Controlling the Opto22 Module Rack and Modules..how!?
how can i use a basic stamp (2 series i do believe) to get
information from the inputs modules and send information to the
output modules.
what im trying to do is detect the voltage created by an ac
generator, then switch off the power coming from a battery, and have
the power from the generator routed to power what the battery was
powering until it got switched off.
i don't need code written. wut i would need to know is if the opto22
modules can achieve this, and what commands i could use to
send/recieve information from the opto22 module rack when connected
with the control interface board.
thank you for any help.
output modules.
The Opto-22 modules have a logic side and a Load/Input side for the real
world.
The Input modules have a Logic + Output and Logic Ground.
Logic + goes to +5 volts
Logic Ground goes to the 5 volt common
Output connects to the stamp Pin. When there is voltage on the input side,
the output goes low, and drags the Stamp Pin low. you read the pin as Low = On
The Output Modules have a Logic + and Logic Control
Logic + to +5
Logic Control to a Stamp Output pin. When the stamp pin goes low the Output
turns on.
You need a 100k pull-up resistor from the Stamp Pins to +5.
If you use the Opto G4 mounting board the pull-up resistors are already there.
You must be careful of the 8 pin limit on the Stamp. Too many Outputs on at
once can exceed the limit. Check the Stamp Manual for the type of stamp you are
using. The Opto-22 Output modules draw about 13-15 MA when on. Try to mix the
inputs with the outputs per 8 pin group to prevent overloading the Stamp.
Hope you are not too confused.
Alan Bradford
Plasma Technologies
In a message dated 3/1/2004 10:33:20 AM Eastern Standard Time,
qaidskey@y... writes:
output modules.
modules read how much voltage is flowing through them into a variable
in the stamp? and if i got what u told me, turning the stamps pins
low would turn either module on letting electricity flow through it?
--- In basicstamps@yahoogroups.com, plasmastamp@a... wrote:
> I use the Opto-22 G4 Modules with all Stamp Models.
real
> world.
input side,
as Low = On
> Logic + to +5
the Output
> turns on.
already there.
Outputs on at
stamp you are
to mix the
Stamp.
> Alan Bradford
> Plasma Technologies
> output modules.
have
opto22
or High) you cannot read an analog signal.
On the output modules when the stamp pin goes low, the module turns on. It is
Optically isolated so no current flows from the stamp to the load on the
output of the module. Think of it as a switch. When the pin goes low the switch
turns on.
The input modules work the same way, but in reverse. When the voltage is
present at the input of the module, it turns on a switch that grounds the stamp
pin. Low = On. They are also optically isolated. No current flows from the load
to the stamp pin.
Opto 22 is a trade name for their Optically isolated solid state relays.
Alan Bradford
Plasma Technologies
In a message dated 3/2/2004 5:10:46 PM Eastern Standard Time,
thanx very much. but i still got a few questions. can the input
real
> world.
input side,
as Low = On
> Logic + to +5
the Output
> turns on.
already there.
Outputs on at
stamp you are
to mix the
Stamp.
> Alan Bradford
> Plasma Technologies
inpute module (we'll say 12v-32v) hooked up in series. if i had the
output "on" and electricity began to flow at about 12v so that the
input turned "on" and forced a pin low, i could then find out if the
pin was low and in turn switch the output off (if i wanted to) to
switch off the input and the output and then do w/e i wanted really.
thanx again!
> The Stamp side of the Opto modules is a digital 1 bit signal On or
Off (Low
on. It is
on the
low the switch
> turns on.
voltage is
grounds the stamp
from the load
> to the stamp pin.
relays.
> Alan Bradford
> Plasma Technologies
variable
the
> real
> > world.
> input side,
pin
> as Low = On
> > Logic + to +5
> the Output
> > turns on.
> already there.
> Outputs on at
> stamp you are
Try
> to mix the
the
> Stamp.
> > Alan Bradford
> > Plasma Technologies
read it to see if it is on. The software should keep track of it for you.
Think of the Opto modules as level shifters for the pins. They shift the
level of the input to a safe 0-5 volts for the inputs and shift the 0-5 volt
output to a level your load needs. It is no more complicated than that.
If you need to verify an output is on, for a fail safe condition, then you
can use another input module and Input on the Stamp to read the load.
Alan Bradford
Plasma Technologies
In a message dated 3/2/2004 10:33:40 PM Eastern Standard Time,
aaaaah...i think im gettin it. so if i had an output module, and an
thanx again!
Off (Low
on. It is
on the
low the switch
> turns on.
voltage is
grounds the stamp
from the load
> to the stamp pin.
relays.
> Alan Bradford
> Plasma Technologies
Getting back to your original posting:
I would just use a power relay that had its coil connected to the generator.
When the generator is running, the coil is energized and the power is routed
from the generator. When the generator is off the relay de-energizes and using
the normally closed contacts rout the power from the batteries. This is the
simple way to do it.
If you want to use a stamp as a relay control, then have one pin set up as an
input and monitor the generator output voltage and when it reaches a certain
level, switch the relay.
An Opto-22 type input module had a range of input voltages so select the
right one for your application.
The power relay is driven by an output pin through an Opto-22 Output module.
A more complicated way to do the same thing as a single relay.
Hope this clears things up,
Alan Bradford
Plasma Technologies
output modules.
meant was that the output modules are like switches at high power
right? and the input modules are like "auto-switches" in the way that
if electricyt flows through them it automatically switches on and
puts the pin from the stamp, low, right?
> Well, I guess Im lost now! If you turn on an output pin, you do
not have to
for you.
shift the
0-5 volt
that.
then you
load.
> Alan Bradford
> Plasma Technologies
the
really.
> thanx again!
> Off (Low
turns
> on. It is
> on the
> low the switch
> > turns on.
> voltage is
> grounds the stamp
> from the load
> > to the stamp pin.
> relays.
> > Alan Bradford
> > Plasma Technologies
passes through. It is just a way to get a 5 volt Stamp to talk to the real world
of
different voltages.
Alan Bradford
Plasma Technologies
In a message dated 3/3/2004 5:01:19 PM Eastern Standard Time,
yeah im lost too, i really dont get what u just said. but what i
not have to
for you.
shift the
0-5 volt
that.
then you
load.
> Alan Bradford
> Plasma Technologies
whose starting voltage was about what i wanted it, and wait for it to
drive the pin on the stamp low?
> HI,
generator.
is routed
energizes and using
This is the
set up as an
a certain
select the
Output module.
> Alan Bradford
> Plasma Technologies
> output modules.
have
opto22
series with an output module that ran just about the same voltage,
and used the code (we'll saying im using pin 6 for input, and pin 5
for output)(btw, i dont know if this is the proper terms or not):
Low 5
Repeater:
if 6 = off then goto repeater
High 5
...so then this would hypothetically mean that the output is turned
on and letting voltage goto the input, and when the input is turned
on (which would be when it reaches 12vdc, in this case) it will then
goto the "High 5" line and switch the input off and then in turn
switch the input off...right?
You need to change the If/Then Statement (Unless you had a variable called
'off' and set its value to 0 (Zero)
Low 5
Repeater:
if 6 = 0 then goto repeater
High 5
Alan Bradford
Plasma Technologies
In a message dated 3/4/2004 5:50:13 PM Eastern Standard Time,
ok! so say i had an input module that was 12-32 vdc hooked up in
Low 5
Repeater:
High 5
> Yes, that is how it should work.
called
> Low 5
> Repeater:
> High 5
> Alan Bradford
> Plasma Technologies
> Low 5
> Repeater:
> High 5
then
