Simple filtering with Basic Stamp?
I have added a compass sensor to my robot project(cmps03) and want
to turn the robot in a specified heading. Even though the compass is
fast the robot will overshoot the desired heading since there is a
delay when reading the heading from the compass.
This must be a common problem with a number of sensors. does anyone
have any suggestions on a solution to my problem. Has anyone
implemented som kind of simple filtering algorithm?
Rightnow im only testing if current heading is larger or smaller
than the desired heading.
Current code:
IF (turnangle>bearing) THEN
PWM_REG1 = turnSpeed
PWM_REG2 = -turnSpeed
GOSUB SETDC
DO
GOSUB ReadDir
LOOP UNTIL (bearing>=turnangle)
ENDIF
best regards
Magnus, Stockholm, Sweden
Current code:
GOSUB SETDC
DO
GOSUB ReadDir
ENDIF
best regards
assist (or desist) with overshoot.
Say...if the heading is more than 10degrees off, the robot moves at X speed.
If the robot is between 3 and 10degrees off it moves at Y speed. If the
robot is less than 3degrees off, it moves at Z speed. (I'm sure you get the
idea!)
We need the dishes to 'settle' at it's specified elevation within a certain
amount of time. If it takes too long to settle, the data will be old and
useless and the weather guys will never get the forecast right...oh
wait...uh....nevermind!! haha
I don't know what kind of output you have from the cmps03....does it give
you any sort of 359 point resolution? I've seen some that just remark on
the cardinal directions....
sb
Sent: Saturday, February 28, 2004 2:49 PM
Subject: [noparse][[/noparse]basicstamps] Simple filtering with Basic Stamp?
> Current code:
> GOSUB SETDC
> DO
> GOSUB ReadDir
> ENDIF
> best regards
> Yahoo! Groups Links
between your current heading and the desired heading -- further away
means faster turn; as you get closer you slow down. This should help
solve your overshoot problem.
-- Jon Williams
-- Dallas Office
From: skogsvargen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2-w39juxxLy4300gzasOMminHpAYjrSEvMXxLuy7BCcJodxweXWUZiJx4cu2JemaOXoVMcYh5tfbIjFh6owsYWvg]skogsvargen@h...[/url
Sent: Saturday, February 28, 2004 1:49 PM
Current code:
GOSUB SETDC
DO
GOSUB ReadDir
ENDIF
best regards
The typical solution to this is a "PID" algorithm.
This algorithm describes how to build a correction
factor for your control output based on your sensor
input. The other answers you've gotten have been
simple quick-and-dirty approaches to a PID.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> You might want to scale your turning rate based on the difference
help
> -- Jon Williams
> -- Dallas Office
> From: skogsvargen [noparse][[/noparse]mailto:skogsvargen@h...]
is
> Current code:
> GOSUB SETDC
> DO
> GOSUB ReadDir
> ENDIF
> best regards
