Parallax or maybe AWC Question
I Ran into a really strange problem. I'm using a Stamp SX to read
two computer mouse units with the AWC PAK IX chips for robot
navigation. The first uses P5, P6, and P7 for Transmit, Receive and
Enable respectively. The second uses P8, P9, and P10 also Transmit,
Receive and Enable respectively. I initialized the first and then the
second with the exact same codes, then do a read on the first chip,
then the weird thing happens, the program locks up on a read of the
second chip.
During trouble shooting, I determined I can run either chip alone
with no problem at all, but the combination of both is a problem.
The solution I found in swapping the serin commands I execute to
read the chips. Everything else is as I originally wrote the program.
I just read the second chip first and the first chip second and it
works perfectly. I don't really have a problem now with this solution
in place, but I would like to know if there is some rule I've violated
that prevented me from reading from "higher" numbered pins after
reading lower numbered pins. It cost me a couple of hours head
scratching and rechecking connections that I could have used in other
activities not to mention a few extra gray hairs.
I'm happily continuing my project but...
Any ideas?
Steve Alaniz
second chip.
Any ideas?
Steve Alaniz
That's a new one on me. I think you mean PAK XI though (the PAK-IX is an
A/D, floating point unit). I can't help but wonder if you fixed some bad
connection or faulty breadboard issue while moving stuff around? Without
changing anything else, if you simply reverse the order of the SERINs now
will it still fail?
I would guess it was some connection not being made or a short between two
connections somewhere. Very strange.
Al Williams
AWC
* New Kits: http://www.awce.com/kits.htm
From: catgirldo [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Uet-5b1inZJltcsp2Eux8X1OiEORGcsUM-4OxhqGnP8JeA0kCnEu1CDccmIafXxy2VwM1K_w3WJKzBWUobU]catgirldo@y...[/url
Sent: Monday, March 15, 2004 3:52 PM
Subject: [noparse][[/noparse]basicstamps] Parallax or maybe AWC Question
I Ran into a really strange problem. I'm using a Stamp SX to read two
computer mouse units with the AWC PAK IX chips for robot navigation. The
first uses P5, P6, and P7 for Transmit, Receive and Enable respectively. The
second uses P8, P9, and P10 also Transmit, Receive and Enable respectively.
I initialized the first and then the second with the exact same codes, then
do a read on the first chip, then the weird thing happens, the program locks
up on a read of the second chip.
During trouble shooting, I determined I can run either chip alone with no
The solution I found in swapping the serin commands I execute to read the
chips. Everything else is as I originally wrote the program. I just read the
second chip first and the first chip second and it works perfectly. I don't
really have a problem now with this solution in place, but I would like to
know if there is some rule I've violated that prevented me from reading from
"higher" numbered pins after reading lower numbered pins. It cost me a
couple of hours head scratching and rechecking connections that I could have
used in other activities not to mention a few extra gray hairs.
Any ideas?
Steve Alaniz
Yahoo! Groups Links
I've tried to verify the failure and naturally it works both ways
now. I had ruled out a hardware failure by using a scope to trace the
signals and verify their presence. That's when I started the software
tracing. I can only speculate that I may have a bad socket, but it
eludes me for the moment.
Well good call Al... guess my hardwired problems are between the
eyes this time. Thanks for the reply!
Steve
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> Hi Steve,
SERINs now
> will it still fail?
between two
> Regards,
> Al Williams
> AWC
> From: catgirldo [noparse][[/noparse]mailto:catgirldo@y...]
respectively. The
respectively.
codes, then
program locks
with no
read the
read the
I don't
like to
reading from
could have
> Any ideas?
> Steve Alaniz
Subject and
> Yahoo! Groups Links
