I designed a PCB. What''s wrong with it?
Hello from Gregg C Levine
Nothing that I could see, on first glance. If you can work on that
board, without causing damage to it, then your okay.
Suppose you post a few more details. Like an idea behind what your
planning on doing with this Maxim part. And have you successfully
bread-boarded this circuit first? It's my guess that you have done
that step, that's why you went to the next step that of creating a
PCB. Have you had a chance to try it? Does it work? What happened?
What does the code for it look like?
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
(This company dedicates this E-Mail to General Obi-Wan Kenobi )
(This company dedicates this E-Mail to Master Yoda )
> From: jmccorm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=j_lM-7g7Bmr4bTLg_jgTInv_7J-ZOtRtJPRBVtehUlkxumib5kBecZVfy15y6sBF29UO7KOlwg8lYZ0]jmccorm@y...[/url
> Sent: Sunday, March 07, 2004 12:49 AM
> Subject: [noparse][[/noparse]basicstamps] I designed a PCB. What's wrong with it?
> Well, this is certainly why I like the Basic Stamp. It is really an
> opportunity to _stretch_ my skills! So, for the first time, I
decided
> to design a PCB layout. I used "pcb", an X-Windows (UNIX/Linux)
> application to help draw the shapes.
> It is here:
> http://members.cox.net/jmccorm/pcb.jpg
> The board is 2"x3.5". It controls 6 RGB LEDs based on the I2C
two-wire
> protocol. It is based on the MAX6956 chip. Towards the top are
jumpers
> which are used to select the address of the chip (16 possibilities).
> Towards the right of the MAX6956 is a connector which would support
> power and interface with the BS2 board, as well as connect one LED
> board to the next one in the series. (Each board would connect to
the
> next board in the series.)
> Three major mounting screw holes are distributed through the board
> (two towards the top, one towards the bottom). At the bottom of the
> board are six 5mm RGB LEDs, which are capable of display one of 4913
> colors (17*17*17).
> But really, the main thing I was wanting was some critique of this
PCB
> layout. Is this realistic? Is this something I could give to an
> experienced person to produce? Are the holes for the LEDs and the
> wires too close to work with? Too many resistors too close together?
> Any obvious mistakes?
decided
> It is here:
two-wire
jumpers
the
> colors (17*17*17).
PCB
