Table driven user interface
Can anybody point me to a working example of a table driven user interface?
Preferred output device is a serial text lcd 2x16 or 4x20.
Preferred input devices are keys.
I would like to program a text intensive menu system into a table that is
offloaded into external eeprom, and then parsing that table while
inside the menu command.
Program language may be pbasic, java or c.
regards peter
regards peter
I have been thinking of something along the same lines. Care to shre
some ideas? Using an EEPROM to store the table information is a good
one, sspecially in a Stamp enfironment.
In "the old days" there was a "programming language" called Decision
Tables. This was essentially a State Transition chart. I can think
of four elements:
1. States
2. Events (essentially status bits set outside the table class)
3. Actions (same, set by the table class to cause things to be done
4. Next State
Imagine the States to be arranged vertically (rows) and Events
horizontally (columns). Each table intersection can have a set of
Actions and one Next state. I am currently doing this on a Javelin
Stamp, but the table is hard-coded. I'd love to discuss a way to
generalize it!
Russ
--- In basicstamps@yahoogroups.com, "Peter Verkaik"
<peterverkaik@b...> wrote:
> Hi,
interface?
that is
> regards peter
>Peter,
>of four elements:
>1. States
>4. Next State
>generalize it!
>Russ
Russ and Peter -
A very similar techniques is often used by operating system task managers in
event driven systems. The last task in the task table is always the system wait
state.
Hopefully the system never reaches that state, other wise nothing is being done.
Just thought I'd mention it, as it uses similar tables and keeps track of
events, and the state of each of the events whether active, pending or complete.
One of the nice things about such a system is the ability to run through the
tables in a commutator fashion, only paying attention to tasks or sub-tasks
which need servicing and pretty much ignoring the rest.
These tasks are also set up in a linked-list scheme. Each task points to the
next task, and back to the prior one. Generally the task list is kept in
priority order, and changing the order is just a matter of changing the each of
the links appropriately.
Getting this back on a Stamp topic, one of the earlier PBasic Stamp Manuals,
possibly Version 1.8 or prior, had a message table for LCD display, if I
remember correctly. I'll see if I can locate it, and if I find it, I'll pass it
along.
Bruce Bates
>> Hi,
>interface?
>that is
>> regards peter
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
http://www.dkl.com/pdf/tabledrivendesign.pdf
It lacks however a working example in real code.
But the table descriptions (especially the decision tables)
are good and when inplemented properly could/should reduce
code by 30% or more.
The trick is to define rules, then use a table lookup to
find all matching entries and executing the tasks belonging
to the matching rules.
regards peter
Sent: Sunday, February 29, 2004 12:55 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Table driven user interface
> At 10:54 PM 2/28/04 +0000, russranshaw wrote:
> >Peter,
> >of four elements:
> >1. States
> >4. Next State
> >generalize it!
> >Russ
> Russ and Peter -
in event driven systems. The last task in the task table is always the
system wait state.
done.
complete. One of the nice things about such a system is the ability to run
through the tables in a commutator fashion, only paying attention to tasks
or sub-tasks which need servicing and pretty much ignoring the rest.
the next task, and back to the prior one. Generally the task list is kept in
of the links appropriately.
Manuals, possibly Version 1.8 or prior, had a message table for LCD display,
if I remember correctly. I'll see if I can locate it, and if I find it, I'll
pass it along.
> Regards,
> Bruce Bates
> >> Hi,
> >interface?
> >that is
> >> regards peter
> >Yahoo! Groups Links
> Yahoo! Groups Links
http://www.imatix.com/html/libero/
A free code generator for table driven design that generates
a framework for C or Java (perhaps useful for the javelin)
and a great number of other languages. Fast reading through
the docs it seems to be possible to add a 'schema' file (language
specific framework file) for other languages, like pbasic.
I will read it closer to find out if this really is possible.
regards peter
Sent: Sunday, February 29, 2004 1:58 AM
> I found this to be good reading material
> regards peter
> From: "Bruce Bates" <bvbates@u...>
> > >Peter,
> > >of four elements:
> > >1. States
> > >4. Next State
> > >generalize it!
> > >Russ
> > Russ and Peter -
managers
> system wait state.
being
> done.
of
tasks
in
each
display,
I'll
> pass it along.
> > Regards,
> > Bruce Bates
> > >> Hi,
> > >interface?
> > >that is
> > >> regards peter
and
> > >Yahoo! Groups Links
and
> > Yahoo! Groups Links
> Yahoo! Groups Links
Could you give us a "fer-instance" of what it is you want to accomplish?
I have a device (Solar Energy Inverter) that has an imbedded micro
controller. It uses a menu system where there are several groups of
related menu items each of which has several sub-items. There are
three main types of sub-item. On lets you select a "mode" using left
and right arrow keys. Another uses the arrow keys to
increment/decrement a value. The third is simply information.
There are six control buttons in all. Two to select the main
category, two to select the sub-category, and two as mentioned above.
Such a scheme would be fairly simple to abstract, using EEPROM to
store the menu data.
And I don't think it would be difficult to build a "compler" to stuff
the EEPROM!
Would something on this order be what you're after?
Russ
> I also found this
> regards peter
> From: "Peter Verkaik" <peterverkaik@b...>
> > regards peter
> > > >Peter,
to shre
a good
Decision
think
> > > >of four elements:
> > > >1. States
be done
> > > >4. Next State
> > > >generalize it!
> > > >Russ
> > > Russ and Peter -
> managers
> > system wait state.
> being
> > done.
track
> of
ability to run
> tasks
points to
is kept
> in
changing the
> each
> display,
find it,
> I'll
> > pass it along.
> > > Regards,
> > > Bruce Bates
> > > >> Hi,
> > > >interface?
> > > >that is
> > > >> regards peter
Subject
> and
> > > >Yahoo! Groups Links
Subject
> and
> > > Yahoo! Groups Links
Subject and
> > Yahoo! Groups Links
what you're looking for as far as input. I've done a multi-level menu
with an LCD and control inputs (up, down, left, right, enter), is that
what you're looking for? If yes, take a look at this to see if it
helps:
http://www.parallax.com/dl/docs/cols/nv/vol2/col/62.pdf
Note that I wrote that article 3.5 years ago and it could stand an
updating to PBASIC 2.5 syntax.
As far as "table driven control" goes, the first thing I think of is
BRANCH or ON idx GOTO/GOSUB because these use a control value to jump to
the desired section of code.
-- Jon Williams
-- Dallas Office
From: Peter Verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=83upwCJyBkpwVrzlCQWCFfF6YiKeTLXwXWbe_nXNLPeeIifUm__YjlWSeFU_L8aWghVHb8j4hx6VyEgh4YN6yJuj0KY]peterverkaik@b...[/url
Sent: Saturday, February 28, 2004 3:43 PM
Subject: [noparse][[/noparse]basicstamps] Table driven user interface
interface? Preferred output device is a serial text lcd 2x16 or 4x20.
Preferred input devices are keys. I would like to program a text
intensive menu system into a table that is offloaded into external
eeprom, and then parsing that table while inside the menu command.
regards peter
I'll start like everybody else, my name is Dan and hope to become a
Stampalcoholic.
I haven't built anything yet but I have a number of projects in my head.
I got my board of edu. about 3 weeks ago but haven't had a chance to
hook it up (btw Active 123 has them for a bit over CAD200; yes I'm from
Canada).
One of my projects will include a main menu - sub menu design so if you
don't mind, can you please share your ideas with me too if you are going
to do it off the mailing list?
I don't have much programming experience but read lots of
manuals/documentation from Parallax so if you want to explaining a few
things along the way feel free to do so.
Basically, my project will activate solenoids, water valves and servos
(nothing new here) and the setup will be done via main menu + sub menus
with an LCD and push buttons for system info and user feedback.
Great newsgroup, I've been lurking on this NS for a long time and am
imprested with the amount of support from everybody and especially
Parallax's people (Jon W. do you ever sleep?).
I think there was someone thinking about starting a BASIC Stamp club in
Canada, any luck with that?
Thanks.
