12 vdc Solenoid
I am in need of a 12 vdc Solenoid that will need at least a 2 inch
stroke on it. It will also need to have at least a 4 pound pull and
be able to be mounted in a engine compartment. I have done a search
on the internet but the only hits that I have come up with are small
solenoids. Does any one out there know of a company or source for
this type of solenoid?
Gene
Gene
heavy duty for your needs but they would work and they are specifically
designed for engine compartment locations.
Bryan Henderson
Manufacturing Design Technician
Corning Cable Systems
Gene
Yahoo! Groups Links
small
> Thanks
> Gene
Gene,
You may need something a bit more sophisticated than a solenoid.
Asking a solenoid to deliver long stroke and strong pull are at
opposite ends of the physical capabilities of solenoids.
You can probably adapt a small motor and gearbox to give you
what you need and at a smaller current draw. Consider a windshield
wiper motor assembly or a power window motor. An electric screwdriver
is an economical way to get a compact motor and gearbox . Put a
crank with 1 inch of throw on the shaft and there's your 2 inch
stroke. Plus you'll be able to easily generate your 4 pound pull.
to the local junk yard is in order!
jim
http://www.geocities.com/jimforkin2003/
From: stamptrol [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Aop29wgt8ZbQCTRXj06lXqfIGCg1zg3yCc8D4nbb8NCWGoAgabWj4rsboITwiUAxmugMVrat0oKOuQWgJRRRwLg]sisk1404@n...[/url
Sent: Monday, March 01, 2004 9:17 PM
Subject: [noparse][[/noparse]basicstamps] Re: 12 vdc Solenoid
small
> Thanks
> Gene
Gene,
Yahoo! Groups Links
