Serial LCDs — Parallax Forums
Serial LCDs
edited 2004-03-03 06:02 in General Discussion
Does the 2x16 Serial LCD that Parallax supplies innately easier to
install, than another LCD display?
    edited 2004-03-02 19:47
    >It's easier to use as far as sending data, and it uses a serial line as opposed
    to multiple parallel lines, so I'd guess that would make installation easier in
    most cases.
    >Bruce Bates
    >from the same email address that you subscribed. Text in the Subject and Body
    >Yahoo! Groups Links
    edited 2004-03-02 22:26
    You interface to it with simple RS-232 commands,
    instead of the arcane Hitachi LCD parallel
    commands. It takes fewer pins, and fewer
    instructions to use. So yes, I'd say it
    is easier than the 'normal' LCD display.
    Brandon,
    Serial displays are easier to use than parallel displays. The one Parallax
    sells is the same as any other serial LCD.
    Jonathan
    www.madlabs.info
    Sent: Monday, March 01, 2004 7:35 PM
    Subject: [noparse][[/noparse]basicstamps] Serial LCDs
    > Yahoo! Groups Links
