Another robot servo question
I am working on a homebrew Boe-bot. I am using the BASIC Stamp 1
Project Board (#27112). I have the servo (just one so far) connected
via the breadboard to a header with power from an external 4x1.5v
pack (6v total) and the control line jumpered over from P0. The
Project Board is powered by 9v transistor--compiles and downloads
fine. I have modified a Hitec HS-311 for continuous rotation. And
just to check if I have a servo problem I also tested with a Futaba
S3003. Test code below was taken from the Parallax Continuous
Rotation Servo data sheet.
'{$STAMP BS1}
'{$PBASIC 1.0}
SYMBOL temp = W0
FOR temp = 0 TO 200
PULSOUT 0,150
PAUSE 20
NEXT
FOR temp = 0 TO 200
PULSOUT 0,180
PAUSE 20
NEXT
FOR temp = 0 TO 200
PULSOUT 0,120
PAUSE 20
NEXT
END
As I understand it, the above code is supposed to first center the
servo, then turn it one direction, then the other (by adjusting
offsets from nominal and centered 1.5mS pulses). The problem is that
with either the Hitec or Futaba servo I only get rotation in one
direction. I have played with the cycle times (PAUSE 20) and pulse
width. When the cycle times are way out I get lurching of the servo.
Short cycle times don't seem to matter much. Long pulse durations
give me a "grinding" slow turning motion and again, very short
pulses don't seem to matter much. Again though, ALL ROTATION IS IN
THE SAME DIRECTION.
Thoughts? What am I doing wrong?
-Tim
'{$STAMP BS1}
'{$PBASIC 1.0}
SYMBOL temp = W0
FOR temp = 0 TO 200
PULSOUT 0,150
PAUSE 20
NEXT
FOR temp = 0 TO 200
PULSOUT 0,180
PAUSE 20
NEXT
FOR temp = 0 TO 200
PULSOUT 0,120
PAUSE 20
NEXT
END
THE SAME DIRECTION.
-Tim
values should be between 100 (full CW) to 200 (full CCW). Be sure to
initialize your servo control output low first, and use a rig a 6v power
supply for your board so that you don't kill the servo (it will work at
9v ... but not for very long).
Here's code right out of my editor that ran and did what you want yours
to do:
' {$STAMP BS1}
' {$PBASIC 1.0}
SYMBOL Servo = 0
SYMBOL temp = B2
Setup:
LOW Servo
Main:
' center (stop)
FOR temp = 0 TO 200
PULSOUT Servo, 150
PAUSE 20
NEXT
' cw
FOR temp = 0 TO 200
PULSOUT Servo, 100
PAUSE 20
NEXT
' ccw
FOR temp = 0 TO 200
PULSOUT Servo, 200
PAUSE 20
NEXT
GOTO Main
-- Jon Williams
-- Dallas Office
From: dixontj93060 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tSw7iFrvqHm9VHrQXHrp0tiFrq1cIFD5ABwNDJxS2Sd6ZKQgZVd_glx_2iI2ESjf6UminYAdb30]t_n_t@v...[/url
Sent: Tuesday, March 16, 2004 8:44 AM
Subject: [noparse][[/noparse]basicstamps] Another robot servo question
'{$STAMP BS1}
'{$PBASIC 1.0}
SYMBOL temp = W0
FOR temp = 0 TO 200
PULSOUT 0,150
PAUSE 20
NEXT
FOR temp = 0 TO 200
PULSOUT 0,180
PAUSE 20
NEXT
FOR temp = 0 TO 200
PULSOUT 0,120
PAUSE 20
NEXT
END
THE SAME DIRECTION.
-Tim
to set the default state of pin 0 to
output, low. PULSOUT only toggles the
pin once and toggles again at the end
of the pulse period -- you need to
set the default state before you
issue PULSOUT.
The goal is to have a 1 mS pulse to go
one way, and a 2 mS pulse to go the other.
1.5 mS pulse is supposed to halt.
Not having used the BS1, I don't know
if your values are correct. Also, the
variable resistor in the Servo MUST
be set to the center position (1.5 mSec
pulse width) for this to work.
connected
> '{$STAMP BS1}
> '{$PBASIC 1.0}
> SYMBOL temp = W0
> FOR temp = 0 TO 200
> PULSOUT 0,150
> PAUSE 20
> NEXT
> FOR temp = 0 TO 200
> PULSOUT 0,180
> PAUSE 20
> NEXT
> FOR temp = 0 TO 200
> PULSOUT 0,120
> PAUSE 20
> NEXT
> END
that
servo.
> THE SAME DIRECTION.
> -Tim
together--VSS and the 6v for the servo).
Thanks for the help!
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> The BS1 PULSOUT resolution is 10 microseconds, so "standard" servo
to
power
work at
yours
> to do:
> ' {$STAMP BS1}
> ' {$PBASIC 1.0}
> SYMBOL Servo = 0
> SYMBOL temp = B2
> Setup:
> LOW Servo
> Main:
> ' center (stop)
> FOR temp = 0 TO 200
> PULSOUT Servo, 150
> PAUSE 20
> NEXT
> ' cw
> FOR temp = 0 TO 200
> PULSOUT Servo, 100
> PAUSE 20
> NEXT
> ' ccw
> FOR temp = 0 TO 200
> PULSOUT Servo, 200
> PAUSE 20
> NEXT
> GOTO Main
> -- Jon Williams
> -- Dallas Office
> From: dixontj93060 [noparse][[/noparse]mailto:t_n_t@v...]
connected
Futaba
> '{$STAMP BS1}
> '{$PBASIC 1.0}
> SYMBOL temp = W0
> FOR temp = 0 TO 200
> PULSOUT 0,150
> PAUSE 20
> NEXT
> FOR temp = 0 TO 200
> PULSOUT 0,180
> PAUSE 20
> NEXT
> FOR temp = 0 TO 200
> PULSOUT 0,120
> PAUSE 20
> NEXT
> END
that
servo.
> THE SAME DIRECTION.
> -Tim
