basic serial question
Hi, I'm a Stamp beginner - I have a BS2p24 that I've been using
for about a month.
My understanding is that the DEBUG terminal is some PC software
which opens a serial port session between itself & the BS2.
Can the SERIN command be used for receiving data from other
programs other than the default DEBUG terminal ?
Can the BS2 resume it's default serial communication with the
DEBUG terminal after this terminal has been closed in order for
another program to send serial data to the BS2 ?
The greater picture is that : I'm trying to send a number via the
serial port to the BS2 using LabView. The program just sits. I'm
guessing the SERIN command (which I had intended on grabbing the
LabView number & calling it a variable) does not work. In order for
LabView to send data, I need to close the DEBUG terminal to allow
access to my serial port. LabView sends the number & then closes the
port.
Here is the code :
'{$STAMP BS2p}
testvar VAR BYTE
SERIN 16, 240, [noparse][[/noparse]DEC testvar]
PAUSE 10000
DEBUG "This is it ",DEC testvar
Any suggestions would be appreciated. I prefer LabView, but if this
is a dead end, how else could such PC to BS2 data transfer be made ?
Arie
for about a month.
port.
Here is the code :
'{$STAMP BS2p}
testvar VAR BYTE
PAUSE 10000
Arie
>for about a month.
>port.
>Here is the code :
>'{$STAMP BS2p}
>testvar VAR BYTE
>PAUSE 10000
>Regards,
> Arie
Use any pin-port other than pin-port 16 for your SERIN.
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
is open all the time. The problem is on the PC side. If you have a
DEBUG window open, then it has control of the serial port and will hold
that until the window is closed; if Labview has the port open it will
maintain control (hence no DEBUG output) until it releases control.
You have two options: do all of your serial IO through one program or
the other, or connect a second serial port (like our RS-232 AppMod) to
get data from Labview.
-- Jon Williams
-- Dallas Office
From: Arie [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=B98AjqlIWyDVBj8m9xNSG49RwKmS7v5rJAbv3Txb6TVrEU62lrthL2CM2Fir35-jxDvHDXd06gdxgKhxSWynRg]allsport572000@y...[/url
Sent: Thursday, March 18, 2004 7:39 PM
Subject: [noparse][[/noparse]basicstamps] basic serial question
for about a month.
port.
Here is the code :
'{$STAMP BS2p}
testvar VAR BYTE
PAUSE 10000
Arie
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
