Debug with
Hi all,
I am using a BS2 to drive a servo after reading some data altitude
input.
My problem is:
I can't save debug inputs from the stamp with official debug program
to look at them further.
Has any one solved this problem or do know how to look at stamp's
debug outputs with microsoft hyperterminal which has save capacities
Thanks for your help
Guy
input.
My problem is:
Guy
press Ctrl-C) and paste it into Notepad to save. Remember that the
DEBUG window is not intended to be a general-purpose terminal like
Hyperterminal (it has control codes that don't work elsewhere).
You can, of course, use Hyperterminal, but you'll have to avoid using
formatting codes other than CR and LF. Set Hyperterminal for 9600-N81,
no flow control and you can receive your DEBUG output.
-- Jon Williams
-- Dallas Office
From: cozy20167 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=a6EizxxsUmP0A0nc9xxaclaw00aByOSHtRkGSyJeMwDNnhorUDZ8qReGq-Sob6go5j4nuYRE]cozy@l...[/url
Sent: Sunday, March 14, 2004 6:36 AM
Subject: [noparse][[/noparse]basicstamps] Debug with "save" option
Hi all,
input.
My problem is:
Guy
I tried today the hyperterminal session you sent me with theese
first lines of 2 programm
'{$STAMP BS2}
DEBUG" ",CR
DEBUG"Program Version alihold 1.02 GT1.11", CR
DEBUG"modif. de C. Caddy par prise de donn
-- DEBUG handles it. Make sure that you have the correct COM port selected in
HyperTerminal (as I told you yesterday, it must be set to the same port as your
BASIC Stamp programming port), and that your Debug Window is NOT open at the
same time (when the Debug Window is open it has control of the COM port).
-- Jon Williams
From: cozy20167 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Z_Pdkdj_gsY_Y-AmkW_5InpbcO0KeRsIJ9WayJk_Dd3sTPX96iMAdxqCylfYmSPkNFmCWUs1Tw]cozy@l...[/url
Sent: Monday, March 15, 2004 5:18 AM
Subject: RE: [noparse][[/noparse]basicstamps] Debug with "save" option
Jon,
first lines of 2 programm ========================================
'{$STAMP BS2}
DEBUG" ",CR
Hyperterminal raises DTS, which holds the
BS2 in reset unless it is decoupled by 2
capacitors -- which are in the BOE circuit.
If you've 'rolled your own' holder board, you
may have left these two capacitors out.
--- In basicstamps@yahoogroups.com, "cozy20167" <cozy@l...> wrote:
> Jon,
> '{$STAMP BS2}
> DEBUG" ",CR
I am using a parallax prototype board ( about 2"5 x 3")for Basic
stamp2.it has socket for BS. Reset button and holes required to
solder conponents
It has no capacitance mounted on
Do you think i need theese two capacitors ?
Where should they be mounted or do you know any terminal programm i
could use without capacitors mods
Guy
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> One question: Are you using the BOE?
> > Jon,
> > '{$STAMP BS2}
> > DEBUG" ",CR
http://www.parallax.com/detail.asp?product_id=28150
and download the BOE rev C schematic.pdf, you'll see
there are two 0.1 uF capacitors in the DTR (Pin 4)
line. These are the de-coupling caps I was talking
about.
You can use the 'terminal' windows in the Stamp IDE
without these caps.
If you can control the serial port from another
terminal program to set DTR OFF, then the stamp
should run. There's NO way that I know of to
convince Hyperterm to leave the DTR line alone.
> Allan,
> solder conponents
> Thanks
> Guy
> > > Jon,
> > > '{$STAMP BS2}
> > > DEBUG" ",CR
seen them.
Thanks a lot
Guy
wrote:
> Yes, if you go to
> about.
> without these caps.
> > Allan,
> > solder conponents
programm i
> > Thanks
> > Guy
<allan.lane@h...>
board will include the inline caps. It's not tough to add caps (0.1 uF)
to your board, you'll just need to sever the direct connection and put
one cap inline, then the other to Vss; like this:
0.1
DTR (DB9.4)
ATN (pin 3 on BASIC Stamp module)
=== 0.1
Vss
Here's alink to one of our standard programming boards that shows the
caps in place:
http://www.parallax.com/dl/docs/prod/stamps/BS2pDemoCschem.pdf
-- Jon Williams
-- Parallax
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MG1pSoSavOpAbKngbx9m1JnbMIP2CQFeLyjBp8f_kYC63hBkzq7GNdbwIaprqfQ--mp-clrrG_Z1Ob3H3HQqKjffWc63]allan.lane@h...[/url
Sent: Monday, March 15, 2004 11:50 AM
Subject: [noparse][[/noparse]basicstamps] Re: Debug with "save" option
Yes, if you go to http://www.parallax.com/detail.asp?product_id=28150
about.
without these caps.
> Allan,
> solder conponents
> Thanks
> Guy
This worked fine. All is ok now
Guy
wrote:
> Yes, if you go to
> about.
> without these caps.
> > Allan,
> > solder conponents
programm i
> > Thanks
> > Guy
<allan.lane@h...>
wrote:
> > > > Jon,
theese
> > > > '{$STAMP BS2}
> > > > DEBUG" ",CR
