controlling many DC motors
I would like to use the Basic Stamp for controlling many DCmotors
independently from eachother, for an art project.
I have no idea what I need to extend the number of (only) 16 pins of
the stamp.
I heard something on "multiplier" and something of using the pins in
a binairy way.
Since being totally newn in this field: anyone can help me?
the stamp.
a binairy way.
Think of a multiplexer this way... You have two hands. And with
your two hands you can operate two buttons. That's it, that's your
limit, two. But with a board and some pegs you could construct a
simple device to operate, say, 8 buttons. So you use your two hands
to setup the sequence of pegs on the board and then that board is
used to operate the 8 buttons. It's slower than the direct method,
but it allows you to extend your limit of two hands.
This is how a multiplexer works. You typically use two or three pins
to set the bit sequence of a shift register (or 3-to-8 multiplexer or
similar device). The outputs from the shift register are then used
to control, usually, 8 things.
Depending on how you want to control your motors (PWM?) and how many
you might have to do some fancy coding.
Check out these two links:
http://www-2.cs.cmu.edu/~RAS/Docs/space/mux.html
ftp://nutsvolts.com/stampaps/st_ap5.pdf
--- In basicstamps@yahoogroups.com, "vandevendel1696"
of
> the stamp.
in
> a binairy way.
of
> the stamp.
in
> a binairy way.
I'm not sure of the queston, but can take a stab at it anyway.
First, I missed how many motors you want/need to run.
A DC motor can be switched ON or OFF so it runs at full speed, or it
can be controlled with a variable speed/variable voltage.
The ON/OFF is easy as it can be one transistor per motor for single
direction, or 4 to make an H-bridge (but uses 2 output pins)
Variable speed is more complicated, but if you use pwm out on a pin,
and can run the transistors in the analogue range you can control the
motor speed.
Multiple motors can be run from one signal, but they would run
exactly the same (direction or speed)
Can you describe your project in a little more detail ? or, at least
your needs and quantities for the motors ?
As you multiplex outputs, you need to use serial comm and that can
slow signals down.
For machine control, I would not recomend serial comm unless the data
speed is higher than the machine speed.
For an art project, it may not be a problem.
Dave
talk to them serially from a main computer. A board that can drive 8 motors
and has provisions for serial input is available from this web site
http://www.geocities.com/jimforkin2003/
jim
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=m7x68otHfxTy-KEUJRHe--4AAlWqFivyVx9XYVVHZYsxQOFtU-qdQVWCdZ-nNyL-7k-7eiQ_nT94CUPb7g]davemucha@j...[/url
Sent: Monday, March 15, 2004 5:40 PM
Subject: [noparse][[/noparse]basicstamps] Re: controlling many DC motors
of
> the stamp.
in
> a binairy way.
motor speed.
slow signals down.
Dave
Yahoo! Groups Links