Dan
From: russranshaw [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EypdJ9r5AbW-Mou4JNQA27ipwqNCw87Kb9-fTxRV_SdHIwTfoIThCH4KH2seW003e3OXNNuT9PU]home.rr@c...[/url
Sent: February 29, 2004 10:08 AM
Subject: [noparse][[/noparse]basicstamps] Re: Table driven user interface
Peter,
related menu items each of which has several sub-items. There are three
main types of sub-item. On lets you select a "mode" using left and
right arrow keys. Another uses the arrow keys to increment/decrement a
There are six control buttons in all. Two to select the main category,
Such a scheme would be fairly simple to abstract, using EEPROM to store
the menu data.
the EEPROM!
Russ
--- In basicstamps@yahoogroups.com, "Peter Verkaik" <peterverkaik@b...>
wrote:
> I also found this
> A free code generator for table driven design that generates a
> framework for C or Java (perhaps useful for the javelin) and a great
> number of other languages. Fast reading through the docs it seems to
> be possible to add a 'schema' file (language specific framework file)
> for other languages, like pbasic. I will read it closer to find out if
> regards peter
> > But the table descriptions (especially the decision tables) are good
> > and when inplemented properly could/should reduce code by 30% or
> > more. The trick is to define rules, then use a table lookup to
> > regards peter
> > > >Peter,
to shre
a good
Decision
think
> > > >of four elements:
> > > >1. States
class)
be done
> > > >4. Next State
> > > >of Actions and one Next state. I am currently doing this on a
> > > >Javelin Stamp, but the table is hard-coded. I'd love to discuss
> > > >a way to generalize it!
> > > >Russ
> > > Russ and Peter -
> managers
> > the system wait state.
> > > is
> being
> > done.
track
> of
> > or complete. One of the nice things about such a system is the
ability to run
to
> tasks
points to
is kept
> in
changing the
> each
> > > Stamp
> display,
find it,
> I'll
> > pass it along.
> > > Regards,
> > > Bruce Bates
> > > >> Hi,
> > > >> user
> > > >interface?
> > > >that is
> > > >> while inside the menu command. Program language may be pbasic,
> > > >> java or c.
> > > >> regards peter
Subject
> and
> > > >Yahoo! Groups Links
Subject
> and
> > > Yahoo! Groups Links
Subject and
> > Yahoo! Groups Links
Yahoo! Groups Links
-- Jon Williams
-- Dallas Office
From: Dan Angiu [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=062Qu2kXrZVKNcNWBc29Mwh3T_qTj23s7rx4QTAf6KW4en4Ge4c4yYvDXDCdAXPL-r8VMzG5nk5e7Ah1iw]dan.angiu@n...[/url
Sent: Sunday, February 29, 2004 11:02 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Table driven user interface
Hi guys,
Stampalcoholic. I haven't built anything yet but I have a number of
projects in my head. I got my board of edu. about 3 weeks ago but
haven't had a chance to hook it up (btw Active 123 has them for a bit
over CAD200; yes I'm from Canada).
to do it off the mailing list? I don't have much programming experience
but read lots of manuals/documentation from Parallax so if you want to
explaining a few things along the way feel free to do so.
Parallax's people (Jon W. do you ever sleep?). I think there was someone
thinking about starting a BASIC Stamp club in Canada, any luck with
that?
Thanks.
Dan
From: russranshaw [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UOujogqLzRTH_MVLQeYLJai261XPT2I4JA-jtDbGssg4h0n16eNzpc_P5QMyGxUEMe0tt7qEKu3wYg]home.rr@c...[/url
Peter,
the menu data.
the EEPROM!
Russ
wrote:
> I also found this
> regards peter
> > regards peter
> > > >Peter,
to shre
a good
Decision
think
> > > >of four elements:
> > > >1. States
class)
be done
> > > >4. Next State
> > > >Russ
> > > Russ and Peter -
> managers
> > > is
> being
> > done.
track
> of
ability to run
to
> tasks
points to
is kept
> in
changing the
> each
> > > Stamp
> display,
find it,
> I'll
> > pass it along.
> > > Regards,
> > > Bruce Bates
> > > >> Hi,
> > > >> user
> > > >interface?
> > > >that is
> > > >> java or c.
> > > >> regards peter
Subject
> and
> > > >Yahoo! Groups Links
Subject
> and
> > > Yahoo! Groups Links
Subject and
> > Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
My name is Russ, and I live in Canada. I hadn't heard ot the Basic
Stamp Club up here, so if you find any information, please CC it to
me, and I'll do likewise!
Russ
--- In basicstamps@yahoogroups.com, "Dan Angiu" <dan.angiu@n...> wrote:
> Hi guys,
> Stampalcoholic.
> Canada).
> Thanks.
> Dan
> From: russranshaw [noparse][[/noparse]mailto:home.rr@c...]
> Peter,
> the menu data.
> the EEPROM!
> Russ
> wrote:
> > I also found this
> > regards peter
> > > regards peter
> > > > >Peter,
> to shre
> a good
> Decision
> think
> > > > >of four elements:
> > > > >1. States
> class)
> be done
> > > > >4. Next State
> > > > >Russ
> > > > Russ and Peter -
> > managers
> > > > is
> > being
> > > done.
> track
> > of
> ability to run
> to
> > tasks
> points to
> is kept
> > in
> changing the
> > each
> > > > Stamp
> > display,
> find it,
> > I'll
> > > pass it along.
> > > > Regards,
> > > > Bruce Bates
> > > > >> Hi,
> > > > >> user
> > > > >interface?
> > > > >that is
> > > > >> java or c.
> > > > >> regards peter
> Subject
> > and
> > > > >Yahoo! Groups Links
> Subject
> > and
> > > > Yahoo! Groups Links
> Subject and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
If I hear something I'll let you know. I thought it was somebody on the
list but probablly I'm wrong.
I'm in Woodbridge, Ontario.
Jon W. thanks for the link.
Dan
From: russranshaw [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PIMsblVWPZsya6JgZDyBXmZqxtQpkmbQItHgoI6yhP6x6rj0oCxjt5aPMWB0btQRXLq9jef1ly-u]home.rr@c...[/url
Sent: February 29, 2004 4:44 PM
Dan,
Stamp Club up here, so if you find any information, please CC it to me,
Russ
Immagine a TV commercial. It begins with a shot of a very well
dressed man an woman in the back seat of what appears to be a plush
limosine. They chat amiably, pop the cork on a bottle of champagne
and drink a toast. The man reaches into his jacket pocket and
withdraws a cell phone. He flips it open, puts it to his hear, then
turns a little crank on its side. He pauses, then says "Central?"
The camera draws away to reveal tha the limosine is only the rear
half. The front is a much taller construction, with a man in a
top-hat holding the reins of a team of six beautiful horses which pull
them along. Around them are other similar conveyances, including on
that looks like a VW Beetle.
The message? What we enjoy today as "conveniencs" are simply levels
of abstraction of underlying technology.
I enjoyed reading your article. Yes, it can be done as you so
eloquently showed. But what we are discussing here are ways to
implement a level of abstraction for menu systems. That is, some
central code that does the grunt work of managing menus and can be
re-used in a simple manner.
I have never had the pleasure of working with a BasicStamp. I chose
the Javelin for my project based on its attributes, primarily a larger
RAM space and use of a Java-based language. Again, even these are
levels of abstraction that isolate me from the actual bits and bytes
of the underlying CPU, which itself is an abstration that separates
the apparent CPU from the transistors and gates of the actual processor.
Russ
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...> wrote:
> Storing and printing strings from EEPROM is a no-brainer -- I'm not sure
> helps:
> -- Jon Williams
> -- Dallas Office
> From: Peter Verkaik [noparse][[/noparse]mailto[noparse]:p[/noparse]eterverkaik@b...]
> Hi,
> regards peter
Russ, I uploaded something I pieced together. It will not work as it is
incomplete.
I defined a table setup to find out how much code would be needed to
navigate
through menus using tables. The size of the navigation code is even smaller
than I expected.
What I need is to run a setup program (like a PC bios) that has much text,
this is for the benefit of application end-users.
