high voltage
Hi group!
I need to control, with my BS2, a high voltage electric fence as you
have on farms
to keep animals to cross fields, anyone know where I can find high
voltage relays
( 10,000 volts).
Rene
have on farms
voltage relays
( 10,000 volts).
Rene
Generally controlled by 28 VDC. The Kennehoochie Hamfest is Saturday. I
will get the fella's name.
It would be easier to use a relay to control the 110 VAC into the electric
fence charger.
From: Rene Genest [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qJAdOrUXfRFti52Kh-GInDGLaJ3pAXTjkTMGo6OnKa0GBNOxMMFBB8GxgdPcPD2AMcPYWXQaLKprjXtJRHYDc-As]rene.genest@q...[/url
Sent: Thursday, March 18, 2004 3:48 PM
To: stamp
Subject: [noparse][[/noparse]basicstamps] high voltage
Hi group!
I need to control, with my BS2, a high voltage electric fence as you have on
farms to keep animals to cross fields, anyone know where I can find high
voltage relays ( 10,000 volts).
Rene
Yahoo! Groups Links
It is possible to use an open frame relay and epoxy a fiberglass rod to it
(with high Voltage wire attached to the end) to get the same effect. The
fiberglass rod would give the Voltage stand off required. Ugly as home made
sin, but functional<G>.
From: Trygve Henriksen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GSZXbCKzBHpfZRfRV2a0T0L5j3pPg-5-afpfajzYzK7enfARrpFUotdXVNXRKyIm9eh66HUI3ZOpjor8mZj8ubJrI5ALpN8]trygve.henriksen@v...[/url
Sent: Friday, March 19, 2004 9:28 AM
Subject: SV: [noparse][[/noparse]basicstamps] high voltage
I've worked with electic fences on my uncle's farm, and switching off the
input voltage is NOT a good solution, particularly if the unit supplies
several sections of fence... (We don't want cattle running wild, do we)
Worst case?
Just mount a small DC motor that lifts a latch using a 'non-conductive'
actuator. (Plastic rods or something)
Hook red and green flags onto it and you also have a visible 'safe'/'Danger'
signal out in the field...
Trygve
Opprinnelig melding
Fra: Grover Richardson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oNoDq0nSHyKvtd_TPv9Aco1lMklk4uaNwUJ5kZq5QwkouTooZSQkulybtyA83jmLf41wgbG4CQnSzRgZBC42RnVjLXPMRmiW5O8]grover.richardson@g...[/url
Sendt: 19. mars 2004 15:10
Til: basicstamps@yahoogroups.com
Emne: RE: [noparse][[/noparse]basicstamps] high voltage
There are several fellas that appear at hamfests that sell used ones.
fence charger.
From: Rene Genest [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=j48P_JNfTWWju9XCIzfNsIO1kzBwe4dw2gmQTCkCggsrCnq0uD0rRKFADKAMLnPz_WfR2BdFxNNajhiNJg]rene.genest@q...[/url
To: stamp
Hi group!
Rene
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
