Question about FREQOUT — Parallax Forums
edited 2004-03-01 23:04 in General Discussion
My BOE-BOT manual uses statement such as
FREQOUT 0, 1, 41000, but according to the manual, highest frequency
is 32767.
They seem to contradict each other.
What is the real limit on frequency?
What is the side effect of a frequency higher than 32767? Anything?
Thank you.
    edited 2004-03-01 18:32
    In a message dated 3/1/2004 1:17:45 PM Eastern Standard Time,
    basicstampede@y... writes:
    > is 32767.
    Frequencies higher than 32767 are derived from harmonics. I have used all
    sorts of frequencies and have never observed any side effects/ I've never gone
    higher 41500 so I don't know what the upper limit is.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2004-03-01 18:35
    >is 32767.
    The 32767 restriction is for the BS-2 and BS-2e. Other Stamps are capable of
    higher frequencies per the table in the PBASIC Stamp Manual.
    >Thank you.
    >Bruce Bates
    edited 2004-03-01 18:42
    My question pertains to BS2 which comes with BOE BOT.
    The BOE BOT manual uses higher frequency than what is supposed to be
    the limit according to the BS manual for BS2.
    Where is the harmonics coming from?
    Thanks.
    frequency
    > >is 32767.
    capable of higher frequencies per the table in the PBASIC Stamp
    Manual.
    Anything?
    > >Thank you.
    > >Bruce Bates
    edited 2004-03-01 18:53
    The output from FREQOUT is actually a string of variable-width square
    waves. If you filter the output you'll get a nice sine wave at the
    targe frequency. Mathematically, a square wave is composed of its root
    frequency and all odd harmonics. It turns out that when you tell the
    Stamp to FREQOUT at 38500 (modulation for an IR LED) that the harmonics
    generated are strong enough at that frequency to do the job.
    One of our staff engineers, Andy, has taken this even further and done
    some really neat frequency sweeping to do distance measuring with a
    BOE-Bot. Download the Robotics text for that.
    And, contrary to other posts, the upper end of FREQOUT is indeed 32767
    -- for all BASIC Stamps.
    -- Jon Williams
    -- Dallas Office
    From: basicstampede [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Kz-d88L99noaZFLUy5u3p3d5kRhnjNjED6u4PyE6SlRBH4niHP0DTqHMeXAHfuRRC6ll_B_vf0WQkZ4vBL6JFQ]basicstampede@y...[/url
    Sent: Monday, March 01, 2004 12:43 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Question about FREQOUT
    Thanks.
    frequency
    > >is 32767.
    Manual.
    Anything?
    > >Thank you.
    > >Bruce Bates
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2004-03-01 19:03
    I'm confused. If you say that the upper limit is 32767, then how
    does the statement FREQOUT 1, 1, 41000 even compile? Or does it
    actually do FREQOUT 1, 1, 32767 instead?
    Thanks.
    --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
    square
    root
    the
    harmonics
    done
    32767
    > -- Jon Williams
    > -- Dallas Office
    > From: basicstampede [noparse][[/noparse]mailto:basicstampede@y...]
    be
    > Thanks.
    > frequency
    > > >is 32767.
    > Manual.
    > Anything?
    > > >Thank you.
    > > >Bruce Bates
    Subject
    > Yahoo! Groups Links
    > abuse@p...
    PBASIC does not do range checking so if you try to put a 16-bit value
    into a 4-bit variable, what you'll end up with is the lower 4-bits.
    That's what happens here, you're getting the lower 15 bits and a
    harmonic of the resultant frequency is what is modulating the IR diode.
    -- Jon Williams
    -- Dallas Office
    From: basicstampede [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hBuThDhDsB7hroekllvgSdvh9hJqMWnWQ4yhXbAGcFtjBhUjxbGvWvnygBCmHqfSZITgPayKgnpOqh4paZxtQpHM]basicstampede@y...[/url
    Sent: Monday, March 01, 2004 1:03 PM
    Thanks.
    square
    root
    the
    harmonics
    done
    32767
    > -- Jon Williams
    > -- Dallas Office
    be
    > Thanks.
    > frequency
    > > >is 32767.
    > Manual.
    > Anything?
    > > >Thank you.
    > > >Bruce Bates
