OT - Litrhium versus Ni Cad
Gentlemen:
I know this is OT but I thought I would ask.
I recently purchase a magnetometer. It uses a soldered in place
Lithium battery (3.5 vdc) to keep the internal Julian clock active when
not being powered. I wish to replace the dead battery with a Ni-Cad
(3.6vdc) that I can quickly replace when it is expired. This modification
will save me from disassembling the unit just to replace the battery.
The manufacturer of the magnetometer claims that the Lithium battery
(an AA size) should be replaced every 6 to 10 years.
Does anyone have any suggestions on why I shouldn't make this
conversion? I know the voltages are different. Should that make
any difference?
Thank you for your replies.
Dick
KF4DSL
any difference?
Dick
KF4DSL
must be low.
As I understand, NiCads can source a greater level of current. Lithiums have a
high
capacity is the current draw is small.
Since the actual voltage of a battery can be be above above nomimal, it would
seem
that your magnetometer should be able to deal with a slightly higher voltage.
Paul
> Gentlemen:
> any difference?
> Dick
> KF4DSL
> Yahoo! Groups Links
NiCad's self-discharge themselves. You can't
really expect a NiCad charge to last more than
3 months, unless you have some kind of charging
circuit on it.
Since the original circuit was designed for
a Lithium cell, it is very safe to assume there
is no charging circuit -- so you'll have to
replace the NiCad every 3 months with a fully
charged NiCad.
It makes LOTS more sense to replace the Lithium
with the appropriate Lithium, and then wait
another 6 to 12 years.
--- In basicstamps@yahoogroups.com, <verhap@o...> wrote:
> Is there a current concern? If the li will last 6 years, I imagine
the draw must be low.
Lithiums have a high
nomimal, it would seem
higher voltage.
> Paul
> > Gentlemen:
active when
Cad
modification
battery.
battery
> > any difference?
> > Dick
> > KF4DSL
Subject and Body of the message will be ignored.
> > Yahoo! Groups Links
Thank you gentlemen for your replies.
I took Mr. Lanes' advice and went back to RS to check for additional Lithium
batteries and I located a 3.6vdc size AA. I also purchase a single AA sized
battery holder and installed it in my magnetometer it works fine.
Thanks again. This is a great group. I've been here for 4 years.
Dick
KF4DSL
Sent: Friday, February 27, 2004 11:53 AM
Subject: [noparse][[/noparse]basicstamps] Re: OT - Litrhium versus Ni Cad
> Yes, there is a very good reason NOT to do this.
> circuit on it.
> charged NiCad.
> higher voltage.
> > Paul
> > > Gentlemen:
> active when
> Cad
> modification
> battery.
> battery
> > > any difference?
> > > Dick
> > > KF4DSL
> > > Yahoo! Groups Links
> Yahoo! Groups Links
