LED control interfering w/servo control — Parallax Forums
edited 2004-03-01 22:32 in General Discussion
I'm stumped--
I have a BS2SX controlling servos and a light source. One light
source I'm using is a 110VAC, 60Hz LED lamp (like the ones they're
using for traffic signals now). Of course my stamp is triggering a
relay to control this. I notice that when I turn the LED on & off,
my servos twitch. However, when I replace that light source with a
standard light bulb (60W) and turn it on and off, it doesn't
interfere with the servos at all. Any suggestions about what I could
do? Thanks.
Jon
    edited 2004-02-29 18:12
    Beef up your power supply, or separate the servo supply from the rest of
    the circuit. If you use a separate servo supply, remember to connect
    the servo supply ground to the BASIC Stamp ground.
    -- Jon Williams
    -- Dallas Office
    From: jhtoolman2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WY5tB_j4_ombPDQ7R_dNqY06lNfwbpfJvld3JS3ZRfCTOIr_knywcH7Q5XryHDNL-sKs8T2NxZ_6jqSfMw]jhtoolman2000@y...[/url
    Sent: Sunday, February 29, 2004 11:01 AM
    Subject: [noparse][[/noparse]basicstamps] LED control interfering w/servo control
    I'm stumped--
    do? Thanks.
    Jon
    edited 2004-03-01 15:09
    I believe a standard incandescent lamp starts
    off at a high resistance, then the resistance
    drops as the lamp heats up and lights up. This
    is 'nice', as you don't get a large current
    surge when you first turn on the light.
    I don't know what circuitry they have around
    your LED's, but its probable there is a current
    pulse when you first turn them on which is
    somehow being coupled to your Servos.
    More capacitance between your power-supply line
    and ground may handle this. You may also need
    a larger (more current) power supply.
    --- In basicstamps@yahoogroups.com, "jhtoolman2000"
    <jhtoolman2000@y...> wrote:
    > I'm stumped--
    could
    > do? Thanks.
    > Jon
    edited 2004-03-01 16:16
    It is just the reverse.
    Regards
    ECO
    Sent: Monday, March 01, 2004 4:09 PM
    Subject: [noparse][[/noparse]basicstamps] Re: LED control interfering w/servo control
    edited 2004-03-01 17:13
    An Incandescent lamp has a low resistance when the filament is cold and
    resistance goes up as the filament heats up.
    Sent: Monday, March 01, 2004 7:09 AM
    > > I'm stumped--
    > could
    > > do? Thanks.
    > > Jon
    > Yahoo! Groups Links
    Sigh. I knew it was the one or the other,
    and I got it wrong. So, the MOST current
    will be drawn at the beginning.
    This still doesn't tell us how much current
    is drawn by the LED-based lighting circuit,
    nor it's startup behavior.
    --- In basicstamps@yahoogroups.com, "Stephen H Chapman"
    and
    > From: "Allan Lane" <allan.lane@h...>
    > > > I'm stumped--
    they're
    triggering a
    off,
    with a
    > > could
    > > > do? Thanks.
    > > > Jon
    Subject and
    > > Yahoo! Groups Links