This setup program will be for the javelin. To create the tables I use the
BS
because there is no DATA equivalent for the havelin, and programming such
menus
inline in javelin code eats too much code space.
I would like to discuss the layout of the tables. I am sure they could be
better
organized or perhaps even compacter or more general. The idea is to retrieve
all required settings
from the eeprom rather than hardcoded in the software.
Comments please.
regards peter
Sent: Sunday, February 29, 2004 4:07 PM
> Peter,
> the EEPROM!
> Russ
> > I also found this
> > regards peter
> > > regards peter
> > > > >Peter,
> to shre
> a good
> Decision
> think
> > > > >of four elements:
> > > > >1. States
> be done
> > > > >4. Next State
> > > > >generalize it!
> > > > >Russ
> > > > Russ and Peter -
> > managers
> > > system wait state.
> > being
> > > done.
> track
> > of
> ability to run
> > tasks
> points to
> is kept
> > in
> changing the
> > each
> > display,
> find it,
> > I'll
> > > pass it along.
> > > > Regards,
> > > > Bruce Bates
> > > > >> Hi,
> > > > >interface?
> > > > >that is
> > > > >> regards peter
> Subject
> > and
> > > > >Yahoo! Groups Links
> Subject
> > and
> > > > Yahoo! Groups Links
> Subject and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
I'm in Port Colborne, ON!
Russ
> Russ,
> Dan
> Dan,
> Russ
I have a similar idea, except what I envision is a "compiler" that
runs on the PC and creates some Java classes, including the menu
driver and a "setup" program. Within the setup program would be a
character array that contained the data destined for the EEPROM. Part
of the table description language would be information about the
starting and ending EEPROM addresses. The user would have to modify
the setup program to get the appropriate pin assignments, driver
class(es) for the EEPROM, etc. My reason for thinking along this line
is that I have a 32k EEPROM, and have other sues for much of it.
Russ
> Thanks Jon for your N&V article.
> incomplete.
> navigate
smaller
> than I expected.
text,
use the
> BS
such
> menus
could be
> better
retrieve
> Comments please.
> regards peter
> From: "russranshaw" <home.rr@c...>
> > Peter,
accomplish?
> > the EEPROM!
> > Russ
> > > I also found this
> > > regards peter
> > > > regards peter
> > > > > >Peter,
> > to shre
> > a good
> > Decision
> > think
> > > > > >of four elements:
> > > > > >1. States
table class)
> > be done
> > > > > >4. Next State
set of
Javelin
way to
> > > > > >generalize it!
> > > > > >Russ
> > > > > Russ and Peter -
> > > managers
always the
> > > > system wait state.
nothing is
> > > being
> > > > done.
> > track
> > > of
pending or
> > ability to run
attention to
> > > tasks
rest.
> > points to
> > is kept
> > > in
> > changing the
> > > each
PBasic Stamp
for LCD
> > > display,
> > find it,
> > > I'll
> > > > pass it along.
> > > > > Regards,
> > > > > Bruce Bates
> > > > > >> Hi,
driven user
> > > > > >interface?
a table
> > > > > >that is
table while
> > > > > >> regards peter
> > Subject
> > > and
> > > > > >Yahoo! Groups Links
> > Subject
> > > and
> > > > > Yahoo! Groups Links
> > Subject and
> > > > Yahoo! Groups Links
Subject and
> > Yahoo! Groups Links
The PBASIC interpreter in the BASIC Stamp is in this sense a table
driven user interface that is built on the underlying PIC
chip/instruction set. The table is the interpreter code that resides
in sequential locations in eeprom, and it consists of instruction
tokens and associated parameters that cause a branch to a subroutine
and actions based on those parameters. Then back to the table for
the next entry. And of course some table entries can alter the
flow. Multitasking processors are a more complicated, as they tend
toward event driven or object oriented programming.
Interesting article, and Wow! they are working in COBOL!
I don't know about a menu interface, but table driven scripts are a
natural for data logging that is synchronized to real time. Each
script block consists of many bytes in a memory area set aside for
the script table. The first entry in each block is a vector pointing
to the next script block in the sequence. Another entry in the block
is a vector pointing to the action to be performed and the rest of
the block consist of the parameters associated with that action. The
actions to be performed, "drivers", use flags and pointers passed by
the system to define their scope and their memory allocation, so that
the drivers can be used in multiple instances without conflict.
Then, changing the data logging scheme means a change in the table
and not in the program mechanism that reads and interprets the table.
For example, a second temperature sensor added to a scheme consists
of a table entry with the vector to the temperature driver, along
with the channels to be used, individual calibration factors, the
formats for LCD or serial data display, etc. The system passes
pointers to the next available file area. New drivers can be
installed for new actions that fit in the schema, for example, an
entirely new type of temperature sensor would entail a driver, but
the driver would be written to fit into the schema and would be
assigned its own vector. On the Stamp 2p/2pe the RUN and STORE
commands allows convenient cross-bank access to the table and to the
drivers.
That is not to say that the very next project won't require something
the does not fit into the schema! That always happens! Otherwise
programmers would be out of work!
-- Tracy
Barrie.
Incidentally, there is an "Extreme Hobbies" place in Richmond Hill/Vaughn
that use stamps for combat bots....that's were I picked up my bs2p40....for
interests sake anyhow...
Sent: Monday, March 01, 2004 1:00 PM
> Dan,
> Russ
> > Russ,
> > Dan
> > Dan,
> > Russ
> Yahoo! Groups Links
Does "Extreme Hobbies" carry electronic parts? Maybe DB-9 Male and
Female PCB connectors?
Russ
--- In basicstamps@yahoogroups.com, "SB" <steve.brady@r...> wrote:
> Hey, I grew up in Fort Erie....went out west and have made it back
and am I
> Barrie.
Hill/Vaughn
bs2p40....for
> > Dan,
> > Russ
wrote:
> > > Russ,
on the
> > > Dan
> > > Dan,
to me,
> > > Russ
Subject and
> > Yahoo! Groups Links
joking....is she?
They carry the parallax kits but nothing for individual components.
I'm still searching for places in general that I can order from. I know of
a few drop-in places, that I can't quite remember the names of now....haha
there's supposedly a REALLY good drop-in place near yonge street in TO.
Surplus place and all...
I'll have to find the name of that one!
sb
Sent: Monday, March 01, 2004 7:35 PM
> Barrie? It's a small world. My wife's daughter lives there!
> Russ
> and am I
> > Barrie.
> Hill/Vaughn
> bs2p40....for
> > > Dan,
> > > Russ
> wrote:
> > > > Russ,
> on the
> > > > Dan
> > > > Dan,
> to me,
> > > > Russ
> Subject and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
I see your point. But both Basic stamp and javelin cannot hold a full 32KB
eeprom image so multiple
'eeprom program cycles' will be required for a 32KB eeprom. Block size
changes for one cycle
could impact on the other cycles, forcing code changes for those other
cycles.
How about using an underlying structure that shows free and allocated blocks
and that is recognized
by basic stamp and javelin? That way available start and end addresses are
retrieved from the eeprom
itself. What I was thinking of is the javelin heap class I wrote that I can
easily port to the basic stamp.
Each block, either free or allocated, requires only 4 eeprom bytes to
maintain the heap structure.
This structure is limited to a 32KB eeprom. A 64KB eeprom could hold two
heap structures.
Whatever you put in allocated blocks (could be another heap) is up to the
application.
I suggest using signature words to identify allocated blocks.
regards peter
Sent: Monday, March 01, 2004 7:07 PM
> Peter,
> Russ
> > incomplete.
> > navigate
> smaller
> > than I expected.
> text,
> use the
> > BS
> such
> > menus
> could be
> > better
> retrieve
> > Comments please.
> > regards peter
> > > Peter,
> accomplish?
> > > the EEPROM!
> > > Russ
> > > > I also found this
> > > > regards peter
> > > > > regards peter
> > > > > > >Peter,
> > > to shre
> > > a good
> > > Decision
> > > think
> > > > > > >of four elements:
> > > > > > >1. States
> table class)
> > > be done
> > > > > > >4. Next State
> set of
> Javelin
> way to
> > > > > > >generalize it!
