I designed a PCB. What''s wrong with it?
--- In basicstamps@yahoogroups.com, "jmccorm" <jmccorm@y...> wrote:
> --- In basicstamps@yahoogroups.com, "fab4442003" <fab4442003@y...>
wrote:
> > The possible problem I see the spacing between the LED holes - which
> > looks too close. Typically you want to place the holes the same
> > distance apart as the LED leads. You'll find this info in the data
> > sheet for the LED - it's typically 0.10 in.
> Even for a 5mm RGB LED with 4 pins? (I *thought* I got it right, but I
> could be wrong!)
Nevermind - thought you were using 2 lead LED's.
> could be wrong!)
