servomotor modification
I have read somewhere that a servomotor can be modified to run
cotinuesly in one direction but I do not know where i read it.
I have received a servomotor with the homeworkboard. Is it posible to
modify this motor so that it can run 360°? Can it than run in one
direction cotiniusly? How is it done?
Thanks.
Willy
Thanks.
Willy
somewhere that shows (might look under servor
question).. I used it to modife one... still playing
with it though... you'll need 2 resistors and a good
pair of pliers (or a way of removing a notch on one of
the gears.)... hope that helps.. :-)
Tony
> modified to run
> i read it.
> Is it posible to
> than run in one
> Thanks.
> Willy
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! Search - Find what you’re looking for faster
http://search.yahoo.com
modifications that remove the servo part of the servomotor to become a
simple geared motor. >>>>>>>>>>I would like to program the basic stamp
telling the servo motor to go 100 turns + 15°.<<<<<<<< So I need to
modify my servo motor to be able to act as a servo in multy turn mode.
Willy
From: not today [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yQ_zKt_o19rbDGtrWw1IiyleIl9Uc_raeANncx8Fht2gVmS5nbR_-cOJtQQnjitwZfKeT3xyDofA4sPdX1JLhw]dakota_99_64804@y...[/url
Sent: woensdag 3 maart 2004 6:43
Subject: Re: [noparse][[/noparse]basicstamps] servomotor modification
do a seach on servo in the messages.. there a link
Tony
> modified to run
> i read it.
> Is it posible to
> than run in one
> Thanks.
> Willy
> ignored.
> Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
The way a servo works is there is a comparator,
and a motor driver, and a motor, and a variable
resistor, and some gears driving an output shaft,
inside the case. All for $15.00, such a deal.
The servo expects to recieve a high-going pulse
of between 1 and 2 mSec, repeated every 20 mS to
50 mSec. A 1.5 mSec pulse indicates center position,
while 1 mSec is all the way left, and 2 mSec is
all the way right (I could have those backwards).
When the servo moves the output shaft, the variable
resistor moves also. This changes an internal pulse
width inside the servo -- which the servo compares
to the input pulse width. It drives the shaft until
the internal pulse width matches the input pulse
width, thus putting the servo output shaft where
you want it.
The continuous rotation modification disconnects
the variable resistor from the output shaft, and
sets the variable resistor to its center position so it
is putting out a 1.5 mSec pulse all the time internally.
Then, if you give a 1 mSec pulse to the servo,
it rotates continuously in one direction, trying to
get that now disconnected variable resistor to
rotate and match your input. The result of all
of this is a nice motor with driver, and all your
BS2 has to do is give it a pulse every 20 mSec.
You can stop the rotation by giving it a 1.5 mSec
I'm afraid what you are trying to do (rotate 10 times
and then stop at one point) will require a separate
position encoder wheel on your output shaft, and
a separate circuit to read it. The servo does
not have the stuff inside it to do this by itself.
--- In basicstamps@yahoogroups.com, "Willy Gooris" <satchid@p...>
wrote:
> I found a lot of ways to modify the servomotors. All that I found
where
become a
stamp
mode.
> Thanks
> Willy
> From: not today [noparse][[/noparse]mailto:dakota_99_64804@y...]
> Tony
> > modified to run
> > i read it.
> > Is it posible to
> > than run in one
> > Thanks.
> > Willy
> > ignored.
> > Yahoo! Groups Links
> Do you Yahoo!?
> Yahoo! Search - Find what you're looking for faster
Subject
> Yahoo! Groups Links