> > > > > > >Russ
> > > > > > Russ and Peter -
> > > > managers
> always the
> > > > > system wait state.
> nothing is
> > > > being
> > > > > done.
> > > track
> > > > of
> pending or
> > > ability to run
> attention to
> > > > tasks
> rest.
> > > points to
> > > is kept
> > > > in
> > > changing the
> > > > each
> PBasic Stamp
> for LCD
> > > > display,
> > > find it,
> > > > I'll
> > > > > pass it along.
> > > > > > Regards,
> > > > > > Bruce Bates
> > > > > > >> Hi,
> driven user
> > > > > > >interface?
> a table
> > > > > > >that is
> table while
> > > > > > >> regards peter
> > > Subject
> > > > and
> > > > > > >Yahoo! Groups Links
> > > Subject
> > > > and
> > > > > > Yahoo! Groups Links
> > > Subject and
> > > > > Yahoo! Groups Links
> Subject and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
Errata, the heap structure requires only 2 eeprom bytes to maintain the
structure.
regards peter
Sent: Tuesday, March 02, 2004 11:40 AM
> Russ,
> cycles.
blocks
can
> heap structures.
> application.
> regards peter
> > Peter,
> > Russ
is
> > > incomplete.
> > > navigate
> > smaller
> > > than I expected.
> > text,
> > use the
> > > BS
> > such
> > > menus
> > could be
> > > better
> > retrieve
> > > Comments please.
> > > regards peter
> > > > Peter,
> > accomplish?
left
above.
stuff
> > > > the EEPROM!
> > > > Russ
> > > > > I also found this
> > > > > regards peter
> > > > > > regards peter
> > > > > > > >Peter,
> > > > to shre
is
> > > > a good
> > > > Decision
can
> > > > think
> > > > > > > >of four elements:
> > > > > > > >1. States
> > table class)
to
> > > > be done
> > > > > > > >4. Next State
Events
> > set of
> > Javelin
> > way to
> > > > > > > >generalize it!
> > > > > > > >Russ
> > > > > > > Russ and Peter -
task
> > > > > managers
> > always the
> > > > > > system wait state.
> > nothing is
> > > > > being
> > > > > > done.
keeps
> > > > track
> > > > > of
> > pending or
> > > > ability to run
> > attention to
> > > > > tasks
> > rest.
> > > > points to
list
> > > > is kept
> > > > > in
> > > > changing the
> > > > > each
> > PBasic Stamp
> > for LCD
> > > > > display,
> > > > find it,
> > > > > I'll
> > > > > > pass it along.
> > > > > > > Regards,
> > > > > > > Bruce Bates
> > > > > > > >> Hi,
> > driven user
> > > > > > > >interface?
> > a table
> > > > > > > >that is
> > table while
> > > > > > > >> regards peter
> > > > Subject
> > > > > and
> > > > > > > >Yahoo! Groups Links
> > > > Subject
> > > > > and
> > > > > > > Yahoo! Groups Links
> > > > Subject and
> > > > > > Yahoo! Groups Links
> > Subject and
> > > > Yahoo! Groups Links
and
> > Yahoo! Groups Links
> Yahoo! Groups Links
she's a true Canuk.
I buy a lot of components from Digi-Key. They can ship from inside
Canada, which saves the "agent's fee", which can amount to a large
amount! Unfortunately they don't have everything I want/need, such as
the PCV male/female DB9 connectors (escept in lots of 100).
Russ
> Hmm....is she single?! KIDDING!! unless she is of course...no
really...I'm
> joking....is she?
know of
now....haha
> sb
> > Russ
> > and am I
> > > Barrie.
> > Hill/Vaughn
> > bs2p40....for
> > > > Dan,
> > > > Russ
> > wrote:
> > > > > Russ,
> > on the
> > > > > Dan
> > > > > Dan,
the Basic
> > to me,
> > > > > Russ
> > Subject and
> > > > Yahoo! Groups Links
Subject and
> > Yahoo! Groups Links
I'm not sure the elaborteness is justified. Those 32k EEPROMs are
pretty cheap ($5). Besides, I don't see even a very complex menu
requiring anywhere near 32k.
If my original thought dosen't sit well (putting the entire structure
which is destined for the EEPROM in a Javelin program), then one could
write a generic Javelin program that would take a stream of data via a
serial port and write it to the EEPROM. If timing is a problem, it is
feasible to implement a simple error checking packetized protocol
which would request the next packet. That way it would be possible to
download some data, write it to the EEPROM, downloand the next chunk,
write it, etc. I don't see speed being a problem. I guess I don't
understand your point about "cycles".
Russ
> Russ,
> structure.
> regards peter
> > Russ,
full 32KB
> > cycles.
> blocks
addresses are
that I
> can
hold two
> > heap structures.
to the
> > application.
> > regards peter
> > > Peter,
Part
this line
> > > Russ
as it
> is
> > > > incomplete.
needed to
> > > > navigate
even
> > > smaller
> > > > than I expected.
has much
> > > text,
> > > use the
> > > > BS
programming
> > > such
> > > > menus
> > > could be
> > > > better
is to
> > > retrieve
> > > > Comments please.
> > > > regards peter
> > > > > Peter,
> > > accomplish?
micro
groups of
There are
> left
> above.
EEPROM to
> stuff
> > > > > the EEPROM!
> > > > > Russ
> > > > > > I also found this
(language
> > > > > > regards peter
> > > > > > > regards peter
> > > > > > > > >Peter,
lines. Care
> > > > > to shre
information
> is
> > > > > a good
called
> > > > > Decision
chart. I
> can
> > > > > think
> > > > > > > > >of four elements:
> > > > > > > > >1. States
> > > table class)
things
> to
> > > > > be done
> > > > > > > > >4. Next State
> Events
have a
> > > set of
this on a
> > > Javelin
discuss a
> > > way to
> > > > > > > > >generalize it!
> > > > > > > > >Russ
> > > > > > > > Russ and Peter -
system
> task
> > > > > > managers
> > > always the
> > > > > > > system wait state.
> > > nothing is
> > > > > > being
> > > > > > > done.
> keeps
> > > > > track
> > > > > > of
> > > pending or
> > > > > ability to run
> > > attention to
> > > > > > tasks
ignoring the
> > > rest.
Each task
> > > > > points to
> list
> > > > > is kept
> > > > > > in
> > > > > changing the
> > > > > > each
> > > PBasic Stamp
> > > for LCD
> > > > > > display,
and if I
> > > > > find it,
> > > > > > I'll
> > > > > > > pass it along.
> > > > > > > > Regards,
> > > > > > > > Bruce Bates
> > > > > > > > >> Hi,
> > > driven user
> > > > > > > > >interface?
or 4x20.
system into
> > > a table
> > > > > > > > >that is
> > > table while
> > > > > > > > >> regards peter
Text in the
> > > > > Subject
> > > > > > and
> > > > > > > > >Yahoo! Groups Links
in the
> > > > > Subject
> > > > > > and
> > > > > > > > Yahoo! Groups Links
in the
> > > > > Subject and
> > > > > > > Yahoo! Groups Links
> > > Subject and
> > > > > Yahoo! Groups Links
Subject
> and
> > > Yahoo! Groups Links
Subject and
> > Yahoo! Groups Links
the "Table Driven Interface" is to have
the display bytes stored in an off-chip
EEPROM -- loaded through some method.
The program then knows the 'base' addr.
of each page in the EEPROM table. The
software merely needs to know which addr
to select -- then go to the EEPROM and
transfer the image from the Table to the
Display.
If that's what you're talking about, then
yes, the EEPROM loader program can be put
into the Javelin. Some PC-based Display
Generator program can generate the Display
data, and load it into the EEPROM (through
a simple program on the Javelin, or through
an EEPROM burner, your choice). Then,
the DisplayGen program needs to give you,
the programmer, the table of start addr for
the loaded 'screens'.
Then, you supply those 'screen' start addr to
your program, add the logic to navigate from
screen to screen, and you are good to go.
