opinion sought
Seeking opinions on code. I am writing 5 words to EEPROM, then later
reading those 5 words. The snippet posted below does work, but I am
simply seeking opinions wether or not there is a more "elegant" way
to achieve the same thing
<SNIP>
FOR run = 0 TO 9
again
IF IN6 = 1 THEN again
HIGH 0
PAUSE 1
RCTIME 0,1,load
WRITE run,load.LOWBYTE
run = run + 1
WRITE run,load.HIGHBYTE
PAUSE 2000 'poor mans debounce
NEXT
'READ PORTION
FOR run = 0 TO 9
READ run,load.LOWBYTE
run = run + 1
READ run,load.HIGHBYTE
SEROUT sPin,Baud,[noparse][[/noparse]"DATA,TIME,", DEC x, ",", DEC load,CR]
x = x + 1
NEXT
<SNIP>
FOR run = 0 TO 9
again
HIGH 0
PAUSE 1
RCTIME 0,1,load
run = run + 1
NEXT
'READ PORTION
FOR run = 0 TO 9
run = run + 1
x = x + 1
NEXT
guidelines and features of the 2.1 compiler. Specifically:
What is IN6? Why not give it a name with the PIN declaration?
Did you know you can WRITE words to EEPROM like this:
WRITE eeAddr, Word value1, Word value2, Word value3, Word value4, Word
value5
... and you can READ them back like this:
READ eeAddr, Word value1, Word value2, Word value3, Word value4, Word
value5
When using $PBASIC 2.5 syntax you are able to WRITE and READ Word-sized
values to EEPROM, and handle
multiple values in the same WRITE/READ instruction. You can even mix
types (Words and Bytes). When
writing a Word, it is done low-byte, then high-byte (the address in
taken care of by the compiler).
You can find our style guidelines ("The Elements of PBASIC Style") in
the v2.1 compiler help file or online in our Downloads section.
-- Jon Williams
-- Dallas Office
From: coiltap2003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=afPkS-6JeoOkA-1NVd5UGys9KqRQjLx_Z76OTtNOIx7BmQjeiigtw8aLA-ySxiWsGzobzns0RA]smartdim@a...[/url
Sent: Wednesday, March 10, 2004 2:48 PM
Subject: [noparse][[/noparse]basicstamps] opinion sought
<SNIP>
FOR run = 0 TO 9
again
HIGH 0
PAUSE 1
RCTIME 0,1,load
run = run + 1
NEXT
'READ PORTION
FOR run = 0 TO 9
run = run + 1
x = x + 1
NEXT
><SNIP>
>FOR run = 0 TO 4
>again
>HIGH 0
>PAUSE 1
>RCTIME 0,1,load
>run = run + 1
>NEXT
HIGH 0 ' init for RCtime first time
FOR cat = 0 TO 4 ' 5 words
DO:LOOP WHILE in6 ' hold for in6=0
RCTIME 0,1,load
HIGH 0 ' init RCtime right after
WRITE cat*2, Word load ' words take two bytes
NEXT
' now values are in eeprom from 0 to 9
>'READ PORTION
>FOR run = 0 TO 9
>run = run + 1
>x = x + 1
>NEXT
'READ PORTION
READ cat*2, Word load
x = x + 1
NEXT
