I designed a PCB. What''s wrong with it?
--- In basicstamps@yahoogroups.com, "fab4442003" <fab4442003@y...> wrote:
> The possible problem I see the spacing between the LED holes - which
> looks too close. Typically you want to place the holes the same
> distance apart as the LED leads. You'll find this info in the data
> sheet for the LED - it's typically 0.10 in.
Even for a 5mm RGB LED with 4 pins? (I *thought* I got it right, but I
could be wrong!)
could be wrong!)