So, what's the problem with this approach?
Sounds brilliant to me. You get the stand-alone
nature of the Stamp, and nice screens from
the EEPROM.
--- In basicstamps@yahoogroups.com, "russranshaw" <home.rr@c...>
wrote:
> Peter,
structure
could
via a
is
to
chunk,
> Russ
> > Russ,
maintain the
> > structure.
> > regards peter
> > > Russ,
> full 32KB
Block size
those other
> > > cycles.
allocated
> > blocks
> addresses are
wrote
> that I
> > can
bytes to
> hold two
> > > heap structures.
up
> to the
> > > application.
> > > regards peter
> > > > Peter,
that
menu
be a
EEPROM.
> Part
the
modify
driver
> this line
it.
> > > > Russ
work
> as it
> > is
> > > > > incomplete.
> needed to
> > > > > navigate
is
> even
> > > > smaller
> > > > > than I expected.
> has much
> > > > text,
tables I
> > > > use the
> > > > > BS
> programming
> > > > such
> > > > > menus
they
> > > > could be
> > > > > better
idea
> is to
> > > > retrieve
> > > > > Comments please.
> > > > > regards peter
> > > > > > Peter,
to
> > > > accomplish?
imbedded
> micro
> groups of
> There are
a "mode" using
> > left
information.
main
mentioned
> > above.
> EEPROM to
a "compler" to
> > stuff
> > > > > > the EEPROM!
> > > > > > Russ
> > > > > > > I also found this
generates
javelin)
through
> (language
pbasic.
possible.
> > > > > > > regards peter
interface
tables)
reduce
to
belonging
> > > > > > > > regards peter
interface
> > > > > > > > > >Peter,
> lines. Care
> > > > > > to shre
> information
> > is
> > > > > > a good
language"
> called
> > > > > > Decision
> chart. I
> > can
> > > > > > think
> > > > > > > > > >of four elements:
> > > > > > > > > >1. States
the
> > > > table class)
cause
> things
> > to
> > > > > > be done
> > > > > > > > > >4. Next State
(rows) and
> > Events
can
> have a
> > > > set of
> this on a
> > > > Javelin
> discuss a
> > > > way to
> > > > > > > > > >generalize it!
> > > > > > > > > >Russ
> > > > > > > > > Russ and Peter -
> system
> > task
> > > > > > > managers
table is
> > > > always the
> > > > > > > > system wait state.
other wise
> > > > nothing is
> > > > > > > being
> > > > > > > > done.
tables and
> > keeps
> > > > > > track
> > > > > > > of
active,
> > > > pending or
is the
> > > > > > ability to run
paying
> > > > attention to
> > > > > > > tasks
> ignoring the
> > > > rest.
> Each task
> > > > > > points to
the task
> > list
> > > > > > is kept
> > > > > > > in
matter of
> > > > > > changing the
> > > > > > > each
earlier
> > > > PBasic Stamp
table
> > > > for LCD
> > > > > > > display,
> and if I
> > > > > > find it,
> > > > > > > I'll
> > > > > > > > pass it along.
> > > > > > > > > Regards,
> > > > > > > > > Bruce Bates
> > > > > > > > > >> Hi,
table
> > > > driven user
> > > > > > > > > >interface?
> or 4x20.
> system into
> > > > a table
> > > > > > > > > >that is
that
> > > > table while
> > > > > > > > > >> regards peter
> Text in the
> > > > > > Subject
> > > > > > > and
> > > > > > > > > >Yahoo! Groups Links
Text
> in the
> > > > > > Subject
> > > > > > > and
> > > > > > > > > Yahoo! Groups Links
> in the
> > > > > > Subject and
> > > > > > > > Yahoo! Groups Links
the
> > > > Subject and
> > > > > > Yahoo! Groups Links
> Subject
> > and
> > > > Yahoo! Groups Links
> Subject and
> > > Yahoo! Groups Links
>If I understand this approach, the goal of
>Display.
>the EEPROM.
Perhaps a look at the SEETRON TRM-425 would be worthwhile. They do exactly what
you're attempting to do. They even provide a Windows program to enter the data
in the EEPROM. The web site is here: www.seetron.com .
Bruce Bates
<About 10K snipped!>
About cycles,
You mentioned you had also other uses for the eeprom, so the menu data is
only a part
of the total eeprom. If I fill part of the eeprom with menu data from a
basic stamp (that is one cycle),
I may also want to store other data for the runtime application (more
cycles), or fill parts from a PC,
either through stamp or javelin (again more cycles), then finally put the
controller with the runtime
application in place that uses the eeprom contents. To prevent changing
sources to apply moved
addresses all the time, I mentioned the heap as a simple way for each
controller to find out free eeprom areas.
Alan,
Not only screen (in this case LCD) data is put in eeprom, but also the
navigation data. Based on key inputs
you traverse the table until you reach a point where a value must be
assigned to a persistent parameter.
The code to traverse the table is small enough to add to the runtime
application.
I would like some comments on the table formats as I presented them in the
file I uploaded to the forum.
(in folder menu). I tried to insert an additional menu in the table today,
anf that was annoying (too many pointers
needed to be changed). The current format is not good enough for me with
respect to table maintenance.
Some clever ideas please.
regards peter.
Sent: Tuesday, March 02, 2004 7:38 PM
> Display.
> the EEPROM.
> wrote:
> > Peter,
> structure
> could
> via a
> is
> to
> chunk,
> > Russ
> > > Russ,
> maintain the
> > > structure.
> > > regards peter
> > > > Russ,
> > full 32KB
> Block size
> those other
> > > > cycles.
> allocated
> > > blocks
> > addresses are
> wrote
> > that I
> > > can
> bytes to
> > hold two
> > > > heap structures.
> up
> > to the
> > > > application.
> > > > regards peter
> > > > > Peter,
> that
> menu
> be a
> EEPROM.
> > Part
> the
> modify
> driver
> > this line
> it.
> > > > > Russ
> work
> > as it
> > > is
> > > > > > incomplete.
> > needed to
> > > > > > navigate
> is
> > even
> > > > > smaller
> > > > > > than I expected.
> > has much
> > > > > text,
> tables I
> > > > > use the
> > > > > > BS
> > programming
> > > > > such
> > > > > > menus
> they
> > > > > could be
> > > > > > better
> idea
> > is to
> > > > > retrieve
> > > > > > Comments please.
> > > > > > regards peter
> > > > > > > Peter,
> to
> > > > > accomplish?
> imbedded
> > micro
> > groups of
> > There are
> a "mode" using
> > > left
> information.
> main
> mentioned
> > > above.
> > EEPROM to
> a "compler" to
> > > stuff
> > > > > > > the EEPROM!
> > > > > > > Russ
> > > > > > > > I also found this
> generates
> javelin)
> through
> > (language
> pbasic.
> possible.
> > > > > > > > regards peter
> interface
> tables)
> reduce
> to
> belonging
> > > > > > > > > regards peter
> interface
> > > > > > > > > > >Peter,
> > lines. Care
> > > > > > > to shre
> > information
> > > is
> > > > > > > a good
> language"
> > called
> > > > > > > Decision
> > chart. I
> > > can
> > > > > > > think
> > > > > > > > > > >of four elements:
> > > > > > > > > > >1. States
> the
> > > > > table class)
> cause
> > things
> > > to
> > > > > > > be done
> > > > > > > > > > >4. Next State
> (rows) and
> > > Events
> can
> > have a
> > > > > set of
> > this on a
> > > > > Javelin
> > discuss a
> > > > > way to
> > > > > > > > > > >generalize it!
> > > > > > > > > > >Russ
> > > > > > > > > > Russ and Peter -
> > system
> > > task
> > > > > > > > managers
> table is
> > > > > always the
> > > > > > > > > system wait state.
> other wise
> > > > > nothing is
> > > > > > > > being
> > > > > > > > > done.
> tables and
> > > keeps
> > > > > > > track
> > > > > > > > of
> active,
> > > > > pending or
> is the
> > > > > > > ability to run
> paying
> > > > > attention to
> > > > > > > > tasks
> > ignoring the
> > > > > rest.
