outputs toggling
Will using the command dirs%00000001 make P0 of a basic stamp 2 to
become an output all the time and not toggle when the progam is not
doing anything?
The reason that i am asking this is b/c i am using two ADC's
connected to lines P0-P7 while using the inl command and selecting
between the two ADC's by using other output lines from the basic
stamp 2. But sometimes i have problems with reading the value from
the ADC's. I think the outputs are toggling but have no way of
measuring this.
All info is greatly appriciated.
doing anything?
measuring this.
>doing anything?
No, not all the time as you seem to need.
>measuring this.
My guess is that you map be using NAP or SLEEP in your program. Change that to a
PAUSE and the problem may disappear.
Bruce Bates
