DS1307 RTC and Supercap - SERIAL CONNECTIONS ???
--- In basicstamps@yahoogroups.com, "erniem1957" <ernie@c...> wrote:
> I'm attempting to add on a DS1307 RTC (real time clock) with a
> supercap power backup.
> Seems the cap isn't charging from the pin as I expected it would,
> that some other means of keeping the charge must be supplied.
> Does anyone know of an app note for doing this? Thanks.
Hi all,
I was thiking of how to best utilize a RTC.
In reading the data sheets, it seems that pins 1,2,3 and 4 of the BS2
are Tx, Rx, ATN and Gnd. Also listed as SOUT and SIN for 1 and 2.
Are there preferred pins to use ?
I'm thinking of the best way to add a clock and not use additonal
pins if I can get away with not having to.
Dave
Hi all,
Dave
SPI interface. The BS2 commands 'SHIFTIN' and
'SHIFTOUT' support this interface. Typically,
you need a Data line, and a Clock line, and
also a ChipSelect line.
You CAN get away with keeping the chip
ALWAYS selected, if you then use the 'Clock'
line to also 'select' the chip. Thus you need
2 or 3 pins to talk to the 1307, using the
SPI code. Check out the 1302.bs2 demo on
the Files section of the Group site.
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...>
> Hi all,
BS2
> Dave
wrote:
> The 1302 (and I assume the 1307) utilize the
I guess I was hoping for method of using less pins, and maybe more
dedicated pins for the serial comm.
Dave
would,
> > Hi all,
> BS2
> > Dave
SEROUT) with an external device (these pins are the BASIC Stamp's
programming port). When using them, you specify pin 16. These pins are
also used by DEBUG and DEBUGIN, but are otherwise unavailable for
general program use.
If you use an I2C clock like the DS1307, you're only using two pins and
these can be shared with other devices. One of my favorite devices is
the MCP23016 IO expander from Microchip. For those of you that read
Nuts & Volts, watch for my May column where I use the MCP23016 (costs a
couple bucks) to make a very inexpensive LCD terminal.
-- Jon Williams
-- Dallas Office
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1IBp-XDjKy28fCyEnPHZVdob_1RygojTieGtchAp1x72fTrDjZeg8Q19fYgEQ3r6jKP3ixMDLtFbdvA]davemucha@j...[/url
Sent: Thursday, March 18, 2004 8:49 AM
Subject: [noparse][[/noparse]basicstamps] Re: DS1307 RTC and Supercap - SERIAL CONNECTIONS
Hi all,
Dave
point, you could keep the DS1302 selected all the time, but this would
prevent sharing the line. I'd go with the DS1307 -- even for non
BS2p/BS2pe BASIC Stamps. I2C is easy to bit-bang with the BS2, BS2e,
and BS2sx.
-- Jon Williams
-- Dallas Office
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hUhufK1uBMhbcbQerhiZzY7Nb3ou2ywIShLIAampah9JieBN3itIqxTURTTFAEgt8BC3tO3ZjDWB70r8SHGCoc39]allan.lane@h...[/url
Sent: Thursday, March 18, 2004 9:14 AM
> Hi all,
BS2
> Dave
