74HC595 run a bipolar stepper?
Hi All,
Sorry for the second OT post, but I was wondering if anyone had ever tried
running a small bipolar stepper like the ones found in floppy drives from a
74HC595.
Thanks!
Jonathan
www.madlabs.info
74HC595.
Thanks!
Jonathan
www.madlabs.info
>Hi All,
>74HC595.
>Thanks!
>Jonathan
>www.madlabs.info
Jonathan -
I've never seen that done, not to say that it can't be done. Here is an L293
used as a stepper driver, with a tutorial along with it:
http://www.phanderson.com/stamp/tutorial_3.html
Thanks to Prof. Peter Anderson.
Bruce Bates
<jpeakall@p...> wrote:
> Hi All,
ever tried
drives from a
> 74HC595.
> Thanks!
> Jonathan
> www.madlabs.info
Check the data sheet for the chip.
Check the coil resistance and your voltage.
Here is a link to floppy drive steppers
http://www.doc.ic.ac.uk/~ih/doc/stepper/
The chip and stepper need to be matched so that the current can be
supplied.
I would considder using a ULN2803 between the 595 and the motor. The
03 has internal diodes. And since you will not beusing all channels
at once, you will never exceed the package rating by pushing any
channel to the max.
Dave
Thanks for the link, looks good. Thanks to P. Anderson too!
Jonathan
www.madlabs.info
L293
> Bruce Bates
