I designed a PCB. What''s wrong with it?
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...> wrote:
> A recommendation is to print out the board 1:1, lay the printout on
> some foam board and press in the components.
> Dave
This is a good suggestion from Dave. After you've tried everything for
dry fit, you might then refine the placement and test the function on
a piece of perfboard from Rat Shack or equivalent.
Stephen Weller
American. Veteran. Patriot.
> Dave
Stephen Weller
