Aristides: Protection for servo motors using Home Work Board-Breadboard
Thanks Aristides
but I soldered the diode to the
red cable of the servo and
it worked erratic.
Thanks in advance: Joe
--- Aristides Alvarez <aristidesparallax@y...>
wrote:
> Hello Joe.
> > I damaged two servo motors easily,
> > using the Home Work Board-Breadboard.
> > When I connected the 6 volts power
> > supply they burned.
> > My mistake was that I reversed the polarity
> > for less than one second
> > (I know,I know it was my mistake)
> With the BOE you don't have this problem because you
> connect the servos to
> the servo port, making it almost impossible to make
> a bad connection (I said
> almost because you can still reverse connect the
> servo, but this won't
> destroy it).
> With the HomeWork Board you have to make your own
> wiring, leaving the door
> open to reverse polarity and other wiring mistakes.
> The circuit inside the servos is using polarized
> capacitors.
> You cannot provide effective external protection to
> avoid reversed polarity
> connection to the servo.
> The diode should be added inside the servo case to
> avoid destroying the
> capacitors.
> As you noticed, capacitors get destroyed almost
> instantly when reversing
> polarity.
> The only solution is double and triple checking your
> wiring before applying
> power to the board.
> Saludos,
> Aristides Alvarez
> International Education Program Developer
> aalvarez@p...
> Parallax, Inc. www.parallax.com
> USA
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! Mail - More reliable, more storage, less spam
http://mail.yahoo.com
it worked erratic.
wrote:
> Hello Joe.
> > supply they burned.
> destroy it).
> capacitors.
> capacitors.
> polarity.
> power to the board.
> Saludos,
> Aristides Alvarez
> aalvarez@p...
> USA
> ignored.
> Yahoo! Groups Links
Do you Yahoo!?