> > Each task
> > > > > > > points to
> the task
> > > list
> > > > > > > is kept
> > > > > > > > in
> matter of
> > > > > > > changing the
> > > > > > > > each
> earlier
> > > > > PBasic Stamp
> table
> > > > > for LCD
> > > > > > > > display,
> > and if I
> > > > > > > find it,
> > > > > > > > I'll
> > > > > > > > > pass it along.
> > > > > > > > > > Regards,
> > > > > > > > > > Bruce Bates
> > > > > > > > > > >> Hi,
> table
> > > > > driven user
> > > > > > > > > > >interface?
> > or 4x20.
> > system into
> > > > > a table
> > > > > > > > > > >that is
> that
> > > > > table while
> > > > > > > > > > >> regards peter
> > Text in the
> > > > > > > Subject
> > > > > > > > and
> > > > > > > > > > >Yahoo! Groups Links
> Text
> > in the
> > > > > > > Subject
> > > > > > > > and
> > > > > > > > > > Yahoo! Groups Links
> > in the
> > > > > > > Subject and
> > > > > > > > > Yahoo! Groups Links
> the
> > > > > Subject and
> > > > > > > Yahoo! Groups Links
> > Subject
> > > and
> > > > > Yahoo! Groups Links
> > Subject and
> > > > Yahoo! Groups Links
> Yahoo! Groups Links
Here is what I envision:
1. Prepare a description of the Menu in a file. (I have some
ideas about this).
2. A Windows/whatever program translates the description and produces
one or more Java classes (or PBASIC code) and a file which is a
structured data representation of the menu's display text and navigation.
3. A Java (or PBASIC) program is started, and a Windows/whatever
program reads the data which is destined for the EEPROM and sends it
to the Stamp using some kind of send/wait with error checking
protocol. The Stamp program commits the data to the EEPROM.
4. The Java classes or PBASIC code snippets are combined with an
application program. The resulting program would contain code that
understands the EEPROM data structure. It displays, navigates, and
stores/modifies varuables as dictated by the original Menu description.
I was thinking about relying on a very simple EEPROM management
technique: the designer keeps track of what is where. For example,
put the Menu structure data in the last 4k of a 32k EEPROM and use the
rest of the EEPROM for whatever is needed. This shouldn't be terribly
unreasonable, as I don't forsee the menu data being terribly large for
most application. And if really needed, use dedicated EEPROMs for the
various functions. As I said earler, they are cheap.
Russ
> Russ,
> About cycles,
data is
> only a part
put the
> Alan,
> application.
in the
today,
> regards peter.
> From: "Allan Lane" <allan.lane@h...>
> > Display.
> > the EEPROM.
> > wrote:
> > > Peter,
> > structure
> > could
> > via a
> > is
> > to
> > chunk,
> > > Russ
> > > > Russ,
> > maintain the
> > > > structure.
> > > > regards peter
> > > > > Russ,
> > > full 32KB
> > Block size
> > those other
> > > > > cycles.
> > allocated
> > > > blocks
> > > addresses are
> > wrote
> > > that I
> > > > can
> > bytes to
> > > hold two
> > > > > heap structures.
> > up
> > > to the
> > > > > application.
> > > > > regards peter
> > > > > > Peter,
> > that
> > menu
> > be a
> > EEPROM.
> > > Part
> > the
> > modify
> > driver
> > > this line
> > it.
> > > > > > Russ
> > work
> > > as it
> > > > is
> > > > > > > incomplete.
> > > needed to
> > > > > > > navigate
> > is
> > > even
> > > > > > smaller
> > > > > > > than I expected.
> > > has much
> > > > > > text,
> > tables I
> > > > > > use the
> > > > > > > BS
> > > programming
> > > > > > such
> > > > > > > menus
> > they
> > > > > > could be
> > > > > > > better
> > idea
> > > is to
> > > > > > retrieve
> > > > > > > Comments please.
> > > > > > > regards peter
> > > > > > > > Peter,
> > to
> > > > > > accomplish?
> > imbedded
> > > micro
> > > groups of
> > > There are
> > a "mode" using
> > > > left
> > information.
> > main
> > mentioned
> > > > above.
> > > EEPROM to
> > a "compler" to
> > > > stuff
> > > > > > > > the EEPROM!
> > > > > > > > Russ
> > > > > > > > > I also found this
> > generates
> > javelin)
> > through
> > > (language
> > pbasic.
> > possible.
> > > > > > > > > regards peter
> > interface
> > tables)
> > reduce
> > to
> > belonging
> > > > > > > > > > regards peter
> > interface
> > > > > > > > > > > >Peter,
> > > lines. Care
> > > > > > > > to shre
> > > information
> > > > is
> > > > > > > > a good
> > language"
> > > called
> > > > > > > > Decision
> > > chart. I
> > > > can
> > > > > > > > think
> > > > > > > > > > > >of four elements:
> > > > > > > > > > > >1. States
> > the
> > > > > > table class)
> > cause
> > > things
> > > > to
> > > > > > > > be done
> > > > > > > > > > > >4. Next State
> > (rows) and
> > > > Events
> > can
> > > have a
> > > > > > set of
> > > this on a
> > > > > > Javelin
> > > discuss a
> > > > > > way to
> > > > > > > > > > > >generalize it!
> > > > > > > > > > > >Russ
> > > > > > > > > > > Russ and Peter -
> > > system
> > > > task
> > > > > > > > > managers
> > table is
> > > > > > always the
> > > > > > > > > > system wait state.
> > other wise
> > > > > > nothing is
> > > > > > > > > being
> > > > > > > > > > done.
> > tables and
> > > > keeps
> > > > > > > > track
> > > > > > > > > of
> > active,
> > > > > > pending or
> > is the
> > > > > > > > ability to run
> > paying
> > > > > > attention to
> > > > > > > > > tasks
> > > ignoring the
> > > > > > rest.
> > > Each task
> > > > > > > > points to
> > the task
> > > > list
> > > > > > > > is kept
> > > > > > > > > in
> > matter of
> > > > > > > > changing the
> > > > > > > > > each
> > earlier
> > > > > > PBasic Stamp
> > table
> > > > > > for LCD
> > > > > > > > > display,
> > > and if I
> > > > > > > > find it,
> > > > > > > > > I'll
> > > > > > > > > > pass it along.
> > > > > > > > > > > Regards,
> > > > > > > > > > > Bruce Bates
> > > > > > > > > > > >> Hi,
> > table
> > > > > > driven user
> > > > > > > > > > > >interface?
> > > or 4x20.
> > > system into
> > > > > > a table
> > > > > > > > > > > >that is
> > that
> > > > > > table while
> > > > > > > > > > > >> regards peter
> > > Text in the
> > > > > > > > Subject
> > > > > > > > > and
> > > > > > > > > > > >Yahoo! Groups Links
> > Text
> > > in the
> > > > > > > > Subject
> > > > > > > > > and
> > > > > > > > > > > Yahoo! Groups Links
> > > in the
> > > > > > > > Subject and
> > > > > > > > > > Yahoo! Groups Links
> > the
> > > > > > Subject and
> > > > > > > > Yahoo! Groups Links
> > > Subject
> > > > and
> > > > > > Yahoo! Groups Links
> > > Subject and
> > > > > Yahoo! Groups Links
Subject and
> > Yahoo! Groups Links
I'm starting a clean slate for this.
Here is a simple idea for setting up a Menu structure:
1.0 Main Menu Item
1.1 First sub-item
bLIST AAA, BBB, CCC
1.2 Second sub-item
iLIST VVV = ('DDD', 23), ('EEE', 123), ('FFF', 987)
1.3 Third sub-item
dITEM 'The value is: ' FOO (3.1)
1.3.1 A third tier menu item
2.0 Second Main Menu Item
etc.
"bLIST" refers t Boolean variables. iLIST to integer variables.
dITEM is used to display a descriptive text followed by an optionally
formatted value (in this case, display as 123.4).
