BS2SX to drive Icon H-Bridge
Has anyone used a BS2 to drive a Icon H-bridge Motor controller?
Neither Parralax which sold it last year, nor Solutions Cubed,
which made it, can seem to tell me how to do this.
I simply need to use the BS2 to one-time program the H-bridge
to put it into direct, rather than serial mode. I have
the Stamp pins 4 and 5 connected to the serial in and out
pins of the icon, and I assume some SERIN and SEROUT commands
need to be developed, but I haven't correctly deciphered the
syntax. (Never mind that I bought the h-bridge for the direct mode,
hoping to avoid having to figure out this syntax in nthe first
place.)
If anyone has working code to communicate with a h-bridge, even
if they are just using serial mode, I would love to see it
so I can adapt it to my simple, one-time use.
place.)
>place.)
>Thanks
Which model ICON Controller are you using, there are apparently a number of
different models. I would like to believe it could be programmed from a PC if
you choose not to do it from a PBASIC Stamp.
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
They seem to sell other modules now. They do now sell an Icon
interface module which simplifies this
problem but I'd rather not spend another $60 for a product
I need for only a few millisecomds.
mode,
> >place.)
> >Thanks
number of different models. I would like to believe it could be
> Bruce Bates
Subject and Body of the message will be ignored.
> >Yahoo! Groups Links
at Icon. The following code immediately put my
Icon H-bridge in direct mode. I have BS2SX pin 4
connected to Din on the Icon and BS2SX Pin 5 to Dout.
I thought I should post it in case another frustrated
coder out there needs to communicate with an Icon.
Thanks you Lon.
Dennis
'{$STAMP BS2sx}
START
PAUSE 2000
SEROUT 4,1021,[noparse][[/noparse]$C2,$01,$02,$04,$83,$4C]
SERIN 5,1021,100,NOACK,[noparse][[/noparse]B0]
IF B0 <> $06 THEN NOACK
DEBUG "ACK FROM WRITE OK",CR
SEROUT 4,1021,[noparse][[/noparse]$C3,$01,$00,$C4]
DEBUG "ACK FROM STORE OK",CR
DONE:
GOTO DONE
NOACK:
DEBUG "NO ACK RECEIVED",CR
GOTO START
mode,
> >place.)
> >Thanks
> Bruce Bates
> >Yahoo! Groups Links
