two stamps triggering same LED
I have two stamps. One was programmed by someone else, and the other
one has my code on it. I simply want my stamp to power a LED
occasionally. The LED is also connected to one of the output pins of
the other stamp.
So basically I have an output from each stamp connected to the same
LED. I know it would be bad if I drove one stamp pin high while the
other was trying to be low, but could I just put a 1n914 diode on
both of the stamp pins so there wouldn't be a problem?
the other stamp.
Stamp 1
[noparse][[/noparse]>|
| LED
Vss
Stamp 2
-- Jon Williams
-- Parallax
From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Vdj5107k26ya665hoTrvQwgzrSb086_KOESNG84gnR0nY0uIp-i8Z33YQw_om_kuHPHb3hHJ0ebCN6iZBLI]andywatson@m...[/url
Sent: Tuesday, March 09, 2004 5:18 PM
Subject: [noparse][[/noparse]basicstamps] two stamps triggering same LED
the other stamp.
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
> else, and the other
> power a LED
> the output pins of
> the other stamp.
So, Andy, you don't have a way to know which stamp is
lighting the LED...Is that okay? Just curious.
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________
Do you Yahoo!?
Yahoo! Search - Find what you’re looking for faster
http://search.yahoo.com
like 99 cents.
On Tue, 9 Mar 2004, Jon Williams wrote:
> Not a good idea unless you put a diode on the other side as well.
> Stamp 1
> | LED
Vss
> Stamp 2
> -- Jon Williams
> -- Parallax
> From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AKlT8n_r_AR9wgIEGVUNyuRKa54MkZsSYVEK30bCfwnfdX2cBjIJtuLFgkPlBhSq4ilw7VPeLdcQ]andywatson@m...[/url
> the other stamp.
> Yahoo! Groups Links
> abuse@p....
> Yahoo! Groups Links
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
thought I'd try doing it with just diodes and save a little room on
my already cramped circuit board.
--- In basicstamps@yahoogroups.com, "Sean T. Lamont .lost."
<lamont@a...> wrote:
> Isn't this just a logical or? You can buy an or gate at radio shack
for
> like 99 cents.
> > Stamp 1
> > | LED
Vss
> > Stamp 2
> > -- Jon Williams
> > -- Parallax
> > From: andy_watson5 [noparse][[/noparse]mailto:andywatson@m...]
other
pins of
> > the other stamp.
same
the
Subject
> > Yahoo! Groups Links
> > abuse@p...
Subject and Body of the message will be ignored.
> > Yahoo! Groups Links
(ServNet)
Bremerton
stamp cant really handle that much current from a single pin. Should switcvh
a transistor and power the led from the seperate 5v supply.
> From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AUiGQb-UCEGvRAyuXzTwWLmxd9YFtHfxSK0fGHygoPKwI5WbBYtNcJBvwyVCN7jlLQFJUNnTjDf31w]andywatson@m...[/url
> Sent: March 9, 2004 3:18 PM
> the other stamp.
> Yahoo! Groups Links
we drive LEDs all the time right out of the BASIC Stamp. A typical LED
only requires about 5 mA or so to light nicely. The only thing one
needs to be cautious of is driving too many LEDs from on IO group.
-- Jon Williams
-- Parallax
From: PatM [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=B5_MGST_Vtsf2vJfqLSZtm0MBhZVXsqlpDiepNm-P3s05U_4kvVOxW91VxmskWLyOfzH_BFc0w]pmeloy@s...[/url
Sent: Tuesday, March 09, 2004 9:29 PM
Subject: RE: [noparse][[/noparse]basicstamps] two stamps triggering same LED
First thing I'd worry about is driving and LED from a stamp pin period!
The stamp cant really handle that much current from a single pin. Should
switcvh a transistor and power the led from the seperate 5v supply.
