running a loop for 10 seconds
I've got a simple loop that's looking for an active-high pushbutton
signal on 3 input pins:
firstloop:
IF IN1 = 1 THEN alpha
IF IN2 = 1 THEN bravo
IF IN3 = 1 THEN charlie
GOTO firstloop
When the stamp program is executed, I want to run this loop for 10
seconds, and then switch to a separate subroutine.
How can I make the loop above execute for only 10 seconds? I don't
want to add a pause at the end of each loop in case the momentary
button input happens during that pause. I've thought about using a
FOR-NEXT loop, but that only counts interations of cycles and not time
duration, correct? Any suggestions?
firstloop:
GOTO firstloop
andywatson@m... writes:
> firstloop:
> GOTO firstloop
A Stamp executes 4000 instruction per second - 10 seconds = 40000
instructions. So try this:
x = 0
loop1
x = x + 1
if x = 10000 then go somewhere else
goto loop1
You might have to adjust the 10000 value for x, but that should be pretty
close.
Sid Weaver
W4EKQ
Port Richey, FL
DO
IF IN1 = 1 THEN Alpha
IF IN2 = 1 THEN Bravo
IF IN3 = 1 THEN Charlie
PAUSE 25
timer = timer + 1
IF (timer >= 400) THEN EXIT
LOOP
GOTO Main
-- Jon Williams
-- Parallax
From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bKD06DPLDkIMDdXhoocouxQUi5218xsu47XlfOltg-QBQbsxbhjqZZ5gCYW_uLujNsYLNQLXKGIfnA]andywatson@m...[/url
Sent: Sunday, February 29, 2004 4:25 PM
Subject: [noparse][[/noparse]basicstamps] running a loop for 10 seconds
firstloop:
GOTO firstloop
How can I make the loop above execute for only 10 seconds? I don't want
to add a pause at the end of each loop in case the momentary button
input happens during that pause. I've thought about using a FOR-NEXT
loop, but that only counts interations of cycles and not time duration,
> instructions.
Is that rate the same for all stamp models? I thought I remembered
seeing a table listing the rate for command executions for each of the
stamp models, but I can't seem to find that table now.
> > instructions.
That is for a BS2, and I think a BS2E. Go toe the Paarallax site, under
Stamps, and look at the comparison table. The fastest is the BS2P at 12000 per
sec. If you are using something other than a BS2 just adjust the 10000
accordingly.
Sid
direction. I've read so much documentation lately that I can't
always remember where I find stuff.
I will have to say that I think Parallax does a superb job of making
documentation available online. It's rare to find a company these
days that goes the extra mile when providing product support.
--- In basicstamps@yahoogroups.com, Newzed@a... wrote:
> In a message dated 2/29/2004 10:05:52 PM Eastern Standard Time,
40000
> > > instructions.
remembered
of the
under
at 12000 per
10000
> accordingly.
> Sid
time. You might find this breakdown informative:
http://www.emesystems.com/BS2speed.htm
-- Tracy
>40000
>> > > instructions.
>remembered
>of the
>under
>at 12000 per
>10000
>> accordingly.
> > Sid
