Connect a BS2SX to I2C
Hello,
Is there a hardware way or code available that allows me to connect the
BS2SX to
I2C devices and or one wire devices?
Scott
_________________________________________________________________
MSN Premium: Up to 11 personalized e-mail addresses and 2 months FREE*
http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://\
hotmail.com/enca&HL=Market_MSNIS_Taglines
BS2SX to
Scott
http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv85.pdf
-- Jon Williams
-- Dallas Office
From: Scott Skinner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iRcgv3PyRtcrdN1kICQc3GBdglVuOS8Lm-AIjlxICMxWWYWIGO3fnlrlolPAh68cMMU54trSaILuNGtKSi-WvmI]scottdskinner@h...[/url
Sent: Thursday, March 18, 2004 7:49 PM
Subject: [noparse][[/noparse]basicstamps] Connect a BS2SX to I2C
Hello,
BS2SX to
Scott
Good luck with the 1-Wire devices! The only thing I've found is a
file called "Working with 1-Wire", which states that you need to buy a
Surface Mound Device and solder it to a carrier board, a process not
for the feint-of-heart (or less than agile fingers)!
I hope a solution comes forth, as I am faced with the same problem!
The rumor mill has it that Parallax might someday provide something to
help us.
Russ
--- In basicstamps@yahoogroups.com, "Scott Skinner"
<scottdskinner@h...> wrote:
> Hello,
> BS2SX to
> Scott
FREE*
> help us.
If someone comes up with a surface mount to DIP converter that doesn't
require soldering (like it is ZIF or locks into place somehow), I'll
BUY BUY BUY. I've run into I2C chips that I can't work with because of
the size, but otherwise would very much want to... like those OSD
(on-screen display) chips for overlaying text over video (This has
also been a problem of mine with non-BASIC stamp projects.)
BTW, does anyone know much about those OSD I2C chips?
PS: That's something Parallax should work with. Who wants a robot with
a wireless video camera and vital parameters overlaid on the video? [noparse]:)[/noparse]
mind. However they are all big ticket items -- not inexpensive enough for
general use. They are mostly used in one of a kind test fixtures.
That being said, I have found I can handle surface mount pretty well and
there are plenty of cheap solder-style PC boards available now days. In
fact, we've considered making some on the edges of our existing PC boards.
Al Williams
AWC
*NEW: Our easiest to use math/analog coprocessor ever!
http://www.awce.com/pak12.htm
From: jmccorm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VoBFfewiLSq07vNGFyt_dfBDCRf6MwUPe74HRIACDwFbERXw4iF7A-pJF6IuCdUgEQkMSPY1sw]jmccorm@y...[/url
Sent: Sunday, March 21, 2004 1:37 PM
Subject: [noparse][[/noparse]basicstamps] Re: Connect a BS2SX to I2C
> help us.
require soldering (like it is ZIF or locks into place somehow), I'll BUY BUY
BUY. I've run into I2C chips that I can't work with because of the size, but
otherwise would very much want to... like those OSD (on-screen display)
chips for overlaying text over video (This has also been a problem of mine
PS: That's something Parallax should work with. Who wants a robot with a
Yahoo! Groups Links