> From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OZ60X5w5OG16alBMuj8IP8voRmhwRFMbnZ4KW_o4CYnDb-rP3gf1d8DxCo3ymrlp6cQ4BBAX6k-5IA]andywatson@m...[/url
> the other stamp.
> other was trying to be low, but could I just put a 1n914 diode on both
Connect the output pin of each stamp to the cathode of any standard
rectifier diode, a 1N4003 would do fine.
Connect the anode ends of the two rectifiers together.
Connect the anode ends also to the LED.
Connect the other end of the LED to the current limiting resistor. If it's
a 5 Volt system, and the LED is a 20 mA unit, then 300 Ohm is what I use.
Connect the other end of the current limiting resistor to +5 Volts.
With this connection, the LED will be illuminated when either of the two
stamps pulls the correct pin low.
> From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DLnAek2b42z7DHBkw0dWlNRqgoLsWHH0y2SNHL620tPKzI-8nvjSrzPCz5z61d3zxchEm2CLDUzR5QZ-]andywatson@m...[/url
> the other stamp.
Yahoo! Groups Links
with 7 segment displays a long while back - maybe thats why I was thinking
of the stamp not being able to handle the current.
Senility creeping up!
> From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=adwckNf8nPCT381z1biVqZ2EBM2BUiMS3GTklT2u3lYvzAvbyWrmpUClpggE8CK1KQCWh2zBaAsaW2eBrObL2g]jwilliams@p...[/url
> Sent: March 9, 2004 8:27 PM
> Where are you getting that idea? Puhleeze (excuse my incredulity) ...
> -- Jon Williams
> -- Parallax
be aware and control current. I typically use a 470 ohm current limiter
for LEDs when it's up to a few, but for a 7-segment display I bump the
current limiters up to 1K to protect the BASIC Stamp.
I hope I did come on too strong ... may I suggest that we all be careful
about what the BASIC Stamp CAN'T do without checking [noparse][[/noparse]the docs]
carefully as there are lots of youngsters and newcomers that will take
our word as gospel.
-- Jon Williams
-- Parallax
From: PatM [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pkT8K7DvZLA9FdllLljGKQsSR7y5LwMmeqYBZVTbA79R8kFSzgCYMw0_WKOeG0JiaJOfbHeL]pmeloy@s...[/url
Sent: Wednesday, March 10, 2004 10:23 AM
Hmm, I must have been thinking multiple LEDs or something. I did some
work with 7 segment displays a long while back - maybe thats why I was
thinking of the stamp not being able to handle the current.
> From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=og1pgeuQ2KcxS0uP4-_6X00lGJe5DOz_itg7s0mN-9DHy9-gH5Q-K20ke7HewS4ZKBBrA_1epVICc8JV2Q]jwilliams@p...[/url
> LED only requires about 5 mA or so to light nicely. The only thing
> one needs to be cautious of is driving too many LEDs from on IO group.
> -- Jon Williams
> -- Parallax
program to accept two different signals and log it at the same exact
time. Example I am trying to keep track of my employees when they
arrive to work with there id badges being swiped in the office reader.
It should store the first track that consist of their first and last
name and also at the same time log their employee number that is on the
second line and store it. Could this be possible? If so could someone
give me a example of doing different task at the same time? Please?
From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iWV_J_BWm9myr5oLrBGndzlYKC3Yp9FD3L3AW7XaNsSNsouLZ_G8NGbjCcQA2Cx3e2LdQrWnK3Fd9yaLCw]jwilliams@p...[/url
Sent: Wednesday, March 10, 2004 10:34 AM
Yes, when lighting multiple LEDs (as with a 7-segment display) we must
our word as gospel.
-- Jon Williams
-- Parallax
From: PatM [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=v3ZIsHdiPRn87MNdCT9KjlHZSPA-G2yT5wQwS4AEAokDKBaIg4wjd2xsn14WtPKp53Km-lg]pmeloy@s...[/url
> -- Jon Williams
> -- Parallax
Yahoo! Groups Links