The symantics of the LISTs are: Display the list of names. The user
navigates to a particular choice (suitable indication woul dhave to be
used on the LCD), then when the menu entry is cleared that particular
In the case of dITEM, the user can increment or decrement the value.
The "compiler" translates the AAA, BBB, CCC, VVV into varibles as follows:
static boolean bvarAAA
static boolean bvarBBB
static boolean bvarCCC
static int VVV
static int FOO
Not terrible pretty, but food for thought!
Russ
That would be a nice tool, but regardless of how to fill the eeprom, we
should
define the table formats first. The idea is to have a single piece of code
for the application
program that traverses the tables, no matter how many menu levels there are.
For the
javelin then only a single class is required (no need to generate classes
for each new menu)
for which you define the eeprom start address for the menu data. For pbasic
a traverse
subroutine could be written to include in application programs.
About storage requirements, I defined full screens for a 4x20 lcd, so 80
bytes per screen.
My application requires about 100 persistent parameters (some are array
based) which
in worse case could lead to at least 8000 bytes of required eeprom space.
If possible I rather not define full screen text for each parameters, but
this too is part
of the table format, which we should define first.
Have you any ideas for the tables, including navigation?
regards peter
Sent: Tuesday, March 02, 2004 10:27 PM
> Peter,
> ideas about this).
> Russ
> > Russ,
> > About cycles,
> data is
> > only a part
> put the
> > Alan,
> > application.
> in the
> today,
> > regards peter.
> > > Display.
> > > the EEPROM.
> > > wrote:
> > > > Peter,
> > > structure
> > > could
> > > via a
> > > is
> > > to
> > > chunk,
> > > > Russ
> > > > > Russ,
> > > maintain the
> > > > > structure.
> > > > > regards peter
> > > > > > Russ,
> > > > full 32KB
> > > Block size
> > > those other
> > > > > > cycles.
> > > allocated
> > > > > blocks
> > > > addresses are
> > > wrote
> > > > that I
> > > > > can
> > > bytes to
> > > > hold two
> > > > > > heap structures.
> > > up
> > > > to the
> > > > > > application.
> > > > > > regards peter
> > > > > > > Peter,
> > > that
> > > menu
> > > be a
> > > EEPROM.
> > > > Part
> > > the
> > > modify
> > > driver
> > > > this line
> > > it.
> > > > > > > Russ
> > > work
> > > > as it
> > > > > is
> > > > > > > > incomplete.
> > > > needed to
> > > > > > > > navigate
> > > is
> > > > even
> > > > > > > smaller
> > > > > > > > than I expected.
> > > > has much
> > > > > > > text,
> > > tables I
> > > > > > > use the
> > > > > > > > BS
> > > > programming
> > > > > > > such
> > > > > > > > menus
> > > they
> > > > > > > could be
> > > > > > > > better
> > > idea
> > > > is to
> > > > > > > retrieve
> > > > > > > > Comments please.
> > > > > > > > regards peter
> > > > > > > > > Peter,
> > > to
> > > > > > > accomplish?
> > > imbedded
> > > > micro
> > > > groups of
> > > > There are
> > > a "mode" using
> > > > > left
> > > information.
> > > main
> > > mentioned
> > > > > above.
> > > > EEPROM to
> > > a "compler" to
> > > > > stuff
> > > > > > > > > the EEPROM!
> > > > > > > > > Russ
> > > > > > > > > > I also found this
> > > generates
> > > javelin)
> > > through
> > > > (language
> > > pbasic.
> > > possible.
> > > > > > > > > > regards peter
> > > interface
> > > tables)
> > > reduce
> > > to
> > > belonging
> > > > > > > > > > > regards peter
> > > interface
> > > > > > > > > > > > >Peter,
> > > > lines. Care
> > > > > > > > > to shre
> > > > information
> > > > > is
> > > > > > > > > a good
> > > language"
> > > > called
> > > > > > > > > Decision
> > > > chart. I
> > > > > can
> > > > > > > > > think
> > > > > > > > > > > > >of four elements:
> > > > > > > > > > > > >1. States
> > > the
> > > > > > > table class)
> > > cause
> > > > things
> > > > > to
> > > > > > > > > be done
> > > > > > > > > > > > >4. Next State
> > > (rows) and
> > > > > Events
> > > can
> > > > have a
> > > > > > > set of
> > > > this on a
> > > > > > > Javelin
> > > > discuss a
> > > > > > > way to
> > > > > > > > > > > > >generalize it!
> > > > > > > > > > > > >Russ
> > > > > > > > > > > > Russ and Peter -
> > > > system
> > > > > task
> > > > > > > > > > managers
> > > table is
> > > > > > > always the
> > > > > > > > > > > system wait state.
> > > other wise
> > > > > > > nothing is
> > > > > > > > > > being
> > > > > > > > > > > done.
> > > tables and
> > > > > keeps
> > > > > > > > > track
> > > > > > > > > > of
> > > active,
> > > > > > > pending or
> > > is the
> > > > > > > > > ability to run
> > > paying
> > > > > > > attention to
> > > > > > > > > > tasks
> > > > ignoring the
> > > > > > > rest.
> > > > Each task
> > > > > > > > > points to
> > > the task
> > > > > list
> > > > > > > > > is kept
> > > > > > > > > > in
> > > matter of
> > > > > > > > > changing the
> > > > > > > > > > each
> > > earlier
> > > > > > > PBasic Stamp
> > > table
> > > > > > > for LCD
> > > > > > > > > > display,
> > > > and if I
> > > > > > > > > find it,
> > > > > > > > > > I'll
> > > > > > > > > > > pass it along.
> > > > > > > > > > > > Regards,
> > > > > > > > > > > > Bruce Bates
> > > > > > > > > > > > >> Hi,
> > > table
> > > > > > > driven user
> > > > > > > > > > > > >interface?
> > > > or 4x20.
> > > > system into
> > > > > > > a table
> > > > > > > > > > > > >that is
> > > that
> > > > > > > table while
> > > > > > > > > > > > >> regards peter
> > > > Text in the
> > > > > > > > > Subject
> > > > > > > > > > and
> > > > > > > > > > > > >Yahoo! Groups Links
> > > Text
> > > > in the
> > > > > > > > > Subject
> > > > > > > > > > and
> > > > > > > > > > > > Yahoo! Groups Links
> > > > in the
> > > > > > > > > Subject and
> > > > > > > > > > > Yahoo! Groups Links
> > > the
> > > > > > > Subject and
> > > > > > > > > Yahoo! Groups Links
> > > > Subject
> > > > > and
> > > > > > > Yahoo! Groups Links
> > > > Subject and
> > > > > > Yahoo! Groups Links
> Subject and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
excel spreadsheet. Then I would put the
link destinations in adjacent cells.
Then I would write a simple excel macro to
traverse the worksheet, writing out the
appropriate 'data' statements to a text file.
I would then cut-and-paste the text
file into the BSX file so when run it
would write the results into the EEPROM.
> Russ,
> About cycles,
data is
> only a part
from a
(more
put the
changing
each
> Alan,
the
> application.
in the
today,
with
> regards peter.
> > Display.
> > the EEPROM.
> > wrote:
> > > Peter,
are
menu
> > structure
> > could
> > via a
problem, it
> > is
protocol
possible
> > to
> > chunk,
don't
> > > Russ
> > > > Russ,
> > maintain the
> > > > structure.
> > > > regards peter
> > > > > Russ,
hold a
> > > full 32KB
> > Block size
> > those other
> > > > > cycles.
> > allocated
> > > > blocks
> > > addresses are
> > wrote
> > > that I
> > > > can
> > bytes to
could
> > > hold two
> > > > > heap structures.
heap) is
> > up
> > > to the
> > > > > application.
blocks.
> > > > > regards peter
> > > > > > Peter,
a "compiler"
> > that
the
> > menu
would
> > be a
> > EEPROM.
> > > Part
about
> > the
have to
> > modify
> > driver
along
> > > this line
of
> > it.
