Tsl230
Hello all. I was reading Nuts and Volts column #21 about the TI TSL230
light-to-frequency converter from paralax, and was wondering if I may use a 1 uf
capacitor across vdd and vss instead of the .1uf.
Thanks for your time, John Baker
Do you Yahoo!?
Yahoo! Mail - More reliable, more storage, less spam
Do you Yahoo!?
small (0.1 uf) and a larger (10 uF) across vdd to vss, the 0.1 uf is there to
act
as a short circuit to high frequency noise that may enter the circuit, while
the larger cap (10uF or bigger) would supply "supplemental" current for very
short periods of time if/when the circuit has a MOMENTARY high current demand
that might cause a small loss in voltage to the circuit. At least that is the
way I understand it.
Does anybody concur?
ken
input is appreciated.
-John Baker
smartdim@a... wrote:
Actually, it is proably a good idea to use both. When you typically see a
act
ken
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Yahoo! Groups Links
Do you Yahoo!?
capacitor basic, bypassing etc. In the mean time you might want to google
"explanation of bypass capacitors"
ken
wow, fast reply. Thank you. I just read some more about noises and such. more
-John Baker
smartdim@a... wrote:When I get to work tomorrow, I will post a link that is
pretty good about
ken
-John Baker
Yahoo! Groups Links
Do you Yahoo!?
-John Baker
smartdim@a... wrote:http://www.interq.or.jp/japan/se-inoue/e_capa.htm
-John Baker
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Finance Tax Center - File online. File on time.
