regarding A/D converters
hi ,
i am planning to use taptiles in my project. the specifications
given are
Product TapTile sensor
Version 2.1 (1998)
Sensing parameter : contact pressure, weight
Sensing method : force-sensitive resistor
Active area :approx. 30 cm (12") diameter circle
Range : 45 to 1000 N (4.5 to 100 Kg, 10 to 227 lbs)
Output resistance: more than 100 KOhm (at 0 N) to 200 Ohm
(at 1000N) in parallel with 47 KOhm
Calibration [noparse]:([/noparse]force applied to center of tile)
Voltage (use 5 V power supply)
N Kg lb voltage
0 0 0 0.00
400 40.0 90.8 1.02
600 60.0 136 4.02
800 80.0 182 4.92
1000 100 227 4.96
Power supply 5 V DC, 1 mA
incl. cable
Cable 5.0 m (16 ft), shielded, red wire = power, uninsulated wire =
ground, black wire = sensor output
Connector male plug with 3 pins in a row spaced 2.54 mm (0.100")
these taptiles produce variable voltages when one steps on
it. do i need to get A/D converter to convert these voltages to
digital values or can i use RCtime command with RC circuit. if i
need to use the converters can anyone suggest what to buy. i mean we
will be having different types of converters which one would be
better for my project.
silpa
given are
Version 2.1 (1998)
N Kg lb voltage
0 0 0 0.00
400 40.0 90.8 1.02
600 60.0 136 4.02
800 80.0 182 4.92
1000 100 227 4.96
incl. cable
silpa
I'm not at all clear. I've done some stuff with the QT
charge-transfer capacitance switches, but this is sort of intriguing. I'm
interested in alternative I/O methodologies.
On Tue, 9 Mar 2004, silpa_k3 wrote:
> hi ,
> given are
> Version 2.1 (1998)
> N Kg lb voltage
> 0 0 0 0.00
> 400 40.0 90.8 1.02
> 600 60.0 136 4.02
> 800 80.0 182 4.92
> 1000 100 227 4.96
> incl. cable
> silpa
> Yahoo! Groups Links
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
http://www.infusionsystems.com/products/taptile-21.shtml
They say that it is based on a force sensing resistor, so you could
probably take the resistance between the red and the black wires as
an input to an RCtime circuit on the Stamp. Just a guess.
-- Tracy
> hi ,
>given are
>Version 2.1 (1998)
> N Kg lb voltage
> 0 0 0 0.00
> 400 40.0 90.8 1.02
> 600 60.0 136 4.02
> 800 80.0 182 4.92
> 1000 100 227 4.96
>incl. cable
>silpa
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
to an IO pin and treat it like any other input switch.
For a force under 40 pounds, you get a zero out. For greater then 60
pounds, you get a one. That right there is something the Stamp can
work with.
As far as being USEFULL to your application, you'll have to tell me.
This works for an on/off condition, but if you are attempting to say
measure the weight on the taptile then this method is no good.
--- In basicstamps@yahoogroups.com, "silpa_k3" <silpa_k3@y...> wrote:
> hi ,
> given are
> Version 2.1 (1998)
> N Kg lb voltage
> 0 0 0 0.00
> 400 40.0 90.8 1.02
> 600 60.0 136 4.02
> 800 80.0 182 4.92
> 1000 100 227 4.96
> incl. cable
we
> silpa