> > > > > > Russ
not
> > work
> > > as it
> > > > is
> > > > > > > incomplete.
be
> > > needed to
> > > > > > > navigate
code
> > is
> > > even
> > > > > > smaller
> > > > > > > than I expected.
that
> > > has much
> > > > > > text,
the
> > tables I
> > > > > > use the
> > > > > > > BS
> > > programming
> > > > > > such
> > > > > > > menus
sure
> > they
> > > > > > could be
> > > > > > > better
> > idea
> > > is to
> > > > > > retrieve
> > > > > > > Comments please.
> > > > > > > regards peter
> > > > > > > > Peter,
want
> > to
> > > > > > accomplish?
> > imbedded
> > > micro
several
> > > groups of
items.
> > > There are
> > a "mode" using
> > > > left
> > information.
the
> > main
> > mentioned
> > > > above.
using
> > > EEPROM to
> > a "compler" to
> > > > stuff
> > > > > > > > the EEPROM!
> > > > > > > > Russ
> > > > > > > > > I also found this
> > generates
> > javelin)
> > through
file
> > > (language
> > pbasic.
> > possible.
> > > > > > > > > regards peter
> > interface
decision
> > tables)
could/should
> > reduce
lookup
> > to
> > belonging
> > > > > > > > > > regards peter
> > interface
> > > > > > > > > > > >Peter,
same
> > > lines. Care
> > > > > > > > to shre
> > > information
> > > > is
> > > > > > > > a good
> > language"
> > > called
> > > > > > > > Decision
Transition
> > > chart. I
> > > > can
> > > > > > > > think
> > > > > > > > > > > >of four elements:
> > > > > > > > > > > >1. States
outside
> > the
> > > > > > table class)
> > cause
> > > things
> > > > to
> > > > > > > > be done
> > > > > > > > > > > >4. Next State
> > (rows) and
> > > > Events
intersection
> > can
> > > have a
> > > > > > set of
doing
> > > this on a
> > > > > > Javelin
to
> > > discuss a
> > > > > > way to
> > > > > > > > > > > >generalize it!
> > > > > > > > > > > >Russ
> > > > > > > > > > > Russ and Peter -
operating
> > > system
> > > > task
> > > > > > > > > managers
> > table is
> > > > > > always the
> > > > > > > > > > system wait state.
> > other wise
> > > > > > nothing is
> > > > > > > > > being
> > > > > > > > > > done.
> > tables and
> > > > keeps
> > > > > > > > track
> > > > > > > > > of
whether
> > active,
> > > > > > pending or
system
> > is the
> > > > > > > > ability to run
> > paying
> > > > > > attention to
> > > > > > > > > tasks
> > > ignoring the
> > > > > > rest.
scheme.
> > > Each task
> > > > > > > > points to
Generally
> > the task
> > > > list
> > > > > > > > is kept
> > > > > > > > > in
> > matter of
> > > > > > > > changing the
> > > > > > > > > each
> > earlier
> > > > > > PBasic Stamp
message
> > table
> > > > > > for LCD
> > > > > > > > > display,
it,
> > > and if I
> > > > > > > > find it,
> > > > > > > > > I'll
> > > > > > > > > > pass it along.
> > > > > > > > > > > Regards,
> > > > > > > > > > > Bruce Bates
Verkaik"
> > > > > > > > > > > >> Hi,
a
> > table
> > > > > > driven user
> > > > > > > > > > > >interface?
2x16
> > > or 4x20.
> > > system into
> > > > > > a table
> > > > > > > > > > > >that is
parsing
> > that
> > > > > > table while
> > > > > > > > > > > >> regards peter
subscribed.
> > > Text in the
> > > > > > > > Subject
> > > > > > > > > and
> > > > > > > > > > > >Yahoo! Groups Links
> > Text
> > > in the
> > > > > > > > Subject
> > > > > > > > > and
> > > > > > > > > > > Yahoo! Groups Links
Text
> > > in the
> > > > > > > > Subject and
> > > > > > > > > > Yahoo! Groups Links
Text in
> > the
> > > > > > Subject and
> > > > > > > > Yahoo! Groups Links
the
> > > Subject
> > > > and
> > > > > > Yahoo! Groups Links
the
> > > Subject and
> > > > > Yahoo! Groups Links
Subject and
> > Yahoo! Groups Links
4x20 LCD
LINE1: menu name or parameter name (10 chars), right side for custom use
(status?)
LINE2: option1
LINE3: option2
LINE4: option3 (blank if not available)
KEYS:6
X
1/U
X X X X
cancel 2/L More/R ok
X
3/D
The menutables consist of ParameterBlocks and MenuBlocks
[noparse][[/noparse]ParameterBlock]
NAME DATA "Parm Name " 'name (10 bytes)
ADDR DATA WORD 0 'address (2 bytes)
FIELD DATA 0 'fieldsize (1 byte)
REORD DATA 0 'recordsize (1 byte)
ATTR DATA WORD TYPE*4096+1 'b15-b12=type, b11-b0=record entries (2 bytes)
The parameter block holds name and address of the parameter.
The parameter name is to be printed on line1 of the lcd.
The field size is the storage size for this parameter.
The recordsize is the storage size of the record the parameter is part of.
fieldsize=recordsize in case parameter is total record.
field and record allow address calculation for array based variables
TYPE is one of the following
00 = RESERVED
01 = BIT (BINAIR)
02 = BYTE (BINAIR)
03 = WORD (BINAIR)
04 = DEC (ASCII)
05 = FLOAT (ASCII)
06 = HEX (ASCII)
07 = TEXT (ASCII)
TYPE determines which characters are valid when entering a new value for a
parameter.
[noparse][[/noparse]MenuBlock]
NAME DATA "Menu Name " 'name (10 bytes)
PREV DATA WORD PrevMenu 'previous menu (key OK or key CANCEL)
OPTION1 DATA "menu option 1 " '20 bytes
OPTION2 DATA "menu option 2 "
OPTION3 DATA "menu option 3 "
KEY1 DATA WORD OPT1+TYPE 'MenuBlock or ParameterBlock or Command
KEY2 DATA WORD OPY2+TYPE
KEY3 DATA WORD OPT3+TYPE
KEYMORE DATA WORD OPTION4
OPTION4 DATA "menu option 4 " 'second screen with options
OPTION5 DATA "menu option 5 "
OPTION6 DATA " "
KEY1 DATA WORD OPT4+TYPE
KEY2 DATA WORD OPT5+TYPE
KEY3 DATA WORD 0
KEYNORE DATA WORD OPTION1
The menu name is printed on the first line of the lcd.
PREV points to the previous menublock (0 if main menu)
OPTION1, OPTION2, OPTION3 are printed on lines 2,3,4 of lcd
KEY1, KEY2, KEY3 hold next menublock or a parameterblock (0 if no option)
KEYMORE points to next options so only lines 2,3,4 of lcd need update
If there are 3 or less options in total, KEYMORE should be 0.
If there are more than 3 options, KEYMORE points to the next 3 options
and KEYMORE for the last 3 options points to the first 3 options to allow
cycling through options.
When the ok key is pressed, a parameter may be updated in eeprom, when
cancel is pressed changes must be discarded.
TYPE identifies the type of addresses.
$0000 identifies options (so parser knows it must print 3 lines)
$4000 identifies a command (use BRANCH to execute a command)
$8000 identifies a menublock
$C000 identifies a parameterblock
The use of TYPE limits usable eeprom space for menus to 16KB
but that should not be a real limit.
When specifying a command, the supplied 'address' is an integervalue
not an eeprom address.
Since all options at the same menu level are within a single menublock,
menublocks can be indented to create an optical view of the menu tree.
This should enhance the readability and allow for easier maintaince.
[noparse][[/noparse]MenuStart]
MAIN DATA WORD MainMenu 'menublock for main menu
This scheme should be easy to traverse.
Any comments on this please.
regards peter
Sent: Tuesday, March 02, 2004 10:45 PM
> Peter,
> 1.0 Main Menu Item
> 1.1 First sub-item
> bLIST AAA, BBB, CCC
> 1.2 Second sub-item
> 1.3 Third sub-item
> etc.
> static int VVV
> static int FOO
> Russ
