differential amplifier
Hello;
I would appreciate any resources or circuit information anyone might have for
building a differential amplifier to transform a ~1.5 mV differential into
something
usable for reading through an ADC connected to my stamp (i.e. amplifying the
signal
from ~1.5mV to roughly 5V).
Thanks in advance,
Hans
something
signal
Thanks in advance,
Hans
--- hrs_mtl <hans@a...> wrote:
> Hello;
> have for
> into something
> amplifying the signal
> Thanks in advance,
> Hans
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! Mail - More reliable, more storage, less spam
http://mail.yahoo.com
Most op-amp spec sheets have a typical operating circuit. I'm no good at
ascii art, so I won't try, but the circuit is very simple. If you search
around on the web you will find many sites with op-amp circuits and
information. A single rail type is probably best for your application, like
an LM324. Microchip makes some single rail op-amps, and I have been playing
with their programmable gain amps, for which you can set the gain with your
Stamp if you need different levels of amplification.
HTH,
Jonathan
www.madlabs.info << Home of the hydrogen powered robot!
Sent: Thursday, March 18, 2004 8:56 PM
Subject: [noparse][[/noparse]basicstamps] differential amplifier
> Hello;
for
something
the signal
> Thanks in advance,
> Hans
> Yahoo! Groups Links
to about 3.5v (positive rail) with a 5 volt supply. Forget what the negative
rail limit is - though I seem to remember 0.5 volts or something.
When looking for an opamp - check for rail to rail single supply types. That
means that with 0 and 5v supplied to it, it can actually output 0-5v.
Another tip - with those kinda of gains, make SURE you use caps on all your
chip supplies. Also put a cap between the +5 and 0 volt supply of the opamp
itself. A tiny bit of noise that would normally not be noticable on a
non-amplified output will be humungous after its amplified 2500 times. If
you don't have access to an oscilloscope, this could be a tough one to get
stable.
> From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6jAZJ65HUsV0dSuSYZtcY7J1JhAfpZIbuXEcDykaSTE-48XVCFUkf35nRjOxN_nLsF8j8x6DZkcJmznrKs4X]jpeakall@p...[/url
> Sent: March 19, 2004 7:30 AM
> Subject: Re: [noparse][[/noparse]basicstamps] differential amplifier
> Hans,
> application, like
> been playing
> with your
> HTH,
> Jonathan
> From: "hrs_mtl" <hans@a...>
> > Hello;
> might have
> for
> differential into
> something
> the signal
> > Thanks in advance,
> > Hans
> Subject and
> > Yahoo! Groups Links
> Yahoo! Groups Links
