so the 100 shift is
no longer necessary.
NP = New Position
> THEN
> Clockwise 'Else CW
> GOTO DO_NOTHING
State3: If CP < 24 + NP Then State2
Clockwise 'Else CW
> GOTO DO_NOTHING
> : GOTO DO_NOTHING
--- In basicstamps@yahoogroups.com, "catgirldo" <catgirldo@y...> wrote:
> I THINK you need a double check on each side of the equation.
> NP = New Position
> THEN
> Clockwise 'Else CW
> GOTO DO_NOTHING
> : GOTO DO_NOTHING
> ' negative numbers
> goto DO_NOTHING
> goto DO_NOTHING
> How's this look?
> CAT
> wrote:
> > Hi All,
> has 48
> range
> (clockwise or
> A and
> position
> clockwise to get
> is a
> > Thanks!
> > Jonathan
> > www.madlabs.info
Thanks a ton for all the help! I will try both methods posted tonight, and
see how it goes. Sitting here doing it on paper it looks good. Mind you, me
saying a math equation looks good means very, very little ;-)
Thanks to all!
Jonathan
www.madlabs.info
Sent: Monday, March 22, 2004 1:14 AM
> Darned! Never program late at night. I think the statements ARE
> NP = New Position
> > THEN
> > Clockwise 'Else CW
> > GOTO DO_NOTHING
> Clockwise 'Else CW
> > GOTO DO_NOTHING
> > : GOTO DO_NOTHING
> > NP = New Position
> > THEN
> > Clockwise 'Else CW
> > GOTO DO_NOTHING
> > : GOTO DO_NOTHING
> > ' negative numbers
> > goto DO_NOTHING
> > goto DO_NOTHING
> > How's this look?
> > CAT
> > wrote:
> > > Hi All,
> > has 48
> > range
> > (clockwise or
> > A and
> > position
> > clockwise to get
> > is a
> > > Thanks!
> > > Jonathan
> > > www.madlabs.info
> Yahoo! Groups Links
Delayed response due to weekend camping! Since I'm typecast in the
question (hehe), here is a little program for edification. It runs
through all the combinations of the 48 start and finish angles, and
shows which way to rotate and by how much. Since this is a problem
involving a circle, you can expect to find the Stamp's // operator.
'{$STAMP BS2pe}
'{$PBASIC 2.5}
' rotation planner, circle with 48 steps
' tracy@e...
a VAR Word ' starting step 0--47
b VAR Word ' move to step 0--47 by shortest angle
x VAR Word ' +/- 24 steps
FOR a=0 TO 47
FOR b=0 TO 47
DEBUG CR,"a:",DEC a,TAB,"b:",DEC b,TAB
SELECT b-a+48//48
CASE 0
DEBUG "stay"
CASE <24
DEBUG "cw"
CASE >=24
DEBUG "ccw"
ENDSELECT
x=b-a+72//48-24
DEBUG TAB,SDEC x ' this many steps
NEXT
NEXT
In the SELECT statement, it is (b-a+48//48) that does the work.
Adding 48 to the difference of the angles is needed, because the //
operator does not calculate well with negative numbers. In general,
(b-a) could land anywhere between -47 and +47. Adding 48 assures
that the result is positive, from 1 to 95. The // operator then puts
that back into a 48 unit circle. Values of (b-a) from -47 to -25 and
from 1 to 23 merit a cw rotation, while values of (b-a) from -24 to
-1 and from 24 to 47 merit a ccw rotation. The value 24 is really a
tossup, as it is the same number of steps to go either cw or ccw, but
I arbitrarily put it with ccw.
The formula x=b-a+72//48-24 tells the whole story. It gives the
number of steps, with + for cw and - for ccw and of course zero for
"already there".
-- Tracy
>Hi All,
>Thanks!
>Jonathan
>www.madlabs.info
Does it hurt being that smart ;-)?
Thanks a ton. Your solution is slick. A student and I came up with another
method using the ABS function, but yours calcualtes the number of steps as
well, which is nice. Goes to show there are a number (pun intended) of ways
to skin this cat. Funny, as it seems on the surface a pretty easy problem.
Thanks again! And to all that replied.
Jonathan
www.madlabs.info
PS Hope you had fun camping. It's that time of year!
Sent: Tuesday, March 23, 2004 9:09 PM
Subject: Re: [noparse][[/noparse]basicstamps] Tracy type math question
> Hi Jonathan,
> '{$STAMP BS2pe}
> '{$PBASIC 2.5}
> ' tracy@e...
> FOR a=0 TO 47
> FOR b=0 TO 47
> SELECT b-a+48//48
> CASE 0
> DEBUG "stay"
> CASE <24
> DEBUG "cw"
> CASE >=24
> DEBUG "ccw"
> ENDSELECT
> x=b-a+72//48-24
> NEXT
> NEXT
> "already there".
> -- Tracy
> >Hi All,
48
get
> >Thanks!
> >Jonathan
> >www.madlabs.info
> Yahoo! Groups Links
