SV: [basicstamps] high voltage
I've worked with electic fences on my uncle's farm, and switching off
the input voltage is NOT a good solution, particularly if the unit
supplies several sections of fence...
(We don't want cattle running wild, do we)
Worst case?
Just mount a small DC motor that lifts a latch using a 'non-conductive'
actuator.
(Plastic rods or something)
Hook red and green flags onto it and you also have a visible
'safe'/'Danger' signal out in the field...
Trygve
Opprinnelig melding
Fra: Grover Richardson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lq7M7YjuH5JBwrs561B3p5mz0KJAYewwGJw3IW_geSdR2FpsaXphwO2Nv0j3_OEmyb2nyah8X30MuMtYPQ_KoxSz__IzpWj1k2Q]grover.richardson@g...[/url
Sendt: 19. mars 2004 15:10
Til: basicstamps@yahoogroups.com
Emne: RE: [noparse][[/noparse]basicstamps] high voltage
There are several fellas that appear at hamfests that sell used ones.
Generally controlled by 28 VDC. The Kennehoochie Hamfest is Saturday.
I will get the fella's name.
It would be easier to use a relay to control the 110 VAC into the
electric fence charger.
From: Rene Genest [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pPcWKn69m_OIi295nWEMjZfkA838FQdHbRtskb9RcXyo13B_Sl6q59rslq9sniLnZg1EbYkqtLFXQY2Jywkn0Vg]rene.genest@q...[/url
Sent: Thursday, March 18, 2004 3:48 PM
To: stamp
Subject: [noparse][[/noparse]basicstamps] high voltage
Hi group!
I need to control, with my BS2, a high voltage electric fence as you
have on farms to keep animals to cross fields, anyone know where I can
find high voltage relays ( 10,000 volts).
Rene
Yahoo! Groups Links
Yahoo! Groups Links
Worst case?
actuator.
Trygve
Opprinnelig melding
To: stamp
Hi group!
Rene
Yahoo! Groups Links
Yahoo! Groups Links
